sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #1
I am looking for a way to programmatically Uncheck Enable Selective Suspend on all USB Serial Ports in device manager. I changed the value of DeviceSelectiveSuspend to 0 in the registry manager but the change doesn't persist over a reboot. I have also changed my power settings to disable USB selective suspend. I cannot get this change to persist any way other than opening device manager going to advanced settings and actually unchecking Enable Selective Suspend in each COM port device. I have a large number of devices and PCs I need to do this for and do not want to manually uncheck this box on every device on every PC. Happy to share photos of everything I have tried in the registry editor that has not worked yet. This is specifically for FTDI devices if that help. Windows 11 Desktop PC.
- Joined
- Mar 14, 2023
- Messages
- 97,506
Thanks — the diff you ran is helpful.
What it shows
This will set the four values for every FTDI COM port instance (creates Device Parameters if missing) and then do a device rescan. It will overwrite existing values.
Run in an elevated PowerShell:
Get-PnpDevice -Class Ports -PresentOnly |
Where-Object { ($.Manufacturer -and $.Manufacturer -like 'FTDI') -or ($.InstanceId -and $.InstanceId -match 'VID0403') } |
ForEach-Object {
$inst = $.InstanceId
$dp = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst\Device Parameters"
New-Item -Path $dp -Force | Out-Null
New-ItemProperty -Path $dp -Name 'DeviceIdleEnabled' -PropertyType DWord -Value 0 -Force | Out-Null
New-ItemProperty -Path $dp -Name 'DefaultIdleState' -PropertyType DWord -Value 0 -Force | Out-Null
New-ItemProperty -Path $dp -Name 'UserSetDeviceIdleEnabled' -PropertyType DWord -Value 0 -Force | Out-Null
New-ItemProperty -Path $dp -Name 'SSIdleTimeout' -PropertyType DWord -Value 0 -Force | Out-Null
Write-Output "Set selective-suspend values for $inst"
Verify for one device (replace <InstanceId>):
Get-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Enum\<InstanceId>\Device Parameters" |
Select-Object DeviceIdleEnabled,DefaultIdleState,UserSetDeviceIdleEnabled,SSIdleTimeout
If you want the script to also schedule a reboot after making changes (so Windows refreshes Device Manager), add the shutdown call after the rescan:
Start-Process -FilePath 'shutdown.exe' -ArgumentList @('/r','/t','15','/c','Applying FTDI Device Parameter changes') -NoNewWindow
If you want the patched script
I can patch your Disable-FTDI-SelectiveSuspend-Final.ps1 to:
What it shows
- The before/after diff shows only SSIdleTimeout appearing (set to 0). That means toggling the Advanced → Enable Selective Suspend checkbox on your machine did NOT change the usual DeviceIdleEnabled / DefaultIdleState / UserSetDeviceIdleEnabled values — it only resulted in SSIdleTimeout being present/0 (or the driver behaves differently). Because the script was written to only create those specific values if missing, it didn’t detect or undo the GUI change.
- To reliably “uncheck” Enable Selective Suspend programmatically you need to write the registry properties the driver/Windows actually uses. The safe, effective approach that will make the Advanced checkbox show unchecked is to explicitly set these values to 0 under each device’s Device Parameters:
- DeviceIdleEnabled = 0
- DefaultIdleState = 0
- UserSetDeviceIdleEnabled = 0
- SSIdleTimeout = 0
- This will overwrite whatever the driver/INF set. It usually works, but driver reinstall or re-enumeration can overwrite these. For a persistent, supported change you should add AddReg entries to the driver INF (I can produce that snippet if you want).
- Run the commands/scripts as Administrator.
- Test on one machine first.
ForEach-Object {
do quick rescan (non-blocking)
Start-Process -FilePath 'pnputil.exe' -ArgumentList '/scan-devices' -NoNewWindowVerify for one device (replace <InstanceId>):
- Force-overwrite the four selective-suspend properties (instead of creating only when missing),
- Keep the PortName behavior,
- Run pnputil non-blocking,
- Optionally schedule a reboot.
- “Patch script to force-overwrite and reboot” — and I’ll paste the full edited script for you to save and run; or
- “Run one-liner now” — and I’ll give the exact command again (you can copy/paste) for immediate execution.
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #103
Inf snippet
- Joined
- Mar 14, 2023
- Messages
- 97,506
Good — INF AddReg is the persistent, supported way to have Windows write the per‑device values at install time so the GUI setting won’t get reset by reboots or driver re‑installs. Below I give:
INF AddReg snippet
HKR,,DeviceIdleEnabled,0x00010001,0
HKR,,DefaultIdleState,0x00010001,0
HKR,,UserSetDeviceIdleEnabled,0x00010001,0
HKR,,SSIdleTimeout,0x00010001,0
How to add it (summary)
; Add this block to the INF file
[FTDI_Device.AddReg]
; Then in the install section (example name)
[FTDI_Device_Install.NTamd64]
AddReg = FTDI_Device.AddReg
; other existing directives follow...
Notes about the syntax
- a ready‑to‑paste AddReg snippet you can drop into the FTDI device install section of the INF,
- where to place it, and
- deployment / signing / test steps.
INF AddReg snippet
- Insert this AddReg section into the FTDI device install portion of the INF (example names below — adjust to match the INF sections in the FTDI driver you use):
- Open the FTDI INF you install (e.g., oem*.inf or the FTDI supplied INF).
- Locate the device install section for the COM adapter — e.g. a section referenced from the Manufacturer/Install sections such as:
%USB\VID_0403&PID_6001.DeviceDesc%=FTDI_Device_Install,USB\VID_0403&PID_6001 - Add the AddReg block and reference it from the same install section. Example full insertion:
- HKR indicates the device’s hardware key (HKLM\SYSTEM\CurrentControlSet\Enum\<instance>\Device Parameters) — AddReg with HKR writes to the per‑device Device Parameters.
- 0x00010001 is the INF token for REG_DWORD (common pattern used in driver INFs).
- The last value (0) is the DWORD value you want written.
- Save the edited INF to a local folder (do NOT overwrite the signed original if you need to revert).
- Dry install the driver on a test machine:
- Add to driver store and install:
pnputil /add-driver "C:\path\to\your\modified.inf" /install - Or use Device Manager → Update driver → Browse my computer → Let Windows pick the new INF.
- After install, verify the registry for one device instance:
- Get the instanceid via Get-PnpDevice -Class Ports … then check:
Get-ItemProperty "HKLM:\SYSTEM\CurrentControlSet\Enum\<InstanceId>\Device Parameters" | Format-List - Confirm DeviceIdleEnabled, DefaultIdleState, UserSetDeviceIdleEnabled and SSIdleTimeout exist and are 0.
- Open Device Manager → Ports → device → Properties → Advanced — the “Enable Selective Suspend” box should reflect the INF values (unchecked if values set to 0).
- Modified INFs must be driver‑signed to install without prompts on production Windows (kernel‑mode signing on x64). For testing you can use test signing or install on machines with test signing enabled, but production use requires a properly signed package.
- For enterprise rollout use your management tools (SCCM, Intune, MDT) or pnputil to distribute and install the INF across many PCs:
- pnputil /add-driver "\server\drivers\your.inf" /install
- or integrate into a driver package and push with your deployment system.
- If Windows blocks an unsigned/modified INF you’ll need to sign the driver package or use a signed wrapper / driver package management method.
- To remove the driver you pushed with pnputil:
- pnputil /delete-driver oemXX.inf /uninstall /force (replace oemXX.inf with the published name)
- Or revert the INF, reinstall the original FTDI driver from FTDI and the AddReg changes will be removed.
- Produce a fully formed INF patch example that matches the exact install section names in your current oem167.inf — paste the relevant portions (the [Manufacturer] and the device install section names) and I’ll produce the exact lines to insert; or
- Give you a ready PowerShell one‑liner that will import your modified INF to the driver store and install it on the local machine, plus a verification command; or
- Produce an automated SCCM/Intune deployment snippet if you plan mass rollout.
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #105
Can you patch Disable-FTDI-SelectiveSuspend-Final.ps1 to:
- Joined
- Mar 14, 2023
- Messages
- 97,506
Got it — I patched the script exactly as you asked. Summary of behavior in this version:
Usage examples:
Notes & recommendations
- Force-overwrites the four selective-suspend properties (DeviceIdleEnabled, DefaultIdleState, UserSetDeviceIdleEnabled, SSIdleTimeout) — but only actually writes and counts an update if the property is missing or its value is not already the desired value (so you won't see the same "60 changes" every run if nothing needs changing).
