Siemens DLL Hijack CVE-2025-40827: Patch Solid Edge SE2025 and Software Center Now
Siemens has confirmed a high‑severity DLL‑hijacking vulnerability in Siemens Software Center and Solid Edge SE2025 that can allow arbitrary code execution when a crafted DLL is placed where the application will load it. The flaw is tracked as CVE‑2025‑40827 and carries a high severity rating — a CVSS v3.1 base score of 7.8 and a CVSS v4 base score of 8.5 — making it a near‑top priority patch for engineering and manufacturing environments that run these Windows applications.
Computer screen shows a DLL hijacking alert (CVE-2025-40827) with a shield icon.Background / Overview​
Siemens published a ProductCERT advisory for this issue (SSA‑365596), and U.S. agencies have republished the findings to raise operator awareness. The vulnerability is an instance of CWE‑427 — Uncontrolled Search Path Element, commonly exploited as DLL hijacking or search‑order hijacking. In practice, the vulnerable application can be tricked into loading a malicious DLL from a location that an attacker can write to, enabling code execution in the context of the user who runs the application. The canonical vendor advisory points operators to Siemens ProductCERT for remediation status; CISA’s republication served as an initial notice only and directs customers to Siemens for follow‑on updates. What’s affected (short form)
  • Siemens Software Center: all versions prior to 3.5.
  • Solid Edge SE2025: all versions prior to V225.0 Update 10.
The vendor‑assigned CVE and the NVD/third‑party tracking entries were published in November 2025; multiple vulnerability trackers confirm the CVSS values quoted above.
Technical details: how the DLL hijack works​
What is DLL hijacking?​
DLL hijacking occurs when an application allows the operating system to search for and load a dynamic‑link library (DLL) from directories that can be influenced by an attacker — for example, the current working directory, temporary folders, or user‑writable paths on a shared drive. If an attacker places a malicious DLL with the same name as a legitimate dependency in a location the loader searches before the legitimate DLL location, the malicious code will be loaded and executed by the application. This is a well‑known Windows attack vector and is frequently weaponized against desktop applications with complex dependency trees.
The specific Siemens issue​
Siemens reports that the affected components in Software Center and Solid Edge SE2025 perform DLL resolution in a way that allows an attacker with local file write or local access (or the ability to place files on shared storage paths) to influence which DLL is loaded. That means exploitation requires file placement and typically some user interaction (starting or launching the application), but does not require administrative privileges. The outcome can be arbitrary code execution under the context of the launched process — a high impact in engineering workstations that often have access to network shares, build tools, or OT management interfaces.
Verified severity and scoring​
Key technical scores and vectors were independently confirmed:
  • CVSS v3.1: 7.8 — vector: AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H.
  • CVSS v4.0: 8.5 — vector: AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N.
Those scores encode the following realities:
  • Attack vector: local (an attacker needs to place files locally or on accessible file shares).
  • Attack complexity: low — a single crafted DLL placed in the right spot can be sufficient.
  • User interaction: required — typically launching the affected app will load the malicious DLL.
  • Impact: high — confidentiality, integrity, and availability can be fully compromised once code runs.
Both vendor and independent tracking records (NVD, Tenable, CVE aggregators) reflect these scores and vectors, providing consistent cross‑validation of the risk level and exploitation prerequisites.
Who should be worried — threat model and attack scenarios​
This is not just an academic Windows desktop issue. The greatest risks arise where engineering/CAD workstations and supply‑chain file exchanges meet production or OT networks.
High‑risk profiles:
  • Design workstations and engineering laptops running Solid Edge that access shared project repositories.
  • Build servers or automation hosts that integrate with Solid Edge or Software Center as part of deployment or packaging workflows.
  • Environments that accept unvetted external CAD assets from suppliers, contractors, or customers.
  • Machines used for commissioning, firmware packaging, or other high‑privilege OT workflows (these desktops are often elevated and can be lateral pivot points).
Typical attack chains (examples)
  • Phishing or social engineering delivers a ZIP that contains a malicious DLL and a dropped launcher that causes an engineer to open Solid Edge from a folder containing the malicious DLL.
  • An adversary with a foothold on a corporate workstation or file‑share places a malicious DLL into a shared project folder that engineers mount and use. When a designer launches Solid Edge from that mapped drive, the malicious DLL is loaded.
  • A compromised contractor’s build artifact or plugin package contains a hijacking DLL that gets distributed to multiple customers during normal supply‑chain collaboration.
