- Thread Author
- #1
In XP with a single click on a folder's name expands the folder and shows it's sontent in the right pane. How to make this work in 7?
1. "Single-click" option in "Folder Options" just works for right pane but not for left.
2. "Automatically expand to current folder" doesn't work, there's no effect by activating or deactivating it.
3. When double-clicking the folder's name, the overview of the left pane drops down to the bottom (seems to be a known problem, which is not seen as a problem by everybody at all) even if "Show all folders" and "Automatically expand to current folder" are deactivated!
What works best is to click the small triangle left to the folder's name, but that's not what I like. The triangles are so small ao that they are often missed, when trying to click them. I remember I was doing some registry edits in XP a very long time ago to solve the similar issue. Anyone an idea if this would work for 7, too? Where in the registry should this be edited?
greets
greets
