Microsoft announced the Surface RTX Spark Dev Box on June 2, 2026, at Microsoft Build in San Francisco as a compact Windows 11 Pro developer workstation powered by Nvidia’s RTX Spark superchip, 128GB of unified memory, and up to one petaflop of advertised AI compute. The device is not another Surface mini PC for the living room or a nostalgia play for the old Windows Dev Kit era. It is Microsoft’s clearest signal yet that the company wants Windows to become the default workbench for local AI development, not merely the client that calls models running somewhere else. The bet is simple, expensive, and very Microsoft: if developers are going to build agents, Microsoft wants the operating system, the tooling, the identity layer, and the hardware box all sitting on the same desk.
For the last several years, Microsoft’s AI story has been overwhelmingly cloud-shaped. Azure supplied the GPUs, GitHub Copilot supplied the developer wedge, and Windows increasingly became the surface on which cloud-backed intelligence appeared. The Surface RTX Spark Dev Box complicates that story in a useful way: Microsoft is now admitting that not every AI development loop belongs in the cloud.
That is not a retreat from Azure. It is a rebalancing of the development workflow. The new box is pitched for prototyping, fine-tuning, inference, agentic pipelines, and model experimentation that can happen locally before the heavy production work moves to cloud infrastructure.
The economics are obvious to anyone who has watched a team burn through hosted inference credits while debugging prompts, evaluating model behavior, or iterating on retrieval pipelines. A local workstation cannot replace frontier-scale training clusters, but it can make the everyday loop less metered. Microsoft’s message is that developers should stop treating every token as a billable event.
That makes the Dev Box interesting even before price enters the conversation. Microsoft has not made this a general-purpose Surface desktop first and an AI box second. It is a developer appliance, and the appliance exists because local AI work has become too large for ordinary PCs and too frequent to leave entirely to cloud meters.
The important number is not only the petaflop claim, which comes with the usual theoretical-performance caveats. The important number is 128GB. Local AI development is increasingly constrained less by raw enthusiasm and more by memory ceilings, especially when developers want to test larger open models, run multiple agents, or keep long context available without compressing everything into toy demos.
Unified memory also changes the Windows workstation conversation. Traditional desktop GPUs have lived behind the boundary of VRAM capacity. When the GPU runs out of memory, the experience gets ugly fast. A 128GB shared pool does not magically make all workloads fast, but it gives developers a far wider local sandbox than a conventional consumer GPU configuration.
This is where Microsoft’s Surface branding matters. Surface has long been the company’s design argument for what Windows hardware should look like. In this case, the argument is not a hinge, a pen, or a detachable keyboard. It is that the next premium Windows developer machine should be built around Nvidia’s AI stack rather than Intel’s or AMD’s familiar workstation grammar.
That detail matters because AI workstations fail or succeed on sustained behavior, not launch-event arithmetic. A machine that can briefly hit impressive numbers and then throttle through a multi-hour fine-tune is a demo prop. Microsoft is explicitly trying to position this as a desk appliance for long jobs, where thermals, acoustics, drivers, and stability matter as much as the silicon logo.
The port selection is practical rather than flashy: USB-C, USB-A, HDMI, Ethernet, and a headphone jack. That reads like Microsoft remembering that developers attach old peripherals, lab gear, displays, KVMs, external storage, and whatever else happens to be in the office. A developer box that requires a dongle nest on day one has already lost part of the argument.
Still, Microsoft’s design language is doing brand work here. The company could have let Nvidia and OEM partners carry the desktop Spark story. Instead, Surface is putting a first-party object on the table, which tells developers and OEMs alike that this category is not being left to reference designs alone.
That changes the software compatibility question. Developers are not merely browsing, writing documents, and running Electron apps. They are compiling dependencies, invoking Python packages, moving between Windows and WSL, using CUDA, testing frameworks, loading models, and relying on command-line tools that may have uneven Arm support.
Microsoft appears aware of this. The Dev Box ships with a developer-optimized Windows 11 Pro image that includes Visual Studio Code, GitHub Copilot in Windows Terminal, WSL, PowerShell 7, Git, Python, Node.js, and GPU passthrough with CUDA support under WSL 2. Developer Mode is enabled, PowerShell 7 is the default shell, and Microsoft says the Windows image is tuned so the machine starts in a development posture rather than a consumer PC posture.
