sleep resume bsod win7 x64 help please.
i am including the minidump from the latest crash to see if i can get some help with this one, it is driving me nuts.
i put the pc to sleep at night and then when resumed in the morning i am either greeted with a smooth working desktop or a bsod. i am at my wits end trying to sort this out, so i will come and ask the experts.
View attachment 010612-24523-01.dmp View attachment 011012-26847-01.dmp
hope i have done this right.
Elmer
Hi Farscape247 and Welcome to The Forum.
STOP 0x0000007A: KERNEL_DATA_INPAGE_ERROR
Usual causes:
Memory, Paging file corruption, File system, Hard drive, Cabling, Virus infection, Improperly seated cards, BIOS, Bad motherboard, Missing Service Pack.
Your latest dump file lists ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Delete current paging file by setting system to "no paging file" reboot, Reset paging file, reboot.
Run chkdsk /f /r on your main system drive/partition.
AtiPcie.sys Tue May 05 16:00:22 2009 ATI PCIE Chipset Driver. Go to Mobo Mfr. or AMD. There's a March 2010 set here.
Download and run CPU-Z. Take screenshots**/snips of the Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
Bugcheck Analysis:
BugCheck 7A, {fffff6fb80000000, ffffffffc000009d, 9c2cf880, fffff70000000000}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+37bba )
Followup: MachineOwner
2: kd> !analyze -v
KERNEL_DATA_INPAGE_ERROR (7a)
The requested page of kernel data could not be read in. [COLOR=red][B] Typically caused by
a bad block in the paging file or disk controller error.[/B][/COLOR] Also see
KERNEL_STACK_INPAGE_ERROR.
If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185,
it means the disk subsystem has experienced a failure.
If the error status is 0xC000009A, then it means the request failed because
a filesystem failed to make forward progress.
Arguments:
Arg1: fffff6fb80000000, lock type that was held (value 1,2,3, or PTE address)
Arg2: ffffffffc000009d, error status (normally i/o status code)
Arg3: 000000009c2cf880, current process (virtual address for lock type 3, or PTE)
Arg4: fffff70000000000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
ERROR_CODE: (NTSTATUS) 0xc000009d - STATUS_DEVICE_NOT_CONNECTED
DISK_HARDWARE_ERROR: [COLOR=red][B]There was error with disk hardware[/B][/COLOR]
BUGCHECK_STR:  0x7a_c000009d
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  wininit.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff880033b1330 -- (.trap 0xfffff880033b1330)
rax=0000000000000000 rbx=0000000000000000 rcx=000000000000000e
rdx=fffff70000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030b7d18 rsp=fffff880033b14c0 rbp=0000000000008000
 r8=0000000000003fff  r9=fffff70000000ff8 r10=0000000000007fff
r11=0000000000007ff8 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz ac po nc
nt!RtlFindClearBits+0xa8:
fffff800`030b7d18 4c0b02          or      r8,qword ptr [rdx] ds:fffff700`00000000=00000000001570da
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80003100b52 to fffff8000308fc40
STACK_TEXT:
fffff880`033b1018 fffff800`03100b52 : 00000000`0000007a fffff6fb`80000000 ffffffff`c000009d 00000000`9c2cf880 : nt!KeBugCheckEx
fffff880`033b1020 fffff800`030b76cf : fffffa80`0a074010 fffff880`033b1190 fffffa80`09228e08 fffffa80`0a074010 : nt! ?? ::FNODOBFM::`string'+0x37bba
fffff880`033b1100 fffff800`0309e02a : 00000000`00000000 00000000`00000000 ffffffff`ffffffff fffffa80`0933f6e0 : nt!MiIssueHardFault+0x28b
fffff880`033b11d0 fffff800`0308dd6e : 00000000`00000000 fffff700`00000000 fffffa80`05201700 00000000`00000008 : nt!MmAccessFault+0x146a
fffff880`033b1330 fffff800`030b7d18 : 00000000`00000000 00000000`ffffffff 00000000`00000001 00000000`00000000 : nt!KiPageFault+0x16e
fffff880`033b14c0 fffff800`03382323 : 00000000`ffffffff fffff6fc`00000000 00000000`00000000 fffff800`0305fd9f : nt!RtlFindClearBits+0xa8
fffff880`033b1500 fffff800`0337e3c2 : ffffffff`ffffffff fffff880`033b1920 00000000`00000000 fffff683`fffffeb8 : nt!MiScanUserAddressSpace+0xdf
fffff880`033b1550 fffff800`0308eed3 : fffff880`033b1930 fffff800`0308de7d 00000000`00000000 000007ff`fffd7318 : nt!NtSetInformationProcess+0x375
fffff880`033b18a0 fffff800`0308b470 : fffff800`0337dcce 00000000`00000000 00000000`ff4500e8 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
fffff880`033b1a38 fffff800`0337dcce : 00000000`00000000 00000000`ff4500e8 00000000`00000000 fffffa80`06ca6c00 : nt!KiServiceLinkage
fffff880`033b1a40 fffff800`0337c2fd : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00001000 : nt!RtlCreateUserStack+0x122
fffff880`033b1b30 fffff800`0337bf2e : fffffa80`09228a70 fffff880`033b2998 fffffa80`06ca6d00 fffff880`033b2580 : nt!PspAllocateThread+0x299
fffff880`033b1d50 fffff800`0337fe35 : 00000000`00000000 00000000`00000000 00000000`00000001 fffff880`033b2580 : nt!PspCreateThread+0x1d2
fffff880`033b1fd0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtCreateThreadEx+0x25d
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`03100b52 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+37bba
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aaa3
FAILURE_BUCKET_ID:  X64_0x7a_c000009d_nt!_??_::FNODOBFM::_string_+37bba
Drivers:
fffff880`00ebd000 fffff880`00f14000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`02c34000 fffff880`02cbd000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`13010000 fffff880`13026000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`03f0e000 fffff880`03f23000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00e68000 fffff880`00e7c000   amdsata  amdsata.sys  Wed Apr 29 00:33:25 2009 (49F79245)
fffff880`01116000 fffff880`01121000   amdxata  amdxata.sys  Wed Apr 29 00:33:27 2009 (49F79247)
fffff880`03ee0000 fffff880`03ee8000   AppleCharger AppleCharger.sys Wed Nov 02 02:46:00 2011 (4EB0AEE8)
fffff880`06198000 fffff880`061a3000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00e2a000 fffff880`00e33000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e33000 fffff880`00e5d000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01630000 fffff880`01638000   AtiPcie  AtiPcie.sys  Tue May 05 16:00:22 2009 (4A005486)
fffff960`00830000 fffff960`00891000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`01680000 fffff880`01687000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03ecf000 fffff880`03ee0000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0395b000 fffff880`03979000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00650000 fffff960`00677000   cdd      cdd.dll      unavailable (00000000)
