Windows 7 Start Menu
barsim
Active Member
Tried to customize the Start menu, but the Right click is not possible (the selection box simply doesn'show up), either at the Jump or Start program list.
Everywhere else is possible though.
What is the solution?
Thanks
barsim
barsim
Active Member
I've discovered a better solution that doesn't change the look into Classic.
Right click the StART button then Properties and select Default in the Start menu tab.
barsim
Top Bottom
