Speed Up Windows Startup: Four Reliable Auto Start Tricks
Hidden startup apps are one of the easiest causes of sluggish boots — and also one of the easiest to fix if you know where Windows hides them and what tools to use. In this practical, step‑by‑step feature we walk through four reliable ways to detect and stop hidden apps that slow Windows startup: the built‑in Task Manager, the Startup folders and Settings, the Registry’s autostart keys (including the hidden StartupApproved values), and Microsoft’s Sysinternals Autoruns utility. Each method is explained, verified against official documentation and independent tooling, and paired with clear safety checks so you can speed up Windows startup without breaking anything important.
Blue-toned UI mockups of Windows Task Manager, Registry Editor, and Autoruns.Background / Overview​
Windows allows programs to register themselves to run automatically at sign‑in or at system boot through multiple, overlapping mechanisms. Common entry points include the per‑user and machine Run keys in the Registry, shortcuts in the Startup folders, scheduled tasks, services, and other, more obscure hooks. Task Manager and Settings show a friendly surface view, but many autostarts live deeper in the system — which is why deeper inspection tools and the Registry matter for a full cleanup.
Microsoft’s Task Manager measures startup “impact” using CPU and disk usage metrics to help prioritize what to disable, and the OS tracks the approval/enabled state of many startup entries in the StartupApproved keys. For a complete audit, Autoruns from Sysinternals enumerates every autostart location Windows supports and is widely recommended by sysadmins and security professionals. These behaviors and locations are documented by Microsoft and corroborated by independent technical sources and community testing, which we’ll reference as we go.
1. Use Task Manager — the fast, safe first pass​
What Task Manager shows and why it matters​
Task Manager’s Startup tab is the safest place to begin. It lists apps that register themselves to start with your user session, shows whether they’re enabled or disabled, and reports a measured Startup impact (Low / Medium / High) based on the app’s CPU and disk usage during startup. Microsoft defines those thresholds so you can objectively prioritize the heavy hitters: High impact indicates an app used more than 1 second of CPU or more than ~3 MB of disk I/O at startup.
How to use it (quick steps)​
  • Press Ctrl + Shift + Esc to open Task Manager (or right‑click the Taskbar → Task Manager).
  • If Task Manager opens in compact mode, click “More details.”
  • Select the Startup tab and click the “Startup impact” column header to sort by impact.
  • Right‑click any nonessential, high‑impact item and choose Disable.
  • Reboot and verify improved responsiveness; re‑enable any app if you discover it’s needed.
Why start here​
  • It’s reversible and safe — disabling doesn’t uninstall the app, it only prevents auto‑launch.
  • Task Manager measures real runtime impact, so you can see what really slows boot.
  • For most users, disabling a handful of high‑impact cloud syncers, chat clients, or vendor updaters yields the largest, quickest gains.
Caveats and safety notes​
  • Don’t disable security or backup clients unless you have an alternative — those protect your system.
  • Some apps re-add themselves to startup after updates; re-check periodically.
2. Check Startup folders and the Settings UI — remove obvious shortcuts​
Per‑user and all‑users Startup folders​
Some apps use the classic Startup folders to auto‑launch. Windows exposes two shell shortcuts:
  • shell:startup — per‑user Startup folder (%AppData%\Microsoft\Windows\Start Menu\Programs\Startup)
  • shell:common startup — machine‑wide Startup folder (all users)
Open the Run dialog (Win + R), paste one of the commands above, and delete any shortcut you don’t want to start automatically. Microsoft documents these shell links and the folder locations; they remain a straightforward, visible place to remove autostart shortcuts.
The Settings → Apps → Startup panel​
Windows 10 and Windows 11 offer a Settings page (Settings → Apps → Startup) with toggles for many apps. This view complements Task Manager and sometimes gives additional context for Universal (Store) apps. Use it to flip off toggles for apps you don’t need immediately after login.
Practical checklist​
  • Open shell:startup and shell:common startup and remove stray shortcuts.
  • Open Settings → Apps → Startup and switch off nonessential toggles.
  • Reboot and test — this is low risk and easy to revert.