fffff880`05c82000 fffff880`05c9f000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`0148b000 fffff880`014b5000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d39000 fffff880`00df9000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01600000 fffff880`01630000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cdb000 fffff880`00d39000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01072000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`13000000 fffff880`13010000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05c9f000 fffff880`05cad000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03e2e000 fffff880`03eb1000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`03eb1000 fffff880`03ecf000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`02de3000 fffff880`02df2000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`019ce000 fffff880`019e4000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05330000 fffff880`05352000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05fe8000 fffff880`05ffc000   dump_amdsata dump_amdsata.sys Wed Apr 29 00:33:25 2009 (49F79245)
fffff880`05cad000 fffff880`05cb7000   dump_diskdump dump_diskdump.sys Fri Apr 22 21:04:32 2011 (4DB1DF50)
fffff880`05358000 fffff880`0536b000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05fce000 fffff880`05fda000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`044e9000 fffff880`045dd000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04400000 fffff880`04446000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`02dd7000 fffff880`02de3000   ElbyCDIO ElbyCDIO.sys Thu Dec 16 22:58:13 2010 (4D0A9985)
fffff880`0608c000 fffff880`060c2000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`0116d000 fffff880`01181000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01121000 fffff880`0116d000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`013de000 fffff880`013e8000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01994000 fffff880`019ce000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01891000 fffff880`018db000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`035fc000 fffff800`03645000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04446000 fffff880`0446a000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`05c00000 fffff880`05c19000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05c19000 fffff880`05c21080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05fda000 fffff880`05fe8000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`03892000 fffff880`0395b000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0198b000 fffff880`01994000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`045dd000 fffff880`045fb000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03f2c000 fffff880`03f3b000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05c22000 fffff880`05c30000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bcf000 fffff800`00bd9000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`03f79000 fffff880`03fbc000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013b2000 fffff880`013cd000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`05352000 fffff880`05357200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`0536b000 fffff880`05380000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05c3e000 fffff880`05c61000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cba000 fffff880`00cc7000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`05c30000 fffff880`05c3e000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`13df1000 fffff880`13e00000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`00e10000 fffff880`00e2a000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`014b5000 fffff880`014e6000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`05557000 fffff880`05567000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`03979000 fffff880`03991000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`03991000 fffff880`039be000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`03800000 fffff880`0384e000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0384e000 fffff880`03872000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00e5d000 fffff880`00e68000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`013e8000 fffff880`013f3000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f1d000 fffff880`00f27000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01181000 fffff880`011df000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`02dcc000 fffff880`02dd7000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01979000 fffff880`0198b000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014f2000 fffff880`015e5000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`1304a000 fffff880`13056000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`13056000 fffff880`13085000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`052b1000 fffff880`052c6000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`02d31000 fffff880`02d40000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02cbd000 fffff880`02d02000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`06180000 fffff880`06198000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`01097000 fffff880`010a8000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02dc0000 fffff880`02dcc000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03013000 fffff800`035fc000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`0120f000 fffff880`013b2000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01677000 fffff880`01680000   Null     Null.SYS     unavailable (00000000)
fffff880`052c6000 fffff880`052f3000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`130ed000 fffff880`13d64000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`02d0b000 fffff880`02d31000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f67000 fffff880`00f7c000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f27000 fffff880`00f5a000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fed000 fffff880`00ff4000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e00000 fffff880`00e10000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013cd000 fffff880`013de000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`05463000 fffff880`05509000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`052f3000 fffff880`05330000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cc7000 fffff880`00cdb000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`13026000 fffff880`1304a000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`13085000 fffff880`130a0000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`130a0000 fffff880`130c1000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`130c1000 fffff880`130db000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02d6f000 fffff880`02dc0000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`130db000 fffff880`130e6000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`019f2000 fffff880`019fb000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015f5000 fffff880`015fe000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`014e6000 fffff880`014ef000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0193f000 fffff880`01979000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05380000 fffff880`05398000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`13d64000 fffff880`13df1000   Rt64win7 Rt64win7.sys Tue Aug 23 14:55:41 2011 (4E53B15D)