That preconfiguration is more than convenience. It is an attempt to reduce the first-week friction that can poison a new architecture. If Microsoft wants developers to treat RTX Spark as a practical workstation platform, the out-of-box experience cannot involve a scavenger hunt through drivers, preview runtimes, package incompatibilities, and half-documented WSL tweaks.
That admission is welcome. Windows has become a strong developer platform in part because of WSL, VS Code, Windows Terminal, PowerToys, package managers, and cross-platform runtimes. But those pieces have often arrived as a kit the developer assembles after buying a normal PC. The Dev Box turns that kit into the default state.
There is a subtle strategic move in that packaging. Microsoft is not just competing with Mac Studio-class hardware or Linux workstations. It is competing with the developer’s mental model of what a clean AI workstation should feel like. Apple wins some developer loyalty by making the hardware-software boundary feel quiet. Linux wins by being close to the metal and the server. Microsoft is trying to thread the gap: Windows as the managed desktop, WSL as the Linux-adjacent workspace, CUDA as the accelerator layer, and Azure or Foundry as the scale-out path.
That will only work if the abstraction holds under pressure. Developers are forgiving of rough edges when they choose a tinkering platform. They are less forgiving when a vendor sells an integrated workstation and promises day-one productivity.
But the comparison breaks down quickly. Apple’s advantage is vertical integration: macOS, Apple Silicon, developer tools, media engines, and hardware design all come from one company. Microsoft’s version is more federated. Windows comes from Microsoft, the accelerator stack comes from Nvidia, the CPU architecture is Arm-based, the Linux compatibility story runs through WSL, and much of the AI developer ecosystem is open-source or cloud-linked.
That federation is a weakness when compatibility gets messy. It is a strength when developers need CUDA, existing Nvidia tooling, cross-platform frameworks, enterprise identity, and a path from local prototypes into Microsoft’s cloud services. The Dev Box is not trying to be an elegant sealed creative appliance in the Apple mold. It is trying to be a compact node in a larger Windows-Nvidia-Azure development fabric.
The real competitive target may be less the Mac Studio than the growing habit of serious AI developers assembling ad hoc local rigs with high-memory GPUs, Linux installs, and a tolerance for noise, heat, and weirdness. Microsoft is asking whether some of those developers would rather buy an integrated, manageable, secure Windows workstation with a vendor-supported stack.
That matters because AI development has created a new shadow-IT problem. Developers want capable models and fast iteration, but the easiest path often involves sending prompts, embeddings, documents, traces, and test data to hosted services. Enterprises then face the familiar question in a new form: where did the data go, who processed it, and what policies applied?
A local workstation does not solve governance by itself. It can still leak data through bad tooling, insecure agents, careless sync, or cloud-connected extensions. But it gives IT departments a more familiar control surface. Identity, device management, encryption, endpoint protection, and policy enforcement are all things Windows shops already understand.
This is where the Dev Box becomes more than a toy for AI hobbyists. Microsoft is making a pitch to enterprises that want developers to use modern AI workflows without turning every experiment into a procurement exception or compliance review. If the box can be enrolled, managed, encrypted, monitored, and updated like other Windows hardware, local AI becomes easier to authorize.
That phrase, hybrid compute, is doing a lot of work. In Microsoft’s version, cloud agents can plan and delegate, while smaller local models handle tasks that do not require frontier-scale intelligence. A coding agent might use cloud reasoning for the high-level plan and a local model for subtasks, reducing latency and cost while keeping some work on the device.
This is the most ambitious reading of the Dev Box. It is not simply a machine for developers who want to run large language models under their desks. It is a proving ground for a Windows architecture where the PC becomes an active participant in AI workflows again. After years of PCs being thin clients for increasingly powerful services, Microsoft and Nvidia want the endpoint to matter.
The risk is that the agent story runs ahead of user trust. Giving local agents access to files, apps, terminals, and development environments raises obvious safety questions. Microsoft and Nvidia can talk about containment, identity, policy, and user control, but developers and admins will judge the platform by failure modes, not keynote vocabulary.
If the Dev Box lands at a workstation-class but defensible price, it could become a credible standard machine for AI teams, research groups, advanced developers, and enterprise labs. If it arrives as a prestige object priced well beyond comparable DIY or OEM options, it risks becoming a symbol rather than a platform.