- Keeps the PortName behavior (it still writes PortName only if missing, and it does not change actual COM assignments).
- Runs pnputil /scan-devices in the background (non-blocking) so the script finishes quickly.
- Optionally schedules a reboot if any real changes were made (unless you pass -NoReboot).
- Supports -WhatIf dry run to preview changes (no writes, no reboot).
Usage examples:
- Dry run (no writes, no reboot):
PowerShell -ExecutionPolicy Bypass -File .\Disable-FTDI-SelectiveSuspend-Force.ps1 -WhatIf - Apply and allow reboot if changes were made:
PowerShell -ExecutionPolicy Bypass -File .\Disable-FTDI-SelectiveSuspend-Force.ps1 - Apply but do not reboot (use pnputil /scan-devices or reboot manually later):
PowerShell -ExecutionPolicy Bypass -File .\Disable-FTDI-SelectiveSuspend-Force.ps1 -NoReboot
- Force-overwrite selective-suspend properties (DeviceIdleEnabled, DefaultIdleState, UserSetDeviceIdleEnabled, SSIdleTimeout) when they are missing or not equal to 0 (so non-zero values get corrected).
- Keeps PortName behaviour: writes PortName only when missing (does not reassign COMs).
- Launches pnputil /scan-devices in background (non-blocking).
- Optionally schedules a reboot if actual changes were made (unless -NoReboot).
- Supports -WhatIf for a dry run.
Run as Administrator.
#> param( [switch]$WhatIf, [switch]$NoReboot) # Ensure elevated
if (-not ([Security.Principal.WindowsPrincipal] [Security.Principal.WindowsIdentity]::GetCurrent.IsInRole([Security.Principal.WindowsBuiltinRole]::Administrator) { Write-Error "This script must be run as Administrator. Exiting." exit 1
} $timestamp = (Get-Date).ToString('yyyyMMdd_HHmmss')
$logFile = Join-Path $env:USERPROFILE ("Desktop\Disable-FTDI-SelectiveSuspend_Force_$timestamp.log")
"Started: $(Get-Date -Format u)" | Out-File -FilePath $logFile -Encoding UTF8 function Get-ComForInstance { param([string]$instanceId) try { $sp = Get-CimInstance -ClassName Win32_SerialPort -ErrorAction SilentlyContinue | Where-Object { $_.PNPDeviceID -eq $instanceId } if ($sp) { return $sp.DeviceID } # e.g. COM3 $tail = ($instanceId -split '\\')[-1] if ($tail) { $sp = Get-CimInstance -ClassName Win32_SerialPort -ErrorAction SilentlyContinue | Where-Object { $_.PNPDeviceID -like "*$tail*" } if ($sp) { return $sp.DeviceID } } } catch {} return $null
} # Find FTDI COM ports
$ports = Get-PnpDevice -Class Ports -PresentOnly -ErrorAction SilentlyContinue | Where-Object { ($_.Manufacturer -and $_.Manufacturer -like '*FTDI*') -or ($_.InstanceId -and $_.InstanceId -match 'VID_0403') } if (-not $ports -or $ports.Count -eq 0) { "No FTDI COM ports found." | Tee-Object -FilePath $logFile -Append Write-Output "No FTDI COM ports found. See log: $logFile" exit 0
} "Found $($ports.Count) FTDI COM port(s)." | Tee-Object -FilePath $logFile -Append $createdCount = 0
$errors = @
$processedDp = @{} # hashset to avoid reprocessing the same DP path foreach ($p in $ports) { "----" | Tee-Object -FilePath $logFile -Append "Device FriendlyName: $($p.FriendlyName)" | Tee-Object -FilePath $logFile -Append "InstanceId: $($p.InstanceId)" | Tee-Object -FilePath $logFile -Append $inst = $p.InstanceId if ([string]::IsNullOrWhiteSpace($inst) { "InstanceId empty; skipping" | Tee-Object -FilePath $logFile -Append continue } # Build the canonical registry path for this instance $regPathBase = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst" $dpCandidates = @("$regPathBase\Device Parameters", "$regPathBase\0000\Device Parameters") $dpFoundForInstance = $false foreach ($dp in $dpCandidates) { $dpStr = [string]$dp "Checking: $dpStr" | Tee-Object -FilePath $logFile -Append if ($processedDp.ContainsKey($dpStr) { "Already processed $dpStr this run - skipping." | Tee-Object -FilePath $logFile -Append $dpFoundForInstance = $true break } if (Test-Path $dpStr) { $dpFoundForInstance = $true "Using Device Parameters: $dpStr" | Tee-Object -FilePath $logFile -Append $processedDp[$dpStr] = $true # Read existing properties once try { $item = Get-ItemProperty -Path $dpStr -ErrorAction SilentlyContinue $existingProps = @ if ($item) { $existingProps = $item.PSObject.Properties | ForEach-Object { $_.Name } } } catch { $existingProps = @ } # PortName: write only if missing (preserve existing COM assignment) if (-not ($existingProps -contains 'PortName') { $friendly = $p.FriendlyName $detectedCom = $null if ($friendly -and ($friendly -match '\(COM(\d+)\)') { $detectedCom = "COM$($matches[1])" "Detected COM from FriendlyName: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } else { $detectedCom = Get-ComForInstance -instanceId $inst if ($detectedCom) { "Detected COM via WMI: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } } if ($detectedCom) { if ($WhatIf) { "WhatIf: would write PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'PortName' -PropertyType String -Value $detectedCom -Force -ErrorAction Stop | Out-Null "WROTE PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing PortName at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "PortName write error for $inst : $($_.Exception.Message)" } } } else { "Could not detect COM for $inst; PortName not written." | Tee-Object -FilePath $logFile -Append } } else { $currPort = (Get-ItemProperty -Path $dpStr -Name 'PortName' -ErrorAction SilentlyContinue).PortName "PortName already present at $($dpStr): $($currPort) - not changed" | Tee-Object -FilePath $logFile -Append } # Force‑overwrite selective‑suspend properties: set to 0 (write only if not already 0) $toForce = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 } foreach ($kv in $toForce.GetEnumerator { $name = $kv.Key; $desired = [int]$kv.Value try { $existingVal = $null try { $existingVal = (Get-ItemProperty -Path $dpStr -Name $name -ErrorAction SilentlyContinue).$name } catch { $existingVal = $null } } catch { $existingVal = $null } # Determine if write needed (only if missing or different) $needWrite = $false if ($existingVal -eq $null) { $needWrite = $true } else { try { $existingInt = [int]$existingVal; if ($existingInt -ne $desired) { $needWrite = $true } } catch { $needWrite = $true } } if ($needWrite) { if ($WhatIf) { "WhatIf: would set $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name $name -PropertyType DWord -Value $desired -Force -ErrorAction Stop | Out-Null "WROTE $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing $($name) at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "Write $($name) error for $inst : $($_.Exception.Message)" } } } else { "$($name) already = $existingVal at $($dpStr) - not changed" | Tee-Object -FilePath $logFile -Append } } break } else { "Not found: $($dpStr)" | Tee-Object -FilePath $logFile -Append } } # end foreach dpCandidates } # end foreach ports "Created/changed count: $createdCount" | Tee-Object -FilePath $logFile -Append
if ($errors.Count -gt 0) { "Errors: $($errors.Count)" | Tee-Object -FilePath $logFile -Append $errors | Tee-Object -FilePath $logFile -Append
} # Launch pnputil asynchronously so script ends quickly
try { "Launching device rescan (pnputil /scan-devices) in background" | Tee-Object -FilePath $logFile -Append $proc = Start-Process -FilePath 'pnputil.exe' -ArgumentList '/scan-devices' -NoNewWindow -PassThru "pnputil started (PID $($proc.Id)" | Tee-Object -FilePath $logFile -Append
} catch { "pnputil failed to start: $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append
} if (($createdCount -gt 0) -and (-not $WhatIf) -and (-not $NoReboot) { "Scheduling reboot in 15 seconds so changes take effect (abort with 'shutdown /a')." | Tee-Object -FilePath $logFile -Append Start-Process -FilePath 'shutdown.exe' -ArgumentList @('/r','/t','15','/c','Applying FTDI Device Parameter changes') -NoNewWindow
} else { "No reboot scheduled. If you created properties and want immediate recognition, run: pnputil /scan-devices or reboot manually." | Tee-Object -FilePath $logFile -Append
} "Completed: $(Get-Date -Format u)" | Tee-Object -FilePath $logFile -Append
Write-Output "Done. Log saved to: $logFile"
- This version will correct any non‑zero values for the four selective‑suspend properties to 0 (so it “unchecks” selective suspend effectively). Because I only count actual writes (value changed or missing), re-running the script will not repeatedly report many changes unless something modifies those values again.
