Windows 7 Spdif Issue
snoopy12533
Don't think i can call it a problem, more of an annoyance. I have installed the new 64 bit drivers from realtek for windows 7 and for some reason the spdif output is only activated when a sound is played, so whatever sound is played gets the begging cut off. Never had this problem with XP.
ah yea, i know what you mean. But I never had the problem of it cutting off the beginning.
What do you have the digital output hooked up on? An Amp? What brand, etc..
It's possible the Amp is just a little slow?
I have used it on two different receivers a denon AVR-589 and a sony STR-DE545. It only started when using windows 7 and the new drivers from realtek. Windows Xp Did not have the problem