The comparison set will be unforgiving. Developers will look at high-end Nvidia desktop GPUs, Mac Studio configurations, used server cards, cloud GPU rates, OEM Spark desktops, and whatever Nvidia’s own DGX Spark machines cost by the time Microsoft ships. The question will not be whether the Surface box is powerful. It will be whether the integrated Windows experience, compact design, support story, and security posture justify any premium.
Microsoft also has to avoid the ghost of earlier developer hardware experiments. The Windows Dev Kit 2023 was interesting but never became the center of gravity for Windows on Arm development. If the Surface RTX Spark Dev Box is to matter, it needs availability, documentation, stable drivers, a clear software support lifecycle, and enough developer adoption that troubleshooting does not feel lonely.
But local AI compute also creates new operational concerns. A machine that can run large models locally can also store large datasets locally. A developer workstation powerful enough for private inference may become a magnet for sensitive data copies, model weights, evaluation sets, credentials, and proprietary prompts.
That means procurement cannot be the end of governance. Organizations will need policies for model storage, approved runtimes, agent permissions, data retention, logging, and cloud handoff. Local compute reduces some exposure, but it also concentrates valuable assets on endpoints that must be protected and eventually decommissioned.
The upside is that Windows shops already have many of the management primitives. The hard part will be adapting them to AI workflows that move faster than traditional endpoint policy. If the Dev Box succeeds, it will force IT teams to treat AI developer workstations as a managed class of infrastructure, not as fancy PCs.
That does not mean the x86 workstation is doomed. Far from it. Many developers will still prefer x86 compatibility, discrete GPU flexibility, upgrade paths, and mature driver ecosystems. AMD’s high-memory workstation chips and Intel’s continued platform work will remain relevant, especially where organizations prize conventional procurement and software predictability.
But Nvidia has something neither Intel nor AMD can easily duplicate in AI development: CUDA as the default mental model for accelerated computing. For developers building and testing AI workloads, software gravity matters. Microsoft choosing Nvidia for this Surface device is an acknowledgment that the AI workstation market is shaped by frameworks and runtimes as much as CPU benchmarks.
The more interesting question is whether RTX Spark becomes a broad Windows platform or a premium niche. Nvidia says multiple OEMs will ship Spark laptops and compact desktops, which could prevent Microsoft’s box from becoming an isolated curiosity. If those systems arrive in volume, Windows on Arm may get a developer-class push that Qualcomm alone has struggled to deliver.
That category is still fragile. It depends on developers believing that local models will remain useful even as cloud models improve. It depends on enough open and enterprise models fitting within the local memory and performance envelope. It depends on software stacks making local inference, fine-tuning, evaluation, and deployment feel routine rather than heroic.
Yet the timing is sensible. Developers are no longer just adding a chatbot panel to applications. They are building retrieval systems, agents, copilots, local assistants, multimodal tools, and workflows that must be tested under realistic constraints. The cloud can provide scale, but the desk can provide iteration speed, privacy, and cost predictability.
Microsoft’s hardware move therefore feels less like a moonshot than a delayed correction. If AI is becoming part of normal software development, the developer workstation had to change. The Surface RTX Spark Dev Box is Microsoft’s answer to what that workstation should look like when Windows, Nvidia, WSL, Copilot, and Azure are treated as one pipeline.
Developers understand why local compute matters. They understand why memory matters. They understand why a CUDA-capable environment matters. They understand why cloud costs matter. Microsoft does not have to persuade them that AI exists; it has to persuade them that this particular Windows machine is a better place to build with it.
That is a stronger starting point than the consumer AI PC narrative, where benefits can feel abstract. A developer can measure whether a model loads, whether inference is fast enough, whether WSL behaves, whether tools compile, whether agents are useful, and whether cloud bills fall. The product either earns its desk space or it does not.
The broader AI PC market may benefit if the Dev Box proves the high end first. Workstation-class machines often establish workflows that later trickle down to mainstream hardware. If local agents, hybrid delegation, and Windows ML tooling become normal on a Spark box, Microsoft can later scale those experiences to less exotic PCs.
Several concrete points will matter more than the keynote language:
Microsoft Puts a Workstation Where the Cloud Pitch Used to Be
For the last several years, Microsoft’s AI story has been overwhelmingly cloud-shaped. Azure supplied the GPUs, GitHub Copilot supplied the developer wedge, and Windows increasingly became the surface on which cloud-backed intelligence appeared. The Surface RTX Spark Dev Box complicates that story in a useful way: Microsoft is now admitting that not every AI development loop belongs in the cloud.That is not a retreat from Azure. It is a rebalancing of the development workflow. The new box is pitched for prototyping, fine-tuning, inference, agentic pipelines, and model experimentation that can happen locally before the heavy production work moves to cloud infrastructure.