- For long‑term persistency across driver reinstalls or re-enumeration, use the INF AddReg approach I gave earlier (I can produce a ready INF snippet targeted to your oem167.inf if you paste its relevant install section header).
- Test on one machine first; keep backups and consider using -WhatIf for a first pass.
- Generate a one‑line command to push this script and run it on multiple machines (PSRemoting / Intune format), or
- Produce the INF AddReg patch targeted to your oem167.inf (paste the INF install section header and I’ll craft the exact insertion).
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #107
This script did not change enable selective suspend checkbox
- Joined
- Mar 14, 2023
- Messages
- 97,506
Thanks — useful context. Your before/after diff showed toggling the Advanced → Enable Selective Suspend checkbox only changed SSIdleTimeout, not the other keys (DeviceIdleEnabled, DefaultIdleState, UserSetDeviceIdleEnabled). That matches why earlier versions of the script didn’t flip the GUI: the GUI is reading a property your script wasn’t overwriting.
What to do now (safe, step‑by‑step)
1) Verify current registry values for one problematic device (run elevated PowerShell)
Where-Object { ($.Manufacturer -and $.Manufacturer -like 'FTDI') -or ($_.InstanceId -match 'VID_0403') } |
Format-List FriendlyName,InstanceId
Get-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst\Device Parameters" -ErrorAction SilentlyContinue | Format-List
If you see SSIdleTimeout only (or some values missing), that confirms what we saw earlier.
2) Force the correct values and immediately refresh the device so Device Manager reads them
Script (copy entire block):
Notes on the script
Select-Object DeviceIdleEnabled,DefaultIdleState,UserSetDeviceIdleEnabled,SSIdleTimeout,PortName
Paste that output here and I’ll inspect. (If you already have a log showing WROTE lines for those keys, paste the last 40 lines.
4) Persistent / supported fix
- List FTDI ports and pick an InstanceId:
- Inspect Device Parameters for one InstanceId (replace <INSTANCEID> with one from above):
- This script (run elevated) will:
- force each FTDI device’s Device Parameters DWords to 0 (overwriting if needed),
- write PortName only if missing (preserves COM assignment),
- disable + re-enable each device (so Windows re-reads Device Parameters immediately),
- run pnputil in background (non-blocking) and optionally reboot if changes were made.
# Run elevated
$WhatIf = $false # set $true to dry-run
$ForceReboot = $false # set $true to allow reboot if changes made $ports = Get-PnpDevice -Class Ports -PresentOnly | Where-Object { ($_.Manufacturer -and $_.Manufacturer -like '*FTDI*') -or ($_.InstanceId -match 'VID_0403') } if (-not $ports) { Write-Output "No FTDI ports found."; exit 0 } $changes = 0
foreach ($p in $ports) { $inst = $p.InstanceId $dp = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst\Device Parameters" if (-not (Test-Path $dp) { if ($WhatIf) { Write-Output "WhatIf: would create key $dp" } else { New-Item -Path $dp -Force | Out-Null; Write-Output "Created $dp" } } # Ensure PortName exists (do not change if already present) try { $currPort = (Get-ItemProperty -Path $dp -Name 'PortName' -ErrorAction SilentlyContinue).PortName } catch { $currPort = $null } if ([string]::IsNullOrWhiteSpace($currPort) { # derive COM from FriendlyName if possible if ($p.FriendlyName -match '\(COM(\d+)\)') { $com = "COM$($matches[1])" } else { $com = $null } if ($com) { if ($WhatIf) { Write-Output "WhatIf: would write PortName=$com to $dp" } else { New-ItemProperty -Path $dp -Name 'PortName' -PropertyType String -Value $com -Force | Out-Null; Write-Output "WROTE PortName=$com to $dp"; $changes++ } } } # Force overwrite the selective-suspend values only if not already 0 $props = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 } foreach ($kv in $props.GetEnumerator { $name = $kv.Key; $desired = [int]$kv.Value try { $existing = (Get-ItemProperty -Path $dp -Name $name -ErrorAction SilentlyContinue).$name } catch { $existing = $null } $doWrite = $false if ($existing -eq $null) { $doWrite = $true } else { try { if ([int]$existing -ne $desired) { $doWrite = $true } } catch { $doWrite = $true } } if ($doWrite) { if ($WhatIf) { Write-Output "WhatIf: would set $name=$desired at $dp" } else { New-ItemProperty -Path $dp -Name $name -PropertyType DWord -Value $desired -Force | Out-Null Write-Output "WROTE $name=$desired at $dp" $changes++ } } else { Write-Output "$name already = $existing at $dp (no change)" } } # Refresh device: disable then enable so Windows re-reads Device Parameters if (-not $WhatIf) { try { Disable-PnpDevice -InstanceId $inst -Confirm:$false -ErrorAction Stop Start-Sleep -Seconds 2 Enable-PnpDevice -InstanceId $inst -Confirm:$false -ErrorAction Stop Write-Output "Restarted device $inst" } catch { Write-Warning "Could not restart device $inst: $($_.Exception.Message) -- you may need to replug or reboot." } } else { Write-Output "WhatIf: would restart device $inst" }
} # background rescan
if (-not $WhatIf) { Start-Process -FilePath 'pnputil.exe' -ArgumentList '/scan-devices' -NoNewWindow Write-Output "Launched pnputil /scan-devices in background"
} Write-Output "Total writes performed: $changes"
if (($changes -gt 0) -and (-not $WhatIf) -and $ForceReboot) { Start-Process -FilePath 'shutdown.exe' -ArgumentList @('/r','/t','15','/c','Applying FTDI Device Parameter changes') -NoNewWindow
- Disable-PnpDevice / Enable-PnpDevice come from the PnpDevice module (built into modern PowerShell). They require elevation. If those cmdlets are not present on your OS, we can instead use devcon (if available) or ask you to replug the device or reboot.
- This script only overwrites the four selective-suspend values when they are missing or not equal to 0. That prevents repeated “60 changes” if nothing actual needs changing.
- After the disable/enable the Device Manager UI should re-read values and update the Advanced → Enable Selective Suspend checkbox immediately. If it doesn’t, a full reboot will.
- Confirm the exact values you see after running the script for a single InstanceId:
- The INF AddReg approach is the proper persistent solution: add these HKR AddReg entries in the FTDI install section so the values are set at driver install/enumeration (we provided that snippet earlier). That survives replug/driver updates. I can craft an INF insertion that matches your oem167.inf if you paste the install section header lines — or I can provide the exact commands to publish/install your modified INF across machines.
- Tell me:
- which mode: run the Force+Refresh script above now, or
- produce the INF patch targeted to your oem167.inf (paste the relevant [Manufacturer] / install section headers), or
- run a focused diagnostic and paste the Get-ItemProperty output for one InstanceId and I’ll tell you exactly which registry writes are still missing.
- The GUI toggled SSIdleTimeout only (we confirmed earlier), so you must set the four selective-suspend keys to 0 and force the device to re-enumerate so the UI reads the new values. We gave a script to do that and a persistent INF AddReg approach for deployment. If you run the Force+Refresh script and paste the verification output (Get-ItemProperty), I’ll confirm the checkbox mapping and produce a final INF snippet you can deploy.
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #109
Can you add to this script to read in the contents of DWORD ConfigData and check if the first 4 bytes of ConfigData are 01 00 3F 3F and if they aren't changes only those bytes to 01 00 3F 3F.
