Windows 7 Sound lagging shortly when CPU is in use
You might still like to check it out:
Link Removed - Invalid URL[/URL]
This SMC Firmware update adjusts the fan behavior in MacBook Pro systems (15-inch and 17-inch) when running under high workload conditions.
[URL=\"http://support.apple.com/downloads/MacBook_Pro_SMC_Firmware_Update_1_3\"]MacBook Pro SMC Firmware Update 1.3[/URL]
I've installed drivers for the co-processor, thx for the help, but it seems like the sound problem persists...
Regarding the driver, it's for OS X I think, since the file ends in .dmg.
One problem solved, still the sound issue to go... :(
I still think the AC 97 drivers might work, since under the specs it said "Mode: AC 97".
There are so many different versions of the AC 97 drivers.
Could you give me a more detailed description?
I meant the driver for Vista 64-bit, the one that could pass Windows digital signature test.
You have to uninstall the previous drivers by going to Control panel > Device Manager,
Reboot and try the install again.
Top Bottom