Common quirks​
  • On a few systems the shell:startup command can behave oddly if folder names are corrupted; if shell:startup fails, navigate manually to %AppData%\Microsoft\Windows\Start Menu\Programs\Startup. There are known, machine‑specific oddities reported in community forums; check folder names with dir /a in a Command Prompt if you encounter problems.
3. Inspect and edit the Registry — where hidden autostarts hide​
Why the Registry matters​
Many programs register autostarts directly in Registry Run keys that never appear in the Startup folder or sometimes even in Task Manager. The classic locations are:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run (per user)
  • HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run (machine)
Windows also keeps a parallel set of keys under Explorer\StartupApproved that record whether each Run entry is enabled (the “approved” status), allowing the OS to track changes made through Task Manager/Settings. That “StartupApproved” area is where the system stores enable/disable metadata for Run entries.
How the StartupApproved values work (what to watch for)​
The StartupApproved values are binary blobs; community analysis shows specific leading bytes indicate enabled vs. disabled states. For example, values beginning with 02 (or sometimes 06) typically indicate the entry is enabled; values starting with 03 (or otherwise timestamped) indicate disabled. Modifying those bytes can flip an entry between enabled and disabled, but the format is undocumented and brittle to edit manually, so proceed with caution and always back up the Registry key first. Independent analyses of these keys confirm this pattern.
Safe, step‑by‑step Registry auditing​
  • Create a System Restore point (recommended).
  • Press Win + R, type regedit and press Enter to open Registry Editor.
  • Back up any key before editing: select the key → File → Export → save .reg file.
  • Inspect these keys for Run entries:
  • To reflect Task Manager’s enable/disable semantics, check:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run
  • If you find an unwanted value under Run, you can either delete the Run value (removes the autostart entirely) or change the corresponding StartupApproved blob to mark it disabled — but prefer deleting the Run value for clarity unless you understand the binary format.
What to avoid​
  • Don’t edit Registry keys unless you’re comfortable restoring them — an incorrect change can break login, driver loads, or security tools.
  • Instead of manually fiddling with StartupApproved blobs, use Task Manager or Autoruns (next section) to safely disable entries. If you must edit, export the key so you can import it back.
4. Download and run Autoruns — the deep audit (recommended for power users)​
What Autoruns does​
Autoruns (Sysinternals / Microsoft) enumerates every autostart location Windows supports: Run keys, RunOnce, services, scheduled tasks, Explorer shell extensions, AppInit DLLs, Winlogon notifications, drivers, and more. It’s the most comprehensive autostart scanner available and exposes hidden entries that Task Manager and Settings do not show. The tool runs without installation — just unzip and run the EXE as Administrator.
How to use Autoruns safely​
  • Download Autoruns from the official Sysinternals page and extract it. Run Autoruns64.exe as Administrator.
  • Let it populate; then click the Logon and Scheduled Tasks tabs to inspect autostarts.
  • Enable Hide Microsoft entries to reduce noise and focus on third‑party items.
  • To stop an entry, uncheck its box — this disables it without deleting the configuration (safer).
  • Reboot and confirm behavior. If something breaks, re‑check the entry to restore it.
Autoruns also gives file properties, digital signature checks, and an option to submit unknown files to VirusTotal (useful for spotting malicious persistence). The tool’s author and documentation emphasize unchecking (disabling) items rather than deleting them so changes are reversible.
Why Autoruns is the go‑to tool​
  • It finds scheduled tasks and driver hooks that other UIs don’t show.
  • It’s created by the Sysinternals team (Mark Russinovich) and maintained by Microsoft.
  • It provides context (file path, publisher) so you can verify whether an entry is legitimate or not.
Safety checklist​
  • Uncheck (disable) instead of delete unless you’re certain.
  • Research unknown entries before disabling critical components (drivers, security software).
  • If you see entries that look malicious or suspicious, quarantine the files for offline scanning or use your AV/Sandbox workflow.
Measuring improvements: prove what you changed​
Anecdotal “it feels faster” is useful, but objective metrics help you confirm which change produced the largest effect.
  • Event Viewer — Diagnostics‑Performance / Operational logs: Event ID 100 reports Boot Duration in milliseconds. Use it to compare before/after averages across several reboots. Note: some Windows builds and configurations may vary in which event details are recorded; use multiple samples.
  • BootRacer or similar third‑party timing tools give user‑centric usable‑desktop times.
