052310-17955-01.dmp
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\DD\AA\Minidump\052310-17955-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02a1d000 PsLoadedModuleList = 0xfffff800`02c5ae50
Debug session time: Sun May 23 19:26:10.499 2010 (GMT+3)
System Uptime: 0 days 7:45:04.383
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck A, {44428c40694d, 2, 0, fffff80002b3fa8f}
Probably caused by : memory_corruption ( nt!MiIdentifyPfn+23f )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
interrupt request level (IRQL) that is too high. This is usually
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 000044428c40694d, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002b3fa8f, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc50e0
000044428c40694d
CURRENT_IRQL: 2
FAULTING_IP:
fffff800`02b3fa8f 4c8b7500 mov r14,qword ptr [rbp]
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffff880077db4b0 -- (.trap 0xfffff880077db4b0)
rax=0000000000000005 rbx=0000000000000000 rcx=0600000000000020
rdx=000000000002aaaa rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002b3fa8f rsp=fffff880077db640 rbp=000044428c40694d
r8=000000000002aab2 r9=0000000000000001 r10=0000000000000042
r11=0000058000000000 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na po nc
nt!MiIdentifyPfn+0x23f:
fffff800`02b3fa8f 4c8b7500 mov r14,qword ptr [rbp] ss:0018:00004442`8c40694d=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002a8e469 to fffff80002a8ef00
STACK_TEXT:
fffff880`077db368 fffff800`02a8e469 : 00000000`0000000a 00004442`8c40694d 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`077db370 fffff800`02a8d0e0 : 00000000`42506650 0a050a04`39080411 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`077db4b0 fffff800`02b3fa8f : 00000000`00000000 02000000`00117bcb 00000000`000018c0 fffff800`02d53c8f : nt!KiPageFault+0x260
fffff880`077db640 fffff800`02b4076b : 00000000`00000000 00000000`00000004 fffffa80`049b0778 fffffa80`049b0000 : nt!MiIdentifyPfn+0x23f
fffff880`077db6e0 fffff800`02ea00f5 : fffffa80`049b0000 fffff880`077dbc60 fffff880`077db7b8 00000000`00000000 : nt!MmQueryPfnList+0xbb
fffff880`077db720 fffff800`02de4f78 : 00000000`00000006 00000000`00000000 fffffa80`049b0000 fffff800`02a1d001 : nt!PfpPfnPrioRequest+0x115
fffff880`077db770 fffff800`02d89cb3 : 00000000`00000000 fffff800`02a1d000 fffffa80`06098000 00000000`00000201 : nt! ?? ::NNGAKEGL::`string'+0x4853d
fffff880`077db800 fffff800`02d8ae49 : 00000000`01a1bb68 00000000`00000001 00000000`01a1bbc0 00000000`02f68f08 : nt!ExpQuerySystemInformation+0x11c2
fffff880`077dbba0 fffff800`02a8e153 : 00000000`00000000 00000000`02f9f4e0 00000000`02f9f401 00000000`01a1c8c0 : nt!NtQuerySystemInformation+0x4d
fffff880`077dbbe0 00000000`77c2021a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`01a1ba98 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77c2021a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiIdentifyPfn+23f
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc600
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiIdentifyPfn+23f
052310-21122-01.dmp
Loading Dump File [F:\DD\AA\Minidump\052310-21122-01.dmp]
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`02a05000 PsLoadedModuleList = 0xfffff800`02c42e50
Debug session time: Mon May 24 00:51:44.752 2010 (GMT+3)
System Uptime: 0 days 0:13:46.012
BugCheck 1E, {ffffffffc0000005, fffff80002a9aa5f, 0, ffffffffffffffff}
Probably caused by : memory_corruption ( nt!MiReplenishPageSlist+100 )
3: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002a9aa5f, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
fffff800`02a9aa5f f00fba6b1000 lock bts dword ptr [rbx+10h],0
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cad0e0
ffffffffffffffff
BUGCHECK_STR: 0x1E
PROCESS_NAME: dinotify.exe
CURRENT_IRQL: 2
EXCEPTION_RECORD: fffff88004f1d5d8 -- (.exr 0xfffff88004f1d5d8)
ExceptionAddress: fffff80002a9aa5f (nt!MiReplenishPageSlist+0x0000000000000100)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME: fffff88004f1d680 -- (.trap 0xfffff88004f1d680)
rax=fffffa8000000000 rbx=0000000000000000 rcx=fdffffffffffffff
rdx=000000000000004f rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002a9aa5f rsp=fffff88004f1d810 rbp=fffffa8004200708
r8=fffff80002caf400 r9=fffffa8004200000 r10=fffffa8004200728
r11=fffff88004f1d868 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na pe nc
nt!MiReplenishPageSlist+0x100:
fffff800`02a9aa5f f00fba6b1000 lock bts dword ptr [rbx+10h],0 ds:f000:00000000`00000010=????????
