Trouble uploading .zip file for post
AsusUser
Hi.
I'm having trouble uploading a 2.34 MB .zip file for a BSOD forum.
I've tried with IE, Firefox and Chrome. No luck.
Seems to stop in the middle and give me a red stop sign.
Then, with basic upload, nothing seems to happen.
Thank you in advance for assistance.
Current max upload size is 10MB. Its possible the connection timed out. You could try a third party host like Skydrive or Dropbox as suggested.
Just a suggestion as I have never needed to do it........
How about using a web hosting such as Skydrive which is a Microsoft product > upload the zip file to skydrive > copy the url and past it to you reply as a link.
Would that help ?
Thanks for the various suggestions. Not sure how. Finally managed to upload a zip file with less in it. Both were well below the upload limit. Either way, these new options suggested above are duly noted for the future. Thanks!