Nvidia’s Superchip Gives Surface a Different Center of Gravity
The heart of the machine is Nvidia’s RTX Spark silicon, built around a Blackwell RTX GPU and a Grace CPU design. Microsoft says the Surface RTX Spark Dev Box offers up to one petaflop of AI compute and 128GB of unified memory, with CPU and GPU sharing a single memory pool. Nvidia’s broader RTX Spark platform claims a 20-core Arm CPU, 6,144 CUDA cores, fifth-generation Tensor Cores, FP4 support, and enough memory headroom to run 120-billion-parameter models with very large context windows locally.The important number is not only the petaflop claim, which comes with the usual theoretical-performance caveats. The important number is 128GB. Local AI development is increasingly constrained less by raw enthusiasm and more by memory ceilings, especially when developers want to test larger open models, run multiple agents, or keep long context available without compressing everything into toy demos.
The Box Is Small, but the Strategy Is Not
The Surface RTX Spark Dev Box is physically framed as compact, but Microsoft is not treating it like a novelty. The company describes an anodized aluminum, 3D-printed body with a grid chassis and 1,000 air vents, a visual wink at the 1,000-teraflop marketing line. The chassis is designed to double as part of the cooling system, with Microsoft citing a 100W thermal envelope intended to sustain long-running workloads.That detail matters because AI workstations fail or succeed on sustained behavior, not launch-event arithmetic. A machine that can briefly hit impressive numbers and then throttle through a multi-hour fine-tune is a demo prop. Microsoft is explicitly trying to position this as a desk appliance for long jobs, where thermals, acoustics, drivers, and stability matter as much as the silicon logo.
Windows on Arm Gets Its Most Serious Developer Test Yet
There is an unavoidable subtext to the announcement: this is another Windows on Arm moment, but with Nvidia rather than Qualcomm at center stage. Microsoft has spent years trying to make Arm-based Windows feel inevitable, only to watch developers, driver vendors, and enterprise buyers respond with varying degrees of caution. The Surface RTX Spark Dev Box raises the stakes because it is not selling Arm as battery life. It is selling Arm as the CPU half of a serious AI workstation.That changes the software compatibility question. Developers are not merely browsing, writing documents, and running Electron apps. They are compiling dependencies, invoking Python packages, moving between Windows and WSL, using CUDA, testing frameworks, loading models, and relying on command-line tools that may have uneven Arm support.
The Developer Image Is the Product, Not Just the Packaging
The most revealing part of Microsoft’s announcement may not be the hardware at all. It is the curated Windows image. Dark theme, simplified taskbar, Widgets removed, Do Not Disturb enabled, command-line tools ready, WSL configured, CUDA available, Copilot present at the terminal: this is Microsoft admitting that default Windows is not quite the same thing as developer-ready Windows.That admission is welcome. Windows has become a strong developer platform in part because of WSL, VS Code, Windows Terminal, PowerToys, package managers, and cross-platform runtimes. But those pieces have often arrived as a kit the developer assembles after buying a normal PC. The Dev Box turns that kit into the default state.
The Mac Studio Comparison Is Useful, but Incomplete
Several early reports have framed the Surface RTX Spark Dev Box as a Mac Studio rival, and the comparison is fair at a distance. Both are compact, premium desktops with large unified memory pools, serious creative and developer ambitions, and a pitch that local compute still matters in a cloud-heavy world. Both are also ecosystem statements as much as hardware products.But the comparison breaks down quickly. Apple’s advantage is vertical integration: macOS, Apple Silicon, developer tools, media engines, and hardware design all come from one company. Microsoft’s version is more federated. Windows comes from Microsoft, the accelerator stack comes from Nvidia, the CPU architecture is Arm-based, the Linux compatibility story runs through WSL, and much of the AI developer ecosystem is open-source or cloud-linked.
Security Becomes the Argument for Local AI
Microsoft is careful to make local development sound like a security feature, not just a cost-saving measure. The Surface RTX Spark Dev Box is described as a Windows 11 secured-core PC with BitLocker, Microsoft Defender, Entra ID, and Intune integration. For organizations handling proprietary models, sensitive datasets, customer records, or regulated information, the ability to keep more experimentation local is not merely convenient.That matters because AI development has created a new shadow-IT problem. Developers want capable models and fast iteration, but the easiest path often involves sending prompts, embeddings, documents, traces, and test data to hosted services. Enterprises then face the familiar question in a new form: where did the data go, who processed it, and what policies applied?
