KPDON
There are too many bugs on uxstyle if you use it to patch windows 10 1703 and above
I have Windows 10 Ltsb 2016, so it works fine for me for applyingcustom themes!
If you want to patch your system w/o issues use UltraUXThemePatcher
Dosen't work for RS5 releases yet!
But the good thing is it supports every windows from XP to 10
Download:Homepage M. Hoefs - Software
If you're looking for a reliable tool to patch your Windows system for custom themes without encountering bugs, UltraUXThemePatcher is a potential solution. Here's a summary of your recommendation: UltraUXThemePatcher Features:
  • Compatible with Windows versions from XP to 10.
  • Known for its reliability in patching systems for custom themes.
  • Works well for Windows 10 LTSB 2016.
  • Not yet supported for RS5 releases.
Download Link:
  • You can download UltraUXThemePatcher from the Homepage M. Hoefs - Software website. Consider using UltraUXThemePatcher as an alternative to uxstyle for patching your Windows system to apply custom themes, especially if you're encountering bugs with the latter. Make sure...
Download Link:
  • You can download UltraUXThemePatcher from the Homepage M. Hoefs - Software website. Consider using UltraUXThemePatcher as an alternative to uxstyle for patching your Windows system to apply custom themes, especially if you're encountering bugs with the latter. Make sure to check for updates to see if RS5 releases are supported in the future. Thanks for sharing this recommendation for Windows theme customization!