Because engineering files often travel across organizational boundaries, a single compromised asset can propagate widely — turning local access requirements into enterprise‑scale risk.
What Siemens and agencies say (official mitigations)​
Siemens has published SSA‑365596 describing the vulnerability, affected versions, and vendor remediation guidance; operators should treat Siemens ProductCERT as the canonical source for updates and fixed builds. CISA republished the advisory to raise visibility but notes it will not provide ongoing updates beyond the initial reposting — operators must rely on Siemens ProductCERT for patching status. CISA and Siemens’ short‑term mitigation guidance (summarized)
  • Patch to vendor‑released fixes where available (see the vendor advisory for exact builds).
  • Minimize network exposure: ensure affected hosts and control systems are not Internet‑accessible.
  • Isolate engineering networks behind firewalls and separate from general business networks.
  • Use secure remote access mechanisms (VPNs, bastion hosts, zero‑trust gateways) and keep them updated.
  • Do not open untrusted files (treat inbound CAD and installer content as potentially hostile).
  • Apply standard ICS/OT hygiene — segmentation, access control, monitoring, and incident reporting.
Note: the CISA reposting also reminds operators to perform impact analysis before deploying any countermeasures and to use Siemens ProductCERT for follow‑on advisories.
Immediate, practical actions for Windows and engineering teams​
Apply the following prioritized playbook now. Each step is actionable and ordered by urgency.
  • Inventory (within hours)
  • Locate every host running Siemens Software Center and Solid Edge SE2025; record exact build numbers and update state.
  • Identify network shares, file servers, and mailboxes that accept or store PRT/PRJ/installer files and temporary directories engineers commonly use.
  • Flag machines that perform elevated tasks (deployment, commissioning, controller programming).
  • Contain (immediate)
  • Block or quarantine inbound installer/PRT/PRJ/ZIP attachments from untrusted sources at mail gateways and gateway file scanners.
  • Enforce file‑type filtering and automated sandboxing/safe‑open for CAD files before exposing them to users.
  • Disallow running applications from user‑writable temporary locations; enforce that application executables are launched from trusted program folders.
  • Where feasible, require opening external CAD files only on isolated jump hosts or ephemeral VMs.
  • Patch (days)
  • Apply Siemens fixes: update Software Center to 3.5 or later and Solid Edge SE2025 to V225.0 Update 10 or later where Siemens has confirmed remedies. Always validate build numbers against the ProductCERT advisory before marking as remediated.
  • Hardening (days–weeks)
  • Reduce local privileges: run Solid Edge and Software Center under least‑privilege accounts and avoid administrator tokens for day‑to‑day engineering tasks.
  • Enforce application allowlists where possible (AppLocker, Windows Defender Application Control).
  • Disable legacy DLL search behaviors in custom automation and installers: call SetDefaultDllDirectories / LOAD_LIBRARY_SEARCH flags or use fully qualified DLL paths in code. Microsoft guidance documents best practices for controlling the DLL search order (SetDefaultDllDirectories, SetDllDirectory).
  • Detection & monitoring (ongoing)
  • Monitor for repeated application crashes, unexplained DLL loads, or new DLLs appearing in application folders.
  • Use EDR/endpoint telemetry to alert on suspicious child processes spawned by Solid Edge or Software Center, unusual network connections from these hosts, and file creation in program directories.
  • Preserve forensic artifacts (memory, triggering file, event logs) if exploitation is suspected.
  • Supply‑chain controls
  • Require cryptographic signatures, checksums, or vendor‑sanctioned packaging for third‑party libraries and plugin modules.
  • Sanitize inbound CAD files using Content Disarm & Reconstruction (CDR) or automated safe‑open workflows for high‑risk projects (defense, aerospace, critical infrastructure).
Hardening Windows against DLL hijacking — technical notes​
Windows offers process‑level APIs and registry controls that help mitigate search‑order hijacking. The vendor fix is the authoritative mitigation for this CVE, but hardening application behavior can reduce exposure in general.
  • Enable and respect Safe DLL Search Mode (enabled by default on modern Windows). Microsoft documents the dynamic‑link library search order and the effect of SafeDllSearchMode.
  • Applications should call SetDefaultDllDirectories with appropriate flags (for example, LOAD_LIBRARY_SEARCH_DEFAULT_DIRS) and, where needed, use AddDllDirectory to add explicit paths. These APIs remove the most vulnerable directories from the default search order, preventing unprivileged directories from being used to satisfy DLL loads.
