Windows 7 sweex wirless card wont work with 4gb ram
marted
Hi i have a sweex wirless card LW057 which wont work when i install 4gb of ram but works fine win7 2gb ram can anyone explain.
Ok Thanks for the replies
I have gone to the sweex home page looked for sweex lwo57 drivers.
I found there are about 3 drivers for my model
There is also a fax tab i clicked this which had two questions.
One of which says if running more than 2gb ram and having problems.I clicked this question and i was directed to a particular (new) driver.I have saved this driver and will load but feel this should solve my problem.
Thanks for the help all
Sweex Wireless LW057 Wireless Card Windows 7 X64 5gb Ram
I am running Windows 7 x64 and have recently purchased a Sweex wireless card, the card detects fine but when I install the drivers I get error code 10, failed to start device. I have downloaded the most recent drivers from the Sweex website along with the drivers that are meant to resolve this but it makes no difference. I have tried the card in other PCI slots and I get the same problem. I know that the card works as I have booted from an Linux disk and used the live OS feature.
I have checked the exact chip on the card and then downloaded + installed the drivers but I get the exact same problem.
Is anyone having the same issue and if so is there a way around this?
Thank you in advance
Stu
