Windows 7 Sounds not Working!
SansCowz
I, Recently upgrade to Windows 10 And I've seen technical issues with it.
So I Downgrade to Windows 7 And The Update was Very fine I've tested it.
But My Volume Won't Speak up Anymore I Tried Anything Nothing works
Here's I Tested
-Updating Sound Video and game controllers
-Setting my Headphones and speaker to Default
-Highs Up My Volume
-Checks the Volume Services
The Issues Has Not been Fixed Scene 1 week
So If anyone Knows the Issue.
I Really Appreciate it.
Thank you!.
Hi SansCowz. Thank you for posting that screenshot for SPECCY it helps tremendously. Going to the download page for drivers for your mainboard I don't see anything at all listed for your audio solution (VIA) for Windows 10. Just onboard LAN and not much else .You have the VIA VT1708 Audio controller. I found updated Windows 10 drivers here.
Direct Link VIAArena download Windows 10 VIA VT1708
Hi @SansCowz! Can you be a little more specific?? It might help other members to know exactly what you did to fix your sound problems.
Did you get a driver from the Biostar site?? Was it for W7?
Thanks!
Try removing and reinstalling the sound driver as shown below :--
An image from 'Sounds not Working!'. Steps showing how to update or uninstall a device driver via Device Manager in Windows.
Then
Hi! @Joseph Gargery . Welcome to the forum! Nice screen shots and good information for installing a driver from devise manager!
That procedure works well, but will install the latest windows drivers and that may not be the best and most recent driver.
The best place to get drivers is from the manufacture of your PC or from the Mother Board!;)
PS I don't think the OP has said for sure how their issue was solved. From their reply, it would seem that that they probably down loaded the driver from Biostar. OP had said that installing from devise manager didn't work for them. I'm of course assuming this. The OP however said that Biostar fixed it.:D It's all good that the issue has been solved and the team effort worked again.:up:
