system error: -2147020584
Georgey
Well-Known Member
I tried to reinstall a backup program that I had used without any problem.
Now the installation program halted and cited system error: -2147020584.
What is this, and how to fix ?
(I run win 7 ultimate 64 bit; the program was, and is to be, installed on a distinct program drive, not on C.)
Thanks a lot.
Windows Forum Admin
Microsoft MVP
Hi Georgey, can you list the name of the program/app in question?
Windows Forum Admin
Microsoft MVP
Hi, thanks for the quick reply..
I think the error relates to the actual app itself and is not a Microsoft related error message. I've checked on the main site and they do have quite a good support section as well as a forum: NovaStor Customer Forum • Index page
I've got a hunch that the error relates to the fact your installing the app on a different drive or partition to 'C' but like I say it's only a hunch.. Try the above site for a more conclusive answer and failing that please post back and I'll try to help you further..
Georgey
Well-Known Member
Thanks,
I started with NovaStor forum but got viewers only, no reply.
The program had worked perfectly on my drive P (a partition on the hard-drive in my laptop) for half a year.
Now I renamed a few folders, so it'd got the 'right' to stop, but then I used the same installer as earlier.
The full error message is this:
Failed to find node:
/configuration/appSettings/add[@key='DefaultSubscriptionGroup']/@value in XML file:
C:\ProgramData\NovaStor\NovaStor
NovaBACKUP\Profiles\ManagementServer.Agent.Service.exe.config,
Windows Forum Admin
Microsoft MVP
Thanks,
So from what you say the app stopped working once you renamed certain folders? Have you considered trying system restore? I've searched the net for a meaning to the above error code but non is forthcoming or at least I can't find one for the moment. Why not try asking the Tech support? NovaStor Knowledgebase
