To disable the sound effects in Solitaire while moving cards, you can follow these steps: 1. Open Solitaire Settings: - Launch the Solitaire game on your Windows computer. 2. Access Game Settings: - Look for a settings or options menu within the game interface. This option is typically represented by a gear icon or labeled as "Settings." 3. Locate Sound Settings: - Once in the settings menu, find the sound settings section. It might be under an audio or sound tab. 4. Disable Sound Effects: - Look for an option to toggle off sound effects specifically related to card movement or game actions. It could be labeled as "Game Sounds," "Sound Effects," or something similar. 5. Save Changes: - After turning off the...