  • For repeatable testing: record three cold boots before changes, average them; then make one change, reboot three times, and compare averages. This isolates the effect of each tweak. Community testing and admin guidance recommend this staged approach.
Extra tactics and complementary tips​
  • Trim unnecessary services (services.msc) — set nonessential third‑party services to Manual after verifying their function. Do not disable security, update, or core OS services.
  • Clean up storage (Storage Sense, Disk Cleanup): low free space and bloated temp folders slow startup on some systems. Run Storage Sense and clean system files to reclaim space.
  • Firmware/UEFI: move the boot drive to the top of the boot order and enable UEFI Fast Boot or Boot Optimization if available — this shortens pre‑Windows firmware enumeration. Be aware firmware Fast Boot can skip device initialization and make USB booting trickier.
  • Consider hardware: if you’re still slow after software tuning, an SSD (especially NVMe) is the single biggest upgrade to reduce boot time. Community testing shows HDD→SSD yields the largest real‑world improvement.
Risks, trade‑offs, and what can go wrong​
  • Disabling security or backup autostarts can leave you unprotected. Always confirm the role of an entry before disabling it.
  • Registry edits are powerful but dangerous. Mistakes can produce login failures or driver problems. Back up keys and create a restore point first.
  • Fast Startup (hybrid shutdown) shortens shutdown→power‑on cycles but can complicate dual‑boot setups, BitLocker recovery, or firmware updates. Use it only if it matches your workflow.
  • Autoruns will show many entries; indiscriminate deletion can break things. Use the “Hide Microsoft entries” filter and disable entries first to test effects.
  • Some claims online (for example, precise seconds saved by disabling a particular app on another person’s machine) are anecdotal — treat them as case studies, not universal guarantees. An app that costs one user 20 seconds might cost another user one second, depending on hardware and configuration. Flag unverified, single‑system claims accordingly.
Putting it into a safe, 15‑minute workflow​
  • Create a System Restore point.
  • Run Task Manager → Startup; disable obvious High impact nonessential apps. Reboot and record Event ID 100 or BootRacer time.
  • Open Settings → Apps → Startup and toggle off anything you just disabled via Task Manager if present (consistency).
  • Open shell:startup and shell:common startup; remove stale shortcuts. Reboot and re‑measure.
  • Run Autoruns as Administrator, enable “Hide Microsoft entries,” and uncheck clearly unwanted third‑party autostarts (don’t delete). Reboot and re‑measure.
  • If you still see unexplained autostarts, inspect Registry Run keys and StartupApproved values — export keys, then remove Run entries rather than editing binary blobs whenever possible. Reboot and verify.
Final analysis — strengths and practical trade‑offs​
  • Strengths: The combination of Task Manager, Settings, Startup folders, Registry checks, and Autoruns gives a layered, low‑risk path from quick wins to deep cleanups. Task Manager and Settings deliver immediate, user‑friendly improvements; Autoruns and Registry inspection expose hidden persistence that otherwise evades detection. Community and Microsoft documentation align on these locations and methods, and using objective boot metrics reveals which steps actually matter on your hardware.
  • Trade‑offs: Deeper actions carry more risk. Registry edits and service changes should be approached methodically. Autoruns exposes powerful options — but with power comes responsibility: disable, don’t delete, until you’ve confirmed stability. Firmware and Fast Startup changes deliver firmware‑level speedups but can complicate multi‑OS workflows or recovery procedures.
  • The practical result: Most users will see their biggest, safest gains by disabling a handful of high‑impact startup apps and cleaning the Startup folders. For curious power users and IT admins, Autoruns and Registry audits complete the job and reveal hidden scheduled tasks or drivers that silently slow boot or provide persistence.
Keeping a lean startup list is low cost and high reward. Start with Task Manager and Settings, then graduate to Startup folders and Autoruns if you want to eliminate every stray launcher. Back up before you edit the Registry, document changes, and measure with event logs or BootRacer so you know which tweaks actually shortened boot time on your PC. Follow these steps and you’ll reclaim seconds — and sometimes tens of seconds — from Windows startup without sacrificing reliability.
Source: How-To Geek 4 ways to detect and stop hidden apps that slow down Windows startup