Agents Are the Real Operating System Story
The announcement sits inside Microsoft and Nvidia’s larger push toward so-called agentic Windows experiences. Nvidia has described RTX Spark PCs as systems purpose-built for personal AI agents, with local models, Windows-native agent capabilities, and security primitives meant to constrain what agents can do. Microsoft, meanwhile, is weaving local models, GitHub Copilot, Windows Copilot Runtime, Windows ML, TensorRT, and Microsoft Foundry into a story about hybrid compute.That phrase, hybrid compute, is doing a lot of work. In Microsoft’s version, cloud agents can plan and delegate, while smaller local models handle tasks that do not require frontier-scale intelligence. A coding agent might use cloud reasoning for the high-level plan and a local model for subtasks, reducing latency and cost while keeping some work on the device.
Pricing Is the Missing Variable That Could Change the Whole Story
The biggest unknown is price. Microsoft has said the Surface RTX Spark Dev Box will be available later this year in the United States exclusively through Microsoft.com, but availability timing and pricing remain thin. That omission makes every value judgment provisional.If the Dev Box lands at a workstation-class but defensible price, it could become a credible standard machine for AI teams, research groups, advanced developers, and enterprise labs. If it arrives as a prestige object priced well beyond comparable DIY or OEM options, it risks becoming a symbol rather than a platform.
IT Departments Will See Both a Gift and a New Class of Risk
For enterprise IT, the Dev Box is attractive precisely because it looks governable. A compact Windows AI workstation enrolled in Intune is easier to reason about than a lab full of self-built Linux towers and unmanaged GPUs. Microsoft’s secured-core positioning, Entra ID integration, BitLocker support, and Defender alignment give administrators a familiar language for approving the device.But local AI compute also creates new operational concerns. A machine that can run large models locally can also store large datasets locally. A developer workstation powerful enough for private inference may become a magnet for sensitive data copies, model weights, evaluation sets, credentials, and proprietary prompts.
The Silicon Alliance Leaves Intel and AMD in an Awkward Frame
Microsoft’s decision to make a first-party Surface developer desktop around Nvidia silicon is symbolically loud. Intel and AMD remain central to the Windows ecosystem, and Microsoft is still talking about a range of capable AI PCs across vendors. But Surface has always been a showcase, and this showcase puts Nvidia’s GPU-first architecture at the center of the most demanding Windows developer story.That does not mean the x86 workstation is doomed. Far from it. Many developers will still prefer x86 compatibility, discrete GPU flexibility, upgrade paths, and mature driver ecosystems. AMD’s high-memory workstation chips and Intel’s continued platform work will remain relevant, especially where organizations prize conventional procurement and software predictability.
The Surface Brand Finally Finds a Developer Desktop Role
Surface has often been at its best when it gives OEMs permission to try something different. The original Surface Pro argued for the detachable. Surface Studio argued for the creative drafting-table PC. Surface Laptop argued that Microsoft could build a conventional premium notebook. The Surface RTX Spark Dev Box argues for a new category: the local AI developer appliance.That category is still fragile. It depends on developers believing that local models will remain useful even as cloud models improve. It depends on enough open and enterprise models fitting within the local memory and performance envelope. It depends on software stacks making local inference, fine-tuning, evaluation, and deployment feel routine rather than heroic.
The Surface Box Makes Microsoft’s AI PC Pitch Concrete
Microsoft has spent plenty of time selling the AI PC as a consumer category, often with mixed clarity. Copilot keys, NPUs, recall features, and local effects have not always convinced users that a new PC class has arrived. The Dev Box is a cleaner pitch because the workload is real and the buyer is specific.Developers understand why local compute matters. They understand why memory matters. They understand why a CUDA-capable environment matters. They understand why cloud costs matter. Microsoft does not have to persuade them that AI exists; it has to persuade them that this particular Windows machine is a better place to build with it.