  • For third‑party integrations and installer authors: always use fully qualified paths when calling LoadLibrary/LoadLibraryEx, or use LOAD_LIBRARY_SEARCH flags with LoadLibraryEx to restrict search directories.
These are engineering‑level mitigations for developers and packagers; administrators should insist that vendors and internal tool authors adopt them as a best practice.
Detection signatures, indicators, and forensic guidance​
Because DLL hijacking often leaves behavioral traces rather than clean static signatures, focus on telemetry and behavioral patterns:
  • Watch for new DLL files appearing in application directories or user‑writable locations with the same base names as legitimate dependencies.
  • Alert on process loads of DLLs that originate from non‑standard paths (temporary folders, user profile temp locations, network shares).
  • Detect and triage repeated application crashes immediately — many exploit attempts are preceded by crafted inputs causing crashes.
  • Monitor for abnormal outbound connections originating from CAD workstations after a file open (possible data exfiltration or C2).
  • Preserve the triggering file and volatile memory for analysis if exploitation is suspected; record the user session and any child processes.
EDR vendors may already ship detection rules for suspicious DLL loads and known DLL‑hijacking patterns; ensure those rules are enabled and tuned for engineering endpoints.
Risk tradeoffs and operational impact​
Strengths of the advisory and response
  • Siemens provided a focused advisory with product/version mapping and a vendor CVE assignment, which enables prioritized patching. Multiple independent trackers confirm the CVSS scoring and affected builds, which helps SOC and vulnerability management teams prioritize remediation.
Potential operational and security risks
  • The vulnerability’s requirement for local file placement can lull defenders into complacency; however, in engineering and OT contexts, local and shared‑drive access is common and can be easily abused. File‑exchange workflows and contractor collaboration frequently place untrusted binaries onto systems where designers will open them.
  • Many engineering environments constrain rapid patching for compatibility testing, third‑party plugins, or validated toolchains; those constraints lengthen the exposure window and demand stronger containment and monitoring.
Unverified or emerging claims to watch
  • As of the vendor advisory and public trackers’ latest updates, no confirmed public exploitation of CVE‑2025‑40827 has been reported. Public EPSS estimates and exploit feeds show very low exploitation probability at present, but public disclosure often increases attackers’ incentives to weaponize bugs rapidly. Treat the “no known exploitation” status as a snapshot, not a guarantee.
Recommended executive‑level checklist (one page)​
  • Patch policy: validate and deploy Siemens updates for Software Center (≥3.5) and Solid Edge SE2025 (≥V225.0 Update 10) according to testing windows.
  • Immediate containment: block untrusted CAD files at mail and gateway, enforce jump‑host opening for external files.
  • Inventory: produce an authoritative list of hosts running Siemens engineering software within 24 hours.
  • Least privilege: move engineers to non‑admin accounts; restrict installers to vetted admins.
  • Monitoring: enable EDR alerts for suspicious DLL loads and unusual child processes from CAD apps.
  • Supply‑chain: require signed/verified packages from contractors and vendors; implement CDR for high‑risk exchanges.
  • Incident readiness: prepare forensic preservation playbooks for engineering host compromise.
Final assessment​
CVE‑2025‑40827 is a classic but dangerous DLL‑search vulnerability that elevates operational exposure in environments where Windows CAD and packaging tools are core assets. The vulnerability’s high impact (arbitrary code execution) combined with low exploitation complexity makes it a priority for security teams that manage Solid Edge or Siemens Software Center installations. The vendor has released guidance, and fixed versions are identified; patching is the definitive remediation. Meanwhile, a layered defense — inventory, containment, least‑privilege, hardening DLL search behavior, and robust monitoring — will reduce the realistic risk of exploitation in mixed IT/OT environments. Validate every remediation against Siemens ProductCERT and treat CISA repostings as initial notifications rather than ongoing trackers.
Quick reference: what to update and where to look first​
  • Update Software Center to v3.5 or later.
  • Update Solid Edge SE2025 to V225.0 Update 10 or later.
  • Consult Siemens ProductCERT (SSA‑365596) for vendor‑specific instructions and CSAF/HTML feeds for automation. CISA’s republication is an initial alert only; use ProductCERT as the authoritative source.
Conclusion: act now to inventory and contain, apply the vendor updates after validation, harden DLL search behavior in toolchains, and monitor engineering endpoints. The risk is real, practical, and remediable — but only if engineering and security teams treat CAD toolchains with the same urgency as other critical Windows applications.
Source: CISA Siemens Software Center and Solid Edge | CISA
