Miguel
Hi all :)!
Hi have a problem that it is stalking me.
I have a machine with Windows 7 Professional with Virtual PC installed, the last time I used it (with XP Mode) it worked perfectly, but now when I execute Virtual PC nothing happens, but the process shows up in the task manager.
The same thing happened to me a few months ago (with 7 Ultimate), and the solution was reinstalling windows.
Already tried system restore and reinstalling Virtual PC, both did not work.
What could it be?
Ok, I fixed it :).
Removed some applications on msconfig and now it works :).
For those who may have the same problem, I removed from startup Daemon tools, some HP Printer software, Java, Adobe Reader, webcam and mouse software.
Do some searching. I just read about using XP mode on Home Premium edition using VMware player which is free.
Joe
Thanks for replying :)
I know about that, but I just wanted to Virtual PC to work again :(
Hi and welcome to the forums.
Check MS Virtual PC in the icon tray area.
Ok, I fixed it :).