The Details That Will Decide Whether This Becomes More Than a Launch Demo
The Surface RTX Spark Dev Box is compelling on paper, but the paper is not the product. Microsoft’s recent hardware and Windows history is full of promising ideas that depended on execution after the announcement. This device will be judged in the months after shipment, when developers discover what works, what breaks, and what was merely aspirational.Several concrete points will matter more than the keynote language:
- Microsoft must publish clear pricing, availability, and support terms before developers can decide whether the box is a tool or a trophy.
- Nvidia’s drivers, CUDA support, WSL integration, and AI frameworks must behave like production infrastructure rather than a preview stack.
- The Windows developer image must remain maintainable over time, because a perfectly configured day-one machine is not useful if updates break the carefully tuned workflow.
- Enterprise buyers will need documentation for management, security baselines, model governance, and lifecycle handling before they deploy these systems broadly.
- The local-agent story must prove that containment, identity, and policy controls can survive real developer behavior, not just scripted demos.
- Microsoft needs OEM momentum around RTX Spark so the Surface model defines a category rather than standing alone as a boutique experiment.
- Primary source: Neowin
Published: Tue, 02 Jun 2026 17:12:00 GMT
Loading…
www.neowin.net - Independent coverage: Android Headlines
Published: Tue, 02 Jun 2026 21:51:33 GMT
Loading…
www.androidheadlines.com - Independent coverage: SiliconANGLE
Published: Tue, 02 Jun 2026 17:40:37 GMT
Loading…
siliconangle.com - Independent coverage: Notebookcheck
Published: Tue, 02 Jun 2026 17:31:00 GMT
Loading…
www.notebookcheck.net - Independent coverage: breakingthenews.net
Published: Tue, 02 Jun 2026 16:46:00 GMT
Loading…
breakingthenews.net - Independent coverage: videocardz.com
Published: Tue, 02 Jun 2026 16:44:14 GMT
Loading…
videocardz.com
Microsoft Surface Laptop Ultra weilds Nvidia's RTX Spark superchip with 128GB of RAM, 20 Arm CPU cores, and a Blackwell GPU — 15-inch mini-LED PixelSense Ultra display rounds out the powerful package
Microsoft + Nvidia = Mivida?www.tomshardware.com
Microsoft and NVIDIA’s Surface Laptop Ultra pushes Windows on Arm into high‑performance territory
Microsoft and NVIDIA unveil the Surface Laptop Ultra, a 128GB RAM beast with Blackwell graphics and a mini-LED display that redefines performance for Windows on Arm.
www.windowscentral.com
- Related coverage: axios.com
Microsoft debuts Nvidia-powered Microsoft Surface Ultra laptop
Microsoft is trying again to redefine the PC for the AI era.www.axios.com
- Related coverage: gamesradar.com
Loading…
www.gamesradar.com - Official source: microsoft.com
Loading…
www.microsoft.com - Official source: blogs.windows.com
Building the next generation of devices for developers: Surface RTX Spark Dev Box
Software developers are some of the most ambitious makers we serve. They push devices harder, ask more of their tools and expect their environment to help define the pace of modern software creation. Development today means longer runnin
blogs.windows.com
- Related coverage: nvidianews.nvidia.com
NVIDIA and Microsoft Reinvent Windows PCs for the Age of Personal AI
NVIDIA today unveiled NVIDIA RTX Spark™, a new superchip that reinvents Windows PCs for the era of personal AI agents — offering a new class of computer that moves from tool to teammate.nvidianews.nvidia.com
- Related coverage: nvidia.com
NVIDIA DGX Spark: AI Supercomputer on Your Desk
Run autonomous AI agents from your desktop.www.nvidia.com - Related coverage: phoronix.com
- Related coverage: anatoliapulse.com
Microsoft Launches Surface RTX Spark Dev Box for Developers
Microsoft unveils Surface RTX Spark Dev Box, a compact developer PC powered by Nvidia's Arm-based RTX Spark chips for AI workloads.anatoliapulse.com
- Related coverage: techspot.com
Loading…
www.techspot.com - Related coverage: docs.nvidia.com
Loading…
docs.nvidia.com - Official source: news.microsoft.com
Microsoft Build 2026: esprimere se stessi al lavoro - Source EMEA
Di Kyle Daigle, COO, GitHub and CMO of Developer, Microsoft Le piattaforme evolvono quando a costruirle sono gli sviluppatori. Sono loro a esplorare, scegliere gli strumenti, immaginare, creare. Questa evoluzione porta con sé più informazioni che mai, disponibili a portata di mano. Ma non si...
news.microsoft.com