# Run elevated<br>$WhatIf = $false # set $true to dry-run<br>$ForceReboot = $false # set $true to allow reboot if changes made<br><br>$ports = Get-PnpDevice -Class Ports -PresentOnly |<br> Where-Object { ($_.Manufacturer -and $_.Manufacturer -like '*FTDI*') -or ($_.InstanceId -match 'VID_0403') }<br><br>if (-not $ports) { Write-Output "No FTDI ports found."; exit 0 }<br><br>$changes = 0<br>foreach ($p in $ports) {<br> $inst = $p.InstanceId<br> $dp = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst\Device Parameters"<br><br> if (-not (Test-Path $dp)) {<br> if ($WhatIf) { Write-Output "WhatIf: would create key $dp" } else { New-Item -Path $dp -Force | Out-Null; Write-Output "Created $dp" }<br> }<br><br> # Ensure PortName exists (do not change if already present)<br> try {<br> $currPort = (Get-ItemProperty -Path $dp -Name 'PortName' -ErrorAction SilentlyContinue).PortName<br> } catch { $currPort = $null }<br> if ([string]::IsNullOrWhiteSpace($currPort)) {<br> # derive COM from FriendlyName if possible<br> if ($p.FriendlyName -match '\(COM(\d+)\)') { $com = "COM$($matches[1])" } else { $com = $null }<br> if ($com) {<br> if ($WhatIf) { Write-Output "WhatIf: would write PortName=$com to $dp" } else { New-ItemProperty -Path $dp -Name 'PortName' -PropertyType String -Value $com -Force | Out-Null; Write-Output "WROTE PortName=$com to $dp"; $changes++ }<br> }<br> }<br><br> # Force overwrite the selective-suspend values only if not already 0<br> $props = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 }<br> foreach ($kv in $props.GetEnumerator()) {<br> $name = $kv.Key; $desired = [int]$kv.Value<br> try { $existing = (Get-ItemProperty -Path $dp -Name $name -ErrorAction SilentlyContinue).$name } catch { $existing = $null }<br> $doWrite = $false<br> if ($existing -eq $null) { $doWrite = $true } else {<br> try { if ([int]$existing -ne $desired) { $doWrite = $true } } catch { $doWrite = $true }<br> }<br> if ($doWrite) {<br> if ($WhatIf) { Write-Output "WhatIf: would set $name=$desired at $dp" } else {<br> New-ItemProperty -Path $dp -Name $name -PropertyType DWord -Value $desired -Force | Out-Null<br> Write-Output "WROTE $name=$desired at $dp"<br> $changes++<br> }<br> } else {<br> Write-Output "$name already = $existing at $dp (no change)"<br> }<br> }<br><br> # Refresh device: disable then enable so Windows re-reads Device Parameters<br> if (-not $WhatIf) {<br> try {<br> Disable-PnpDevice -InstanceId $inst -Confirm:$false -ErrorAction Stop<br> Start-Sleep -Seconds 2<br> Enable-PnpDevice -InstanceId $inst -Confirm:$false -ErrorAction Stop<br> Write-Output "Restarted device $inst"<br> } catch {<br> Write-Warning "Could not restart device $inst: $($_.Exception.Message) -- you may need to replug or reboot."<br> }<br> } else {<br> Write-Output "WhatIf: would restart device $inst"<br> }<br>}<br><br># background rescan<br>if (-not $WhatIf) {<br> Start-Process -FilePath 'pnputil.exe' -ArgumentList '/scan-devices' -NoNewWindow<br> Write-Output "Launched pnputil /scan-devices in background"<br>}<br><br>Write-Output "Total writes performed: $changes"<br>if (($changes -gt 0) -and (-not $WhatIf) -and $ForceReboot) {<br> Start-Process -FilePath 'shutdown.exe' -ArgumentList @('/r','/t','15','/c','Applying FTDI Device Parameter changes') -NoNewWindow<br>}
- Joined
- Mar 14, 2023
- Messages
- 97,506
Done — I added ConfigData handling to your script. What I implemented:
Script (copy entire file and save as .ps1):
Notes and safety
- For each FTDI device instance the script now:
- Reads the ConfigData value (if any).
- Normalizes it to a byte[] (handles REG_BINARY or REG_DWORD).
- Checks whether the first 4 bytes equal: 0x01,0x00,0x3F,0x3F.
- If they are not equal, it replaces only those first 4 bytes (preserving the remainder of the blob) and writes the value back:
- If original was a DWORD (4 bytes) it writes a REG_DWORD with the new uint32 value.
- If original was binary (longer blob) it writes the modified binary back as REG_BINARY.
- If ConfigData did not exist it creates ConfigData with those 4 bytes.
- Counts an actual write only when a real change was performed.
- The rest of the script is unchanged:
- Force-overwrites the four selective-suspend DWords when necessary,
- Keeps PortName behavior (only write if missing),
- Runs pnputil /scan-devices in the background,
- Optionally schedules a reboot if changes were made (unless you pass -NoReboot),
- Supports -WhatIf dry-run mode.
Disable-FTDI-SelectiveSuspend-Force-ConfigData.ps1
- Force-overwrite selective-suspend properties (DeviceIdleEnabled, DefaultIdleState, UserSetDeviceIdleEnabled, SSIdleTimeout) when they are missing or not equal to 0.
- Keeps PortName behaviour (write only if missing).
- Reads/modifies ConfigData: ensures first 4 bytes are 01 00 3F 3F; if not, changes only those bytes.
- Launches pnputil /scan-devices in background and optionally schedules reboot.
- Supports -WhatIf for dry-run.
#> param( [switch]$WhatIf, [switch]$NoReboot) # ensure elevated
$logFile = Join-Path $env:USERPROFILE ("Desktop\Disable-FTDI-SelectiveSuspend_Force_ConfigData_$timestamp.log")
"Started: $(Get-Date -Format u)" | Out-File -FilePath $logFile -Encoding UTF8 function Get-ComForInstance { param([string]$instanceId) try { $sp = Get-CimInstance -ClassName Win32_SerialPort -ErrorAction SilentlyContinue | Where-Object { $_.PNPDeviceID -eq $instanceId } if ($sp) { return $sp.DeviceID } $tail = ($instanceId -split '\\')[-1] if ($tail) { $sp = Get-CimInstance -ClassName Win32_SerialPort -ErrorAction SilentlyContinue | Where-Object { $_.PNPDeviceID -like "*$tail*" } if ($sp) { return $sp.DeviceID } } } catch { } return $null
} # desired first 4 bytes
$desiredBytes = [byte[] (0x01,0x00,0x3F,0x3F)
$desiredDword = [uint32]0x3F3F0001 # little-endian bytes 01 00 3F 3F # Find FTDI COM ports
$errors = @
$processedDp = @{} # track DP paths processed this run foreach ($p in $ports) { "----" | Tee-Object -FilePath $logFile -Append "Device FriendlyName: $($p.FriendlyName)" | Tee-Object -FilePath $logFile -Append "InstanceId: $($p.InstanceId)" | Tee-Object -FilePath $logFile -Append $inst = $p.InstanceId if ([string]::IsNullOrWhiteSpace($inst) { "InstanceId empty; skipping" | Tee-Object -FilePath $logFile -Append; continue } $regPathBase = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst" $dpCandidates = @("$regPathBase\Device Parameters", "$regPathBase\0000\Device Parameters") $dpFoundForInstance = $false foreach ($dp in $dpCandidates) { $dpStr = [string]$dp "Checking: $dpStr" | Tee-Object -FilePath $logFile -Append if ($processedDp.ContainsKey($dpStr) { "Already processed $dpStr this run - skipping." | Tee-Object -FilePath $logFile -Append $dpFoundForInstance = $true break } if (Test-Path $dpStr) { $dpFoundForInstance = $true "Using Device Parameters: $($dpStr)" | Tee-Object -FilePath $logFile -Append $processedDp[$dpStr] = $true # Read existing properties once try { $item = Get-ItemProperty -Path $dpStr -ErrorAction SilentlyContinue $existingProps = if ($item) { $item.PSObject.Properties | ForEach-Object { $_.Name } } else { @ } } catch { $existingProps = @ } # PortName: write only if missing if (-not ($existingProps -contains 'PortName') { $friendly = $p.FriendlyName $detectedCom = $null if ($friendly -and ($friendly -match '\(COM(\d+)\)') { $detectedCom = "COM$($matches[1])"; "Detected COM from FriendlyName: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } else { $detectedCom = Get-ComForInstance -instanceId $inst; if ($detectedCom) { "Detected COM via WMI: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } } if ($detectedCom) { if ($WhatIf) { "WhatIf: would write PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'PortName' -PropertyType String -Value $detectedCom -Force -ErrorAction Stop | Out-Null "WROTE PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing PortName at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "PortName write error for $inst : $($_.Exception.Message)" } } } else { "Could not detect COM for $inst; PortName not written." | Tee-Object -FilePath $logFile -Append } } else { $currPort = (Get-ItemProperty -Path $dpStr -Name 'PortName' -ErrorAction SilentlyContinue).PortName "PortName already present at $($dpStr): $($currPort) - not changed" | Tee-Object -FilePath $logFile -Append } # Force-overwrite selective-suspend properties if missing or not 0 $toForce = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 } foreach ($kv in $toForce.GetEnumerator { $name = $kv.Key; $desired = [int]$kv.Value try { $existingVal = (Get-ItemProperty -Path $dpStr -Name $name -ErrorAction SilentlyContinue).$name } catch { $existingVal = $null } $needWrite = $false if ($existingVal -eq $null) { $needWrite = $true } else { try { if ([int]$existingVal -ne $desired) { $needWrite = $true } } catch { $needWrite = $true } } if ($needWrite) { if ($WhatIf) { "WhatIf: would set $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name $name -PropertyType DWord -Value $desired -Force -ErrorAction Stop | Out-Null "WROTE $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing $($name) at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "Write $($name) error for $inst : $($_.Exception.Message)" } } } else { "$($name) already = $existingVal at $($dpStr) - not changed" | Tee-Object -FilePath $logFile -Append } } # ---- ConfigData handling: ensure first 4 bytes == 01 00 3F 3F ---- try { # read raw $cfgRaw = $null try { $cfgRaw = Get-ItemProperty -Path $dpStr -Name 'ConfigData' -ErrorAction SilentlyContinue }.ConfigData } catch { $cfgRaw = $null } if ($cfgRaw -ne $null) { # normalize to byte[] if ($cfgRaw -is [byte[]) { $bytes = [byte[]$cfgRaw $origType = 'Binary' } elseif ($cfgRaw -is [int] -or $cfgRaw -is [uint32] -or $cfgRaw -is [long]) { # DWORD -> convert to 4-byte little-endian array $bytes = [BitConverter]::GetBytes([uint32]$cfgRaw) $origType = 'DWord' } else { # unknown type: attempt to convert try { $bytes = [byte[]$cfgRaw; $origType='Binary' } catch { $bytes = @; $origType='Unknown' } } } else { # not present -> create minimal 4-byte array $bytes = [byte[](0,0,0,0) $origType = 'Missing' } $needCfgWrite = $false # ensure length at least 4 if ($bytes.Length -lt 4) { $newBytes = New-Object byte[] 4; $bytes.CopyTo($newBytes,0); $bytes = $newBytes } # compare first 4 bytes for ($i=0; $i -lt 4; $i++) { if ($bytes[$i] -ne $desiredBytes[$i]) { $needCfgWrite = $true; break } } if ($needCfgWrite) { # change only first 4 bytes for ($i=0; $i -lt 4; $i++) { $bytes[$i] = $desiredBytes[$i] } if ($WhatIf) { "WhatIf: would update ConfigData first 4 bytes at $($dpStr) (orig type: $origType)" | Tee-Object -FilePath $logFile -Append } else { try { if ($origType -eq 'DWord') { # write as DWORD: convert first 4 bytes to uint32 $newDword = [BitConverter]::ToUInt32($bytes,0) New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'ConfigData' -PropertyType DWord -Value $newDword -Force -ErrorAction Stop | Out-Null "WROTE ConfigData (DWORD) = 0x$([Convert]::ToString($newDword,16).ToUpper at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { # write as binary blob (preserve extended bytes) New-Item -Path $dpStr -Force | Out-Null Set-ItemProperty -Path $dpStr -Name 'ConfigData' -Value $bytes -ErrorAction Stop "WROTE ConfigData (Binary) first 4 bytes updated at $($dpStr)" | Tee-Object -FilePath $logFile -Append } $createdCount++ } catch { "ERROR writing ConfigData at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "ConfigData write error for $inst : $($_.Exception.Message)" } } } else { "ConfigData first 4 bytes already match desired pattern at $($dpStr) (no change)." | Tee-Object -FilePath $logFile -Append } break } else { "Not found: $($dpStr)" | Tee-Object -FilePath $logFile -Append } } } # end foreach ports "Created/changed count: $createdCount" | Tee-Object -FilePath $logFile -Append
- The script preserves any bytes beyond the first 4 when ConfigData is REG_BINARY. If ConfigData was a DWORD originally, it writes a DWORD with the new 4 bytes.
- Run a dry run first: add -WhatIf to the command line to preview changes without writing.
- If you get Access Denied writing under HKLM...\Enum on some machines, you may need to run the script as SYSTEM (scheduled task or psexec) or use the INF AddReg approach (preferred for deployment). I can show the minimal, reversible ACL approach if needed.
- After running (not WhatIf) the script will launch an asynchronous pnputil rescan; if Device Manager doesn’t immediately update, replug a device or reboot.
- Remove the automatic reboot entirely and just rely on rescan; or
- Add an option to force overwrite ConfigData entirely (instead of preserving the tail) — say so and I’ll provide it.
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #111
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:42 char:46
+ $desiredBytes = [byte[] (0x01,0x00,0x3F,0x3F)
Missing ] at end of attribute or type literal.
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:156 char:105
+ ... ath $dpStr -Name 'ConfigData' -ErrorAction SilentlyContinue }.ConfigD ...
The Try statement is missing its Catch or Finally block.
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:160 char:31
+ if ($cfgRaw -is [byte[]) {
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:161 char:26
+ $bytes = [byte[]$cfgRaw
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:169 char:32
+ try { $bytes = [byte[]$cfgRaw; $origType='Binary' } catch { ...
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:173 char:34
+ $bytes = [byte[](0,0,0,0)
+ CategoryInfo : ParserError: ) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : EndSquareBracketExpectedAtEndOfAttribute
- Joined
- Mar 14, 2023
- Messages
- 97,506
Thanks — those parse errors came from a few missing brackets and a malformed try block in the ConfigData section. I fixed and cleaned the entire script so it parses and runs correctly.
Save this exact script (overwrite Disable_Selective_Suspend.ps1) and run it in an elevated PowerShell (Run as Administrator). Test first with -WhatIf.
What I fixed
Run tips
What I fixed
- Correct [byte[] literal: [byte[] (0x01,0x00,0x3F,0x3F)
- Proper try/catch around reading ConfigData
- Robust conversion of ConfigData when it is REG_BINARY or REG_DWORD
- Ensures byte[] length >= 4 before comparing/updating
- Writes back either REG_DWORD (if original was DWORD) or REG_BINARY (otherwise)
- Balanced brackets and tidy logging
- Ensure ConfigData first 4 bytes are 01 00 3F 3F (modify only those bytes)
- Keep PortName behavior (write only if missing)
- Launch pnputil /scan-devices in background and optionally schedule reboot
Run elevated.
$logFile = Join-Path $env:USERPROFILE ("Desktop\Disable_Selective_Suspend_$timestamp.log")
} # desired first 4 bytes (01 00 3F 3F)
# corresponding little-endian DWORD
$desiredDword = [uint32]0x3F3F0001 # Find FTDI COM ports
$errors = @
$processedDp = @{} # avoid reprocessing same DP foreach ($p in $ports) { "----" | Tee-Object -FilePath $logFile -Append "Device FriendlyName: $($p.FriendlyName)" | Tee-Object -FilePath $logFile -Append "InstanceId: $($p.InstanceId)" | Tee-Object -FilePath $logFile -Append $inst = $p.InstanceId if ([string]::IsNullOrWhiteSpace($inst) { "InstanceId empty; skipping" | Tee-Object -FilePath $logFile -Append; continue } $regPathBase = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst" $dpCandidates = @("$regPathBase\Device Parameters","$regPathBase\0000\Device Parameters") $dpFoundForInstance = $false foreach ($dp in $dpCandidates) { $dpStr = [string]$dp "Checking: $dpStr" | Tee-Object -FilePath $logFile -Append if ($processedDp.ContainsKey($dpStr) { "Already processed $dpStr this run - skipping." | Tee-Object -FilePath $logFile -Append $dpFoundForInstance = $true break } if (Test-Path $dpStr) { $dpFoundForInstance = $true "Using Device Parameters: $($dpStr)" | Tee-Object -FilePath $logFile -Append $processedDp[$dpStr] = $true # Read existing properties try { $item = Get-ItemProperty -Path $dpStr -ErrorAction SilentlyContinue $existingProps = if ($item) { $item.PSObject.Properties | ForEach-Object { $_.Name } } else { @ } } catch { $existingProps = @ } # PortName: write only if missing if (-not ($existingProps -contains 'PortName') { $friendly = $p.FriendlyName $detectedCom = $null if ($friendly -and ($friendly -match '\(COM(\d+)\)') { $detectedCom = "COM$($matches[1])"; "Detected COM from FriendlyName: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } else { $detectedCom = Get-ComForInstance -instanceId $inst; if ($detectedCom) { "Detected COM via WMI: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } } if ($detectedCom) { if ($WhatIf) { "WhatIf: would write PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'PortName' -PropertyType String -Value $detectedCom -Force -ErrorAction Stop | Out-Null "WROTE PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing PortName at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "PortName write error for $inst : $($_.Exception.Message)" } } } else { "Could not detect COM for $inst; PortName not written." | Tee-Object -FilePath $logFile -Append } } else { $currPort = (Get-ItemProperty -Path $dpStr -Name 'PortName' -ErrorAction SilentlyContinue).PortName "PortName already present at $($dpStr): $($currPort) - not changed" | Tee-Object -FilePath $logFile -Append } # Force-selective-suspend writes if missing or not 0 $toForce = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 } foreach ($kv in $toForce.GetEnumerator { $name = $kv.Key; $desired = [int]$kv.Value try { $existingVal = (Get-ItemProperty -Path $dpStr -Name $name -ErrorAction SilentlyContinue).$name } catch { $existingVal = $null } $needWrite = $false if ($existingVal -eq $null) { $needWrite = $true } else { try { if ([int]$existingVal -ne $desired) { $needWrite = $true } } catch { $needWrite = $true } } if ($needWrite) { if ($WhatIf) { "WhatIf: would set $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name $name -PropertyType DWord -Value $desired -Force -ErrorAction Stop | Out-Null "WROTE $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing $($name) at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "Write $($name) error for $inst : $($_.Exception.Message)" } } } else { "$($name) already = $existingVal at $($dpStr) - not changed" | Tee-Object -FilePath $logFile -Append } } # ConfigData: ensure first 4 bytes are 01 00 3F 3F try { $cfgRaw = $null try { $cfgRaw = (Get-ItemProperty -Path $dpStr -Name 'ConfigData' -ErrorAction SilentlyContinue).ConfigData } catch { $cfgRaw = $null } } catch { $cfgRaw = $null } if ($cfgRaw -ne $null) { if ($cfgRaw -is [byte[]) { $bytes = [byte[]$cfgRaw $origType = 'Binary' } elseif ($cfgRaw -is [int] -or $cfgRaw -is [uint32] -or $cfgRaw -is [long]) { $bytes = [BitConverter]::GetBytes([uint32]$cfgRaw) $origType = 'DWord' } else { try { $bytes = [byte[]$cfgRaw; $origType='Binary' } catch { $bytes = @; $origType='Unknown' } } } else { # not present -> create empty array (we'll pad to 4) $bytes = @ $origType = 'Missing' } if ($bytes.Length -lt 4) { $newBytes = New-Object byte[] 4 if ($bytes.Length -gt 0) { $bytes.CopyTo($newBytes,0) } $bytes = $newBytes } $needCfgWrite = $false for ($i=0; $i -lt 4; $i++) { if ($bytes[$i] -ne $desiredBytes[$i]) { $needCfgWrite = $true; break } } if ($needCfgWrite) { for ($i=0; $i -lt 4; $i++) { $bytes[$i] = $desiredBytes[$i] } if ($WhatIf) { "WhatIf: would update ConfigData first 4 bytes at $($dpStr) (orig type: $origType)" | Tee-Object -FilePath $logFile -Append } else { try { if ($origType -eq 'DWord') { $newDword = [BitConverter]::ToUInt32($bytes,0) New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'ConfigData' -PropertyType DWord -Value $newDword -Force -ErrorAction Stop | Out-Null "WROTE ConfigData (DWORD) = 0x$([Convert]::ToString($newDword,16).ToUpper at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { New-Item -Path $dpStr -Force | Out-Null Set-ItemProperty -Path $dpStr -Name 'ConfigData' -Value $bytes -ErrorAction Stop "WROTE ConfigData (Binary) first 4 bytes updated at $($dpStr)" | Tee-Object -FilePath $logFile -Append } $createdCount++ } catch { "ERROR writing ConfigData at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "ConfigData write error for $inst : $($_.Exception.Message)" } } } else { "ConfigData first 4 bytes already match desired pattern at $($dpStr) (no change)." | Tee-Object -FilePath $logFile -Append } break } else { "Not found: $($dpStr)" | Tee-Object -FilePath $logFile -Append } } if (-not $dpFoundForInstance) { "No Device Parameters found for instance $inst (expected path: $regPathBase). Skipping." | Tee-Object -FilePath $logFile -Append } } # end foreach ports "Created/changed count: $createdCount" | Tee-Object -FilePath $logFile -Append
- Dry-run first:
PowerShell -ExecutionPolicy Bypass -File .\Disable_Selective_Suspend.ps1 -WhatIf - Then run for real (no -WhatIf). If you want no automatic reboot, add -NoReboot.
- If you see Access Denied writing under Enum, run as SYSTEM (scheduled task) or use the INF AddReg approach.
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #113
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:41 char:46
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:157 char:31
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:158 char:26
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:164 char:32
- Joined
- Mar 14, 2023
- Messages
- 97,506
Thanks — those parse errors are from a few bad/missing square brackets when the file was saved (common when copying). I fixed the exact mistakes and included a clean, syntactically-correct script below.
What to do
If you still get the bracket parse errors after saving this exact file, two likely causes:
What to do
- Save the whole script below to C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1 (overwrite the current file).
- Use Notepad (Run as Administrator) or your editor and make sure file encoding is UTF8 (no BOM is fine).
- Verify parse only (won't execute):
powershell -NoProfile -Command "[scriptblock]::Create((Get-Content -Raw 'C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1'); Write-Output 'Parse OK'" - Dry run:
powershell -ExecutionPolicy Bypass -File 'C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1' -WhatIf - If dry run looks correct, run without -WhatIf (optionally add -NoReboot).
$errors = @
- Smart quotes or non-ASCII characters got injected — open the file and ensure all quotes and brackets are standard ASCII.
- The editor truncated lines — open and visually confirm the lines around the $desiredBytes and ConfigData section match the script above.
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #115
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:147 char:31
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:148 char:26
At C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1:154 char:32
- Joined
- Mar 14, 2023
- Messages
- 97,506
Thanks — I fixed the bracket mistakes and prepared a safe overwrite so you don’t have to edit the file manually.
Please run the following in an elevated PowerShell (Run as Administrator). It will overwrite C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1 with a corrected, parse‑clean script, then print "WROTE SCRIPT". After that I show the command to verify parsing (won’t execute the script).
1) Paste & run (elevated) — this writes the corrected script file:
$script = @'
[switch]$WhatIf,
[switch]$NoReboot)
exit 1
$logFile = Join-Path $env:USERPROFILE ("Desktop\Disable_SelectiveSuspend$timestamp.log")
try {
$sp = Get-CimInstance -ClassName Win32SerialPort -ErrorAction SilentlyContinue | Where-Object { $.PNPDeviceID -eq $instanceId }
$tail = ($instanceId -split '\')[-1]
if ($tail) {
$sp = Get-CimInstance -ClassName Win32SerialPort -ErrorAction SilentlyContinue | Where-Object { $.PNPDeviceID -like "$tail" }
} catch { }
return $null
Where-Object { ($.Manufacturer -and $.Manufacturer -like 'FTDI') -or ($.InstanceId -and $.InstanceId -match 'VID_0403') }
exit 0
$createdCount = 0
$errors = @
} catch {
} else {
Set-Content -Path 'C:\Users\spencer.besenski\Documents\Disable_Selective_Suspend.ps1' -Value $script -Encoding UTF8
Write-Output 'WROTE SCRIPT'
2) Parse-check (no execution)
Run this to ensure the file parses:
If you see "Parse OK", run a dry run:
If anything still errors, paste the exact new console error output and I’ll patch immediately.
