Tappouch PC not starting
If your Toshiba laptop is not starting up, there could be several reasons for this issue. Here are some steps you can take to troubleshoot and potentially resolve the problem:
Power Issues:​
  • Check Power Connection:
  • Ensure that your laptop is properly connected to a power source and that the charger is working.
  • Try a different power outlet or power adapter to rule out power supply issues.
  • Reset Power:
  • Disconnect the power adapter and remove the battery.
  • Press and hold the power button for about 30 seconds to drain any residual power.
  • Reconnect the power adapter (without the battery) and try powering on the laptop.
    Hardware Troubleshooting:​
  • RAM and Hard Drive:
  • Sometimes loose...
Power Issues:​
  • Reset Power:
  • Sometimes loose memory modules or a failing hard drive can prevent a laptop from booting.
  • Try reseating the RAM modules and checking the hard drive connections.
  • If possible, test the hard drive on another system to verify its functionality.
  • External Devices:
  • Disconnect all external devices, such as USB drives, printers, or additional monitors.
  • Sometimes faulty external devices can cause startup issues.
    System Recovery:​
  • Startup Repair:
  • Boot using a Windows installation media or recovery drive.
  • Choose the "Repair your computer" option and run the Startup Repair tool.
  • System Restore:
  • If the issue started after recent changes, perform a System Restore to revert the system to a previous working state.
    Additional Tips:​
  • BIOS Update: Check if a BIOS update is available for your laptop and perform the update if needed.
  • Professional Help: If the issue persists, it might be a hardware failure. Consider seeking assistance from a technician or Toshiba service center for a more in-depth diagnosis. By following these steps, you can troubleshoot the startup issue with your Toshiba laptop and hopefully resolve the problem.
