Is your Device optiarc dvd+-rw ad-5540a ata seen in Device Manager> + DVD/CDROM drives ?My Windows 7 is unable to read any CD/DVDs I put and I've tried several methods like uninstalling driver, reboot then let it auto reinstall again. Nothing works.
My device name is optiarc dvd+-rw ad-5540a ata.
Hope someone can help me![]()
Telepathically?HAHAHA,
Could this be one of those cases we just discussed?![]()
Did this occur immediately after installing? yes
Obviously it worked to boot from the ISO, correct? no idea
Are you usting the official RC directly from Microsoft? yes
Can you see it from Windows Explorer? yes
Does the drive letter show up when you go to Control Panel > Administrative Tools > Computer Management > Disk Management? yes
Is your Device optiarc dvd+-rw ad-5540a ata seen in Device Manager> + DVD/CDROM drives ? yes
I tried that method before... cant find the UpperFliter and LowerFilter.
I tried disable and re-enable my DVD rom drive at device manager and now it cant detect the device.
I'm still able to open up the DVD rom drive before windows 7 start up, after it start up I cant open it anymore.
Did you mean to say that Device Manager does not list your optiarc dvd+-rw ad-5540a ata in the DVD/CD-ROM devices group?
If that is correct:
Go to BIOS setup at reboot by pressing the appropraite key and check if the optiarc dvd+-rw ad-5540a ata is listed under IDE devices .
Please post back.
So the Problem was solved with the upperFilter and LowerFilter removal in Registry , right?I've had the same problem as well. With mine, both drives (asus CD-S480/AH ATA device, and LITE-ON DVDRW LH-20A1H ATA device) show up as stated in device manager. The issue here is that it says the driver is corrupt. Here's the problem, when I uninstall the driver, and scan for new devices, it installs with the same driverI just did the registry edit and am going to restart the PC now to see what happens....
*EDIT*
NO they do not show up when I go to Computer
Did this occur immediately after installing: within 12 hours, but it was after I installed Adobe CS3 Master Collection, I was about to install Microsoft Office and then this happened....
Does the drive letter show up when you go to Control Panel > Administrative Tools > Computer Management > Disk Management? no
Problem solved with the registry edit! Thanks guys!
I dont see any IDE devices under the BIOS setup. And there's no optiarc dvd+-rw ad-5540a ata listed under headers in BIOS setup.
the optiarc dvd+-rw ad-5540a previously seen in Explorer view (or click Computer> installed drives) , Disk Management Snap-in tool and Device Manager is no longer seen in those places and additionally , it is not seen in the BIOS Setup also.I tried disable and re-enable my DVD rom drive at device manager and now it cant detect the device. I'm still able to open up the DVD rom drive before windows 7 start up, after it start up I cant open it anymore
