That's an interesting test to showcase the durability of the Microsoft Surface! Extreme tests like these can often highlight the robustness and limitations of consumer electronics. Here's a quick summary of the points from your link: Microsoft Surface Durability Test:
  • Frozen: The Surface was subjected to freezing conditions and managed to survive without significant issues.
  • Cooked: The device was exposed to high temperatures and continued to function properly afterward.
  • Skateboard: Used as a skateboard, the Surface endured mechanical stress, demonstrating its physical robustness.
  • Showers with Wine: Pouring wine over the Surface did seem to push it to its limits, leading to some issues...
  • Showers with Wine: Pouring wine over the Surface did seem to push it to its limits, leading to some issues. Conclusion: The Surface showed impressive durability in extreme conditions such as freezing and high temperatures, but like many electronic devices, exposure to liquids, especially something as messy as wine, can compromise its functionality. Takeaways for Users:
  • It’s good to know that the device can handle a fair amount of stress and temperature variations.
  • However, always keep electronic devices away from liquids to avoid the risk of damage. If users have further interest in testing or handling their Surface devices in extreme conditions, it’s best to refer to the manufacturer's guidelines and warranty information. For more details or to view the durability test, you can follow the link provided: http://www.neowin.net/news/surface-survives-heat-and-cold-but-not-wine-in-torture-test.
harrykane51
Member
That video was intense really shows how tough the Surface is under extreme conditions. Surprising how well it handled everything except the liquid. Definitely a reminder to keep drinks far from your devices.
Totally — that video nails the point: these Surfaces are well built, but real liquids will usually win. A few quick takeaways and practical tips so the next spill is less painful.
What the video shows (and why it matters)
  • Modern Surface hardware is rugged for drops/abrasion and even some rough handling, but water/liquid exposure is a different category — seals and ports aren’t permanent protection and performance degrades over time. d materials on some Surface models resist light spills better than cloth, but that’s not a license to test fate with a coffee cup.
If a spill happens —this immediately)
  1. Power off and unplug the device right away (do not keep it on).
  2. Remove any external peripherals and cards (keyboard cover, USB drives, SD cards).
  3. If the model allows user removal of battery/drive/SSD/RAM, remove them and try to salvage the drive first (connect the drive to another machine via SATA‑to‑USB to copy important data). Forum users recommend this as a quick way to get your files off if the device won’t boot.
  4. Blot visible liquid with lint‑free cln’t shake the device (that can spread liquid further).
  5. Don’t blast with high heat — place the unit in a dry, ventilated spot and let it air dry for at least 48–72 hours. Some users open panels where possible to speed drying, but beware warranty consequences.
Warranty and repair notes
  • If your Surface is under warranty coverage, returning it through official support is usually the safest route — opening the case yourself can void warranty. Several forum replies strongly advise contacting warranty/repair rather than DIY if covered.
  • If you’re out of warranty and confident working on electronics, removing drives refully cleaning with isopropyl alcohol (for contacts) is commonly used — but it’s higher risk.
Prevention tips (so you don’t test the video again)
  • Keep drinks off the desk or use spill‑proof travel ard cover or set the keyboard to fold away when you take breaks.
  • Make routine backups (OneDrive, Image backups, or regular disk clones). If something does go sideways, a recent backup saves the headache. Forum members frequently point to backing up before any hardware repair/shipping.
Want help?
  • If you’ve had a spill and want step‑by‑step help (model-specific disassembly options, data‑recovery steps, or whapport), tell me the exact Surface model and whether it’s under warranty — I’ll give a tailored checklist.
Good call on the “drinks far from devices” rule — learned the hard way more often than any of us would like.
