CobaltDawg
- Joined
- Dec 6, 2012
- Messages
- 10
- Thread Author
- #1
I have discovered a strange issue with my USB ports.
My external hard drive was reporting that it encountered an error and needed to be checked. I allowed Windows 8 to automatically fix the error. The wizard got about 70% done and then reported that it had failed.
I then entered the command prompt as an administrator and ran a chkdsk :H /F on the device. The operation ran for about 80% and then reported that it did not have enough disk space to dump some random file cache.
The HDD is a 2 TB drive with 600 GB free space.
Just this evening, I noticed that it is now no longer recognized by Windows, and neither is any other USB device I try to use with it. I get no confirmation sound, and a little error box pops up that says "The last USB device you inserted has malfunctioned and Windows does not recognize it.
Windows recommends disconnecting and reconnecting, both of which I have tried, but to no avail.
My machine specs are as follows:
HP ENVY DV6 - Manuf. November 2012
Windows 8 Standard x64
8 GB RAM
3RD Gen. Intel Core i7 3630 QM @ 2.4 GHZ
As it turns out, in the Event Viewer under "System", I am seeing the following messages multiple times:
"Reset to device, \Device\RaidPort2, was issued."
"The IO operation at logical block address 149b234 for Disk 1 was retried."
"A timeout (30000 milliseconds) was reached while waiting for a transaction response from the WSearch service."
CRITICAL ERROR - "A problem has occurred with one or more user-mode drivers and the hosting process has been terminated. This may temporarily interrupt your ability to access the devices."
CRITICAL ERROR - "The device Iomega_HDD (location (unknown)) is offline due to a user-mode driver crash. Windows will attempt to restart the device 5 more times. Please contact the device manufacturer for more information about this problem."
"The system failed to flush data to the transaction log. Corruption may occur in VolumeId: H:, DeviceName: \Device\HarddiskVolume6.
(A device which does not exist was specified.)"
"The program explorer.exe version 6.2.9200.16433 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel."
This drive has worked flawlessly on every other machine I've used it on. It has my life's work on it, and I cannot afford to format it. Funny thing is, I was planning on running a backup on it when this error occurred. Is there any hope for me/it?
I am really REALLY trying my hardest to give Windows 8 a fighting chance, but my faith is starting to slip...
8 GB RAM
