* Bugcheck Analysis *
http://www.raxco.com/support/technical
BugCheck D1, {8584383, 2, 0, 8b2ccf88}
Probably caused by : tcpip.sys ( tcpip!TcpSegmentTcbSend+4c8 )
Followup: MachineOwner
the above dump file is usually caused by Drivers using incorrect memory address's and tcpip is usually network related. I notice you have some incredibly old drivers for Windows 10 namely:
AegisP.sys Thu Dec 15 15:31:20
2005: AEGISP.SYS is related to AEGIS Client 3.4.0.1. Meetinghouse Data Comm or Cisco/Linksys wireless devices. This is far too old for Windows 10 and you need to either remove it or update it:
Cisco
AsIO.sys Tue Aug 24 08:24:46
2010: Asus PCProbe Utility
AsUpIO.sys Tue Aug 03 03:48:02
2010: Asus Hardware monitoring related. Please either update or remove
P8H61-M LX - Support
CtClsFlt.sys Mon Sep 05 03:27:59
2011: Creative Camera Class Upper Filter Driver please update:
Creative Worldwide Support
DefragFS.SYS Wed Aug 19 18:31:36
2009: PerfectDisk Defragmentation Support Driver please update or remove
HECI.sys Wed Oct 20 00:33:38
2010: Intel Management Engine Interface driver please update:
http://downloadcenter.intel.com/Default.aspx
giveio.sys Thu Apr 04 03:33:25
1996: ADC Analyzer/SwiftForth/Disspy - ?SpeedFan? Way, way too old for Windows 10 either update or remove.
mbmiodrvr.sys Sat Apr 10 15:42:35
2004: I had trouble finding out what this was or is. Perhaps something belonging to windows Driver kit?
nltdi.sys Mon Apr 23 12:02:47
2007: NetLimiter please either update or remove:
http://www.netlimiter.com/download.php
seehcri.sys Wed Jan 09 08:41:37
2008: SonyEricsson Device 0016 (likely a phone) please either update or remove:
http://www.sonyericsson.com/cws/support/softwaredownloads
tcpz-x86d.sys Sat Dec 27 07:33:05
2008: TCP-Z is a tiny application that allows users to monitor the network traffic. Please either remove or update, it wouldn't surprise me if this had something to do with your issue but i guess anything Network related has to be suspect at this time.
tenCapture.sys Sat Apr 21 15:15:42
2007: Apparently this belongs to a voice changer??? As above either update or remove.
vcsvad.sys Sun Nov 16 09:50:37
2008: Avnex Ltd. Virtual Audio Device update or remove:
Free download and try of all Audio4fun.com’s unique audio and video software
WinRing0.sys Sat Jul 26 14:25:10
2008: many different programs that center around the using of the WinRing libraries (RealTemp, Corsair Link2 (known BSOD issues w/Win8), Razer GameBooster, Fusiontweaker (Google Code), etc)
Phew, well they are the worst offenders. You still have some which I haven't posted which date around 2012 but hopefully the above will be enough. I would seriously consider at some point doing a clean install and starting afresh.
Post any new dump files.