$script = @'
[switch]$WhatIf,
[switch]$NoReboot)
ensure elevated
if (-not ([Security.Principal.WindowsPrincipal] [Security.Principal.WindowsIdentity]::GetCurrent.IsInRole([Security.Principal.WindowsBuiltinRole]::Administrator) {Write-Error "This script must be run as Administrator. Exiting."
exit 1
try {
if ($tail) {
} catch { }
return $null
$desiredBytes = [byte[] (0x01,0x00,0x3F,0x3F)corresponding little-endian DWORD
$desiredDword = [uint32]0x3F3F0001Find FTDI COM ports
$ports = Get-PnpDevice -Class Ports -PresentOnly -ErrorAction SilentlyContinue |Where-Object { ($.Manufacturer -and $.Manufacturer -like 'FTDI') -or ($.InstanceId -and $.InstanceId -match 'VID_0403') }
exit 0
$createdCount = 0
$errors = @
try {"Launching device rescan (pnputil /scan-devices) in background" | Tee-Object -FilePath $logFile -Append
} catch {
} else {
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #117
Please give me the full script
- Joined
- Mar 14, 2023
- Messages
- 97,506
Here is the full, corrected script you asked for. It:
Script:
If you want, I can also:
- Force‑writes the four selective‑suspend DWORDs when missing or not already 0,
- Keeps PortName behavior (only writes if missing),
- Reads ConfigData and ensures the first 4 bytes are 01 00 3F 3F (updates only those bytes, preserving the rest; writes as REG_DWORD if original was a DWORD, otherwise as REG_BINARY),
- Launches pnputil /scan-devices in the background (non‑blocking),
- Optionally schedules a reboot if any real changes were made (unless you pass -NoReboot),
- Supports -WhatIf (dry run).
Script:
#> param( [switch]$WhatIf, [switch]$NoReboot) # require elevation
$desiredBytes = [byte[](0x01,0x00,0x3F,0x3F)
$errors = @
$processedDp = @{} # avoid reprocessing same DP foreach ($p in $ports) { "----" | Tee-Object -FilePath $logFile -Append "Device FriendlyName: $($p.FriendlyName)" | Tee-Object -FilePath $logFile -Append "InstanceId: $($p.InstanceId)" | Tee-Object -FilePath $logFile -Append $inst = $p.InstanceId if ([string]::IsNullOrWhiteSpace($inst) { "InstanceId empty; skipping" | Tee-Object -FilePath $logFile -Append; continue } $regPathBase = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst" $dpCandidates = @("$regPathBase\Device Parameters","$regPathBase\0000\Device Parameters") $dpFoundForInstance = $false foreach ($dp in $dpCandidates) { $dpStr = [string]$dp "Checking: $dpStr" | Tee-Object -FilePath $logFile -Append if ($processedDp.ContainsKey($dpStr) { "Already processed $dpStr this run - skipping." | Tee-Object -FilePath $logFile -Append $dpFoundForInstance = $true break } if (Test-Path $dpStr) { $dpFoundForInstance = $true "Using Device Parameters: $($dpStr)" | Tee-Object -FilePath $logFile -Append $processedDp[$dpStr] = $true # Read existing properties try { $item = Get-ItemProperty -Path $dpStr -ErrorAction SilentlyContinue $existingProps = if ($item) { $item.PSObject.Properties | ForEach-Object { $_.Name } } else { @ } } catch { $existingProps = @ } # PortName: write only if missing if (-not ($existingProps -contains 'PortName') { $friendly = $p.FriendlyName $detectedCom = $null if ($friendly -and ($friendly -match '\(COM(\d+)\)') { $detectedCom = "COM$($matches[1])" "Detected COM from FriendlyName: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } else { $detectedCom = Get-ComForInstance -instanceId $inst if ($detectedCom) { "Detected COM via WMI: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } } if ($detectedCom) { if ($WhatIf) { "WhatIf: would write PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'PortName' -PropertyType String -Value $detectedCom -Force -ErrorAction Stop | Out-Null "WROTE PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing PortName at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "PortName write error for $inst : $($_.Exception.Message)" } } } else { "Could not detect COM for $inst; PortName not written." | Tee-Object -FilePath $logFile -Append } } else { $currPort = (Get-ItemProperty -Path $dpStr -Name 'PortName' -ErrorAction SilentlyContinue).PortName "PortName already present at $($dpStr): $($currPort) - not changed" | Tee-Object -FilePath $logFile -Append } # Force-selective-suspend writes if missing or not 0 $toForce = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 } foreach ($kv in $toForce.GetEnumerator { $name = $kv.Key; $desired = [int]$kv.Value try { $existingVal = (Get-ItemProperty -Path $dpStr -Name $name -ErrorAction SilentlyContinue).$name } catch { $existingVal = $null } $needWrite = $false if ($existingVal -eq $null) { $needWrite = $true } else { try { if ([int]$existingVal -ne $desired) { $needWrite = $true } } catch { $needWrite = $true } } if ($needWrite) { if ($WhatIf) { "WhatIf: would set $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name $name -PropertyType DWord -Value $desired -Force -ErrorAction Stop | Out-Null "WROTE $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing $($name) at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "Write $($name) error for $inst : $($_.Exception.Message)" } } } else { "$($name) already = $existingVal at $($dpStr) - not changed" | Tee-Object -FilePath $logFile -Append } } # ConfigData: ensure first 4 bytes are 01 00 3F 3F try { $cfgRaw = $null try { $cfgRaw = (Get-ItemProperty -Path $dpStr -Name 'ConfigData' -ErrorAction SilentlyContinue).ConfigData } catch { $cfgRaw = $null } } catch { $cfgRaw = $null } if ($cfgRaw -ne $null) { if ($cfgRaw -is [byte[]) { $bytes = [byte[]$cfgRaw $origType = 'Binary' } elseif ($cfgRaw -is [int] -or $cfgRaw -is [uint32] -or $cfgRaw -is [long]) { $bytes = [BitConverter]::GetBytes([uint32]$cfgRaw) $origType = 'DWord' } else { try { $bytes = [byte[]$cfgRaw; $origType='Binary' } catch { $bytes = @; $origType='Unknown' } } } else { # not present -> create empty array (we'll pad to 4) $bytes = @ $origType = 'Missing' } if ($bytes.Length -lt 4) { $newBytes = New-Object byte[] 4 if ($bytes.Length -gt 0) { $bytes.CopyTo($newBytes,0) } $bytes = $newBytes } $needCfgWrite = $false for ($i=0; $i -lt 4; $i++) { if ($bytes[$i] -ne $desiredBytes[$i]) { $needCfgWrite = $true; break } } if ($needCfgWrite) { for ($i=0; $i -lt 4; $i++) { $bytes[$i] = $desiredBytes[$i] } if ($WhatIf) { "WhatIf: would update ConfigData first 4 bytes at $($dpStr) (orig type: $origType)" | Tee-Object -FilePath $logFile -Append } else { try { if ($origType -eq 'DWord') { $newDword = [BitConverter]::ToUInt32($bytes,0) New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'ConfigData' -PropertyType DWord -Value $newDword -Force -ErrorAction Stop | Out-Null "WROTE ConfigData (DWORD) = 0x$([Convert]::ToString($newDword,16).ToUpper at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { New-Item -Path $dpStr -Force | Out-Null Set-ItemProperty -Path $dpStr -Name 'ConfigData' -Value $bytes -ErrorAction Stop "WROTE ConfigData (Binary) first 4 bytes updated at $($dpStr)" | Tee-Object -FilePath $logFile -Append } $createdCount++ } catch { "ERROR writing ConfigData at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "ConfigData write error for $inst : $($_.Exception.Message)" } } } else { "ConfigData first 4 bytes already match desired pattern at $($dpStr) (no change)." | Tee-Object -FilePath $logFile -Append } break } else { "Not found: $($dpStr)" | Tee-Object -FilePath $logFile -Append } } if (-not $dpFoundForInstance) { "No Device Parameters found for instance $inst (expected path: $regPathBase). Skipping." | Tee-Object -FilePath $logFile -Append } } # end foreach ports "Created/changed count: $createdCount" | Tee-Object -FilePath $logFile -Append
- Provide the single PowerShell command to overwrite your existing file automatically, or
- Produce a variant that also toggles (disable/enable) each device to force immediate refresh of Device Manager (requires Disable-PnpDevice/Enable-PnpDevice and may briefly disconnect ports).
sjbesenski
Member
- Joined
- Nov 21, 2025
- Messages
- 71
- Thread Author
- #119
Cannot index into a null array.
At C:\Users\kioskuser2\Documents\Disable_FTDI_Selective_Suspend.ps1:185 char:40
+ ... ($i=0; $i -lt 4; $i++) { if ($bytes[$i] -ne $desiredBytes[$i]) { $nee ...