fffff880`05cc7000 fffff880`05faec00   RTKVHD64 RTKVHD64.sys Fri Aug 12 06:28:04 2011 (4E44B9E4)
fffff880`03f4a000 fffff880`03f79000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`05509000 fffff880`05514000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01937000 fffff880`0193f000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`060e8000 fffff880`06180000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`05567000 fffff880`055d0000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`05514000 fffff880`05545000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`010b3000 fffff880`01116000   storport storport.sys Fri Mar 11 04:30:23 2011 (4D79A55F)
fffff880`045fb000 fffff880`045fc480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0168d000 fffff880`01891000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`05545000 fffff880`05557000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`013f3000 fffff880`01400000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`00e7c000 fffff880`00e9e000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`02d5b000 fffff880`02d6f000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00430000 fffff960`0043a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03ee8000 fffff880`03f0e000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`06000000 fffff880`06055000   udfs     udfs.sys     Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`03fbc000 fffff880`03fce000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05faf000 fffff880`05fcc000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`05fcc000 fffff880`05fcdf00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`044d7000 fffff880`044e8000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`044cb000 fffff880`044d7000   usbfilter usbfilter.sys Fri Apr 03 12:39:51 2009 (49D5F587)
fffff880`05257000 fffff880`052b1000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`0446a000 fffff880`04475000   usbohci  usbohci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`04475000 fffff880`044cb000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`03f3b000 fffff880`03f4a000   VClone   VClone.sys   Sat Jan 15 16:21:04 2011 (4D31C970)
fffff880`00f5a000 fffff880`00f67000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`019e4000 fffff880`019f2000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01072000 fffff880`01097000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`018db000 fffff880`018eb000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`00f7c000 fffff880`00f91000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00f91000 fffff880`00fed000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`018eb000 fffff880`01937000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`02d40000 fffff880`02d5b000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`015e5000 fffff880`015f5000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ca4000 fffff880`00cb3000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02d02000 fffff880`02d0b000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a4000   win32k   win32k.sys   unavailable (00000000)
fffff880`03f23000 fffff880`03f2c000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f14000 fffff880`00f1d000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05c61000 fffff880`05c82000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`06068000 fffff880`06072000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`06072000 fffff880`06086000   hiber_amdsat
    Checksum:  00000000
    ImageSize:  00014000
fffff880`060c2000 fffff880`060d5000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`061d4000 fffff880`061de000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`061de000 fffff880`061f2000   hiber_amdsat
    Checksum:  00000000
    ImageSize:  00014000
fffff880`06055000 fffff880`06068000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`061a3000 fffff880`061d4000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`06055000 fffff880`06070000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
    Checksum:  00000000
    ImageSize:  00031000
fffff880`060c2000 fffff880`060dd000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
    Checksum:  00000000
    ImageSize:  0000A000
    Checksum:  00000000
    ImageSize:  00014000
fffff880`061d4000 fffff880`061e7000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  0000A000
    Checksum:  00000000
    ImageSize:  00014000
    Checksum:  00000000
    ImageSize:  00013000
fffff880`070f0000 fffff880`07161000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06066000 fffff880`06072000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06055000 fffff880`06066000   usbscan.sys
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  00031000
fffff880`06071000 fffff880`0608c000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`06000000 fffff880`06071000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01638000 fffff880`01646000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01646000 fffff880`01650000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01650000 fffff880`01664000   dump_amdsata
    Checksum:  00000000
    ImageSize:  00014000
fffff880`01664000 fffff880`01677000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
here are the screen shots for you.
i also cleared the page file and updated the driver.
i have also included mainboard, cpu and gpu.
i have also run a full scan disk including surface check and there were no errors, but i have noticed something when shutting down or restarting, when about to shut down, the hdd's start spining up then down then up then down then it shuts down. when botting up, at the post screen the drives start up one by one then the pc boots normally.
i have 3x 1TB seagate barracuda 7200 drive installed.
i think i found the problem, the latest sata driver was causing read write errors on the drive, i backed up, downloaded seatool's and completely wiped the drive, then re installed win7 without any issues. the spin down and spin up on shutdown has gone away.
all seems fine now, thanks for your help anyway.
Elmer
Glad you got your problem sorted and Thanks for returning to update on how you resolved the issue.
Thanks for joining our community. We hope to continue to see you around.