+ CategoryInfo : InvalidOperation: ) [], RuntimeException
+ FullyQualifiedErrorId : NullArray
- Joined
- Mar 14, 2023
- Messages
- 97,506
Thanks — that error means $bytes was $null when the script tried to index it. I fixed the ConfigData handling so $bytes is always a valid byte[] (and padded to at least 4 bytes) before any indexing or comparison.
Below is the full corrected script. Save it over your current Disable_FTDI_Selective_Suspend.ps1 and run elevated. Start with -WhatIf to dry‑run.
Corrected script (full):
If you still see the null‑array error after saving and running this exact script, paste the exact command you used to run it and the full console output (I’ll debug immediately).
$errors = @
$processedDp = @{} # avoid reprocessing same DP foreach ($p in $ports) { "----" | Tee-Object -FilePath $logFile -Append "Device FriendlyName: $($p.FriendlyName)" | Tee-Object -FilePath $logFile -Append "InstanceId: $($p.InstanceId)" | Tee-Object -FilePath $logFile -Append $inst = $p.InstanceId if ([string]::IsNullOrWhiteSpace($inst) { "InstanceId empty; skipping" | Tee-Object -FilePath $logFile -Append; continue } $regPathBase = "HKLM:\SYSTEM\CurrentControlSet\Enum\$inst" $dpCandidates = @("$regPathBase\Device Parameters","$regPathBase\0000\Device Parameters") $dpFoundForInstance = $false foreach ($dp in $dpCandidates) { $dpStr = [string]$dp "Checking: $dpStr" | Tee-Object -FilePath $logFile -Append if ($processedDp.ContainsKey($dpStr) { "Already processed $dpStr this run - skipping." | Tee-Object -FilePath $logFile -Append $dpFoundForInstance = $true break } if (Test-Path $dpStr) { $dpFoundForInstance = $true "Using Device Parameters: $($dpStr)" | Tee-Object -FilePath $logFile -Append $processedDp[$dpStr] = $true # Read existing properties try { $item = Get-ItemProperty -Path $dpStr -ErrorAction SilentlyContinue $existingProps = if ($item) { $item.PSObject.Properties | ForEach-Object { $_.Name } } else { @ } } catch { $existingProps = @ } # PortName: write only if missing if (-not ($existingProps -contains 'PortName') { $friendly = $p.FriendlyName $detectedCom = $null if ($friendly -and ($friendly -match '\(COM(\d+)\)') { $detectedCom = "COM$($matches[1])" "Detected COM from FriendlyName: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } else { $detectedCom = Get-ComForInstance -instanceId $inst if ($detectedCom) { "Detected COM via WMI: $($detectedCom)" | Tee-Object -FilePath $logFile -Append } } if ($detectedCom) { if ($WhatIf) { "WhatIf: would write PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'PortName' -PropertyType String -Value $detectedCom -Force -ErrorAction Stop | Out-Null "WROTE PortName = $($detectedCom) at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing PortName at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "PortName write error for $inst : $($_.Exception.Message)" } } } else { "Could not detect COM for $inst; PortName not written." | Tee-Object -FilePath $logFile -Append } } else { $currPort = (Get-ItemProperty -Path $dpStr -Name 'PortName' -ErrorAction SilentlyContinue).PortName "PortName already present at $($dpStr): $($currPort) - not changed" | Tee-Object -FilePath $logFile -Append } # Force-selective-suspend writes if missing or not 0 $toForce = @{ DeviceIdleEnabled = 0; DefaultIdleState = 0; UserSetDeviceIdleEnabled = 0; SSIdleTimeout = 0 } foreach ($kv in $toForce.GetEnumerator { $name = $kv.Key; $desired = [int]$kv.Value try { $existingVal = (Get-ItemProperty -Path $dpStr -Name $name -ErrorAction SilentlyContinue).$name } catch { $existingVal = $null } $needWrite = $false if ($existingVal -eq $null) { $needWrite = $true } else { try { if ([int]$existingVal -ne $desired) { $needWrite = $true } } catch { $needWrite = $true } } if ($needWrite) { if ($WhatIf) { "WhatIf: would set $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { try { New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name $name -PropertyType DWord -Value $desired -Force -ErrorAction Stop | Out-Null "WROTE $($name) = $desired at $($dpStr)" | Tee-Object -FilePath $logFile -Append $createdCount++ } catch { "ERROR writing $($name) at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "Write $($name) error for $inst : $($_.Exception.Message)" } } } else { "$($name) already = $existingVal at $($dpStr) - not changed" | Tee-Object -FilePath $logFile -Append } } # ConfigData: ensure first 4 bytes are 01 00 3F 3F # Read raw value (may be binary or dword) $cfgRaw = $null try { $cfgRaw = (Get-ItemProperty -Path $dpStr -Name 'ConfigData' -ErrorAction SilentlyContinue).ConfigData } catch { $cfgRaw = $null } # Normalize to a byte[] safely $bytes = $null $origType = 'Missing' if ($cfgRaw -ne $null) { if ($cfgRaw -is [byte[]) { $bytes = [byte[]$cfgRaw $origType = 'Binary' } elseif ($cfgRaw -is [int] -or $cfgRaw -is [uint32] -or $cfgRaw -is [long]) { $bytes = [BitConverter]::GetBytes([uint32]$cfgRaw) $origType = 'DWord' } else { try { $bytes = [byte[]$cfgRaw; $origType='Binary' } catch { $bytes = New-Object byte[] 0; $origType='Unknown' } } } else { $bytes = New-Object byte[] 0 $origType = 'Missing' } # Ensure we have at least 4 bytes (pad with zeros if necessary) if ($null -eq $bytes) { $bytes = New-Object byte[] 4 } if ($bytes.Length -lt 4) { $newBytes = New-Object byte[] 4 if ($bytes.Length -gt 0) { [System.Array]::Copy($bytes, 0, $newBytes, 0, $bytes.Length) } $bytes = $newBytes } $needCfgWrite = $false for ($i=0; $i -lt 4; $i++) { if ($bytes[$i] -ne $desiredBytes[$i]) { $needCfgWrite = $true; break } } if ($needCfgWrite) { for ($i=0; $i -lt 4; $i++) { $bytes[$i] = $desiredBytes[$i] } if ($WhatIf) { "WhatIf: would update ConfigData first 4 bytes at $($dpStr) (orig type: $origType)" | Tee-Object -FilePath $logFile -Append } else { try { if ($origType -eq 'DWord') { $newDword = [BitConverter]::ToUInt32($bytes,0) New-Item -Path $dpStr -Force | Out-Null New-ItemProperty -Path $dpStr -Name 'ConfigData' -PropertyType DWord -Value $newDword -Force -ErrorAction Stop | Out-Null "WROTE ConfigData (DWORD) = 0x$([Convert]::ToString($newDword,16).ToUpper at $($dpStr)" | Tee-Object -FilePath $logFile -Append } else { New-Item -Path $dpStr -Force | Out-Null Set-ItemProperty -Path $dpStr -Name 'ConfigData' -Value $bytes -ErrorAction Stop "WROTE ConfigData (Binary) first 4 bytes updated at $($dpStr)" | Tee-Object -FilePath $logFile -Append } $createdCount++ } catch { "ERROR writing ConfigData at $($dpStr) : $($_.Exception.Message)" | Tee-Object -FilePath $logFile -Append $errors += "ConfigData write error for $inst : $($_.Exception.Message)" } } } else { "ConfigData first 4 bytes already match desired pattern at $($dpStr) (no change)." | Tee-Object -FilePath $logFile -Append } break } else { "Not found: $($dpStr)" | Tee-Object -FilePath $logFile -Append } } if (-not $dpFoundForInstance) { "No Device Parameters found for instance $inst (expected path: $regPathBase). Skipping." | Tee-Object -FilePath $logFile -Append } } # end foreach ports "Created/changed count: $createdCount" | Tee-Object -FilePath $logFile -Append
try { "Launching device rescan: pnputil /scan-devices (background)" | Tee-Object -FilePath $logFile -Append $proc = Start-Process -FilePath 'pnputil.exe' -ArgumentList '/scan-devices' -NoNewWindow -PassThru "pnputil started (PID $($proc.Id)" | Tee-Object -FilePath $logFile -Append
Similar threads
- Article
- Replies
- 0
- Views
- 19
- Article
- Replies
- 0
- Views
- 32
- Article
- Replies
- 0
- Views
- 113
- Replies
- 0
- Views
- 50
- Article
- Replies
- 0
- Views
- 43