LAST_CONTROL_TRANSFER: from fffff80002aaf929 to fffff80002a75600
STACK_TEXT:
fffff880`04f1ce08 fffff800`02aaf929 : 00000000`0000001e ffffffff`c0000005 fffff800`02a9aa5f 00000000`00000000 : nt!KeBugCheckEx
fffff880`04f1ce10 fffff800`02a74c42 : fffff880`04f1d5d8 fffef280`00000000 fffff880`04f1d680 00000000`0000000b : nt!KiDispatchException+0x1b9
fffff880`04f1d4a0 fffff800`02a7354a : fffffa80`07587a18 fffffa80`07587800 fffffa80`00000104 00000000`001ca000 : nt!KiExceptionDispatch+0xc2
fffff880`04f1d680 fffff800`02a9aa5f : fffff880`00001000 fffff880`00000104 fffffa80`057919f0 00000000`0009bc00 : nt!KiGeneralProtectionFault+0x10a
fffff880`04f1d810 fffff800`02a9af8f : fffff800`02caf400 00000000`0000002d fffffa80`00868470 fffffa80`00806070 : nt!MiReplenishPageSlist+0x100
fffff880`04f1d870 fffff800`02a93197 : 00000000`00000002 fffff880`00000002 fffffa80`07587b98 00000000`00000002 : nt!MiRemoveAnyPage+0x24f
fffff880`04f1d990 fffff800`02a8f8a6 : 00000000`00000001 00000000`00306000 fffff880`04f1dbe0 fffff680`00001830 : nt!MiResolveDemandZeroFault+0x577
fffff880`04f1da80 fffff800`02a736ee : 00000000`00000001 00000000`00000000 00000000`77b93501 fffffa80`00000000 : nt!MmAccessFault+0x5c6
fffff880`04f1dbe0 00000000`77ab1afe : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`001cd268 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77ab1afe
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: nt!MiReplenishPageSlist+100
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4b88cfeb
FAILURE_BUCKET_ID: X64_0x1E_nt!MiReplenishPageSlist+100
052410-17191-01.dmp
Loading Dump File [F:\DD\AA\Minidump\052410-17191-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a1f000 PsLoadedModuleList = 0xfffff800`02c5ce50
Debug session time: Mon May 24 09:59:14.596 2010 (GMT+3)
System Uptime: 0 days 0:27:45.075
BugCheck 1E, {ffffffffc0000005, fffff80002ab4a5f, 0, ffffffffffffffff}
0: kd> !analyze -v
Arguments:
Arg2: fffff80002ab4a5f, The address that the exception occurred at
Debugging Details:
FAULTING_IP:
fffff800`02ab4a5f f00fba6b1000 lock bts dword ptr [rbx+10h],0
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc70e0
ffffffffffffffff
BUGCHECK_STR: 0x1E
PROCESS_NAME: chrome.exe
CURRENT_IRQL: 2
EXCEPTION_RECORD: fffff88009c386c8 -- (.exr 0xfffff88009c386c8)
ExceptionAddress: fffff80002ab4a5f (nt!MiReplenishPageSlist+0x0000000000000100)
NumberParameters: 2
TRAP_FRAME: fffff88009c38770 -- (.trap 0xfffff88009c38770)
rip=fffff80002ab4a5f rsp=fffff88009c38900 rbp=fffffa80042003c0
r8=fffff80002cc9400 r9=fffffa8004200000 r10=fffffa80042003e0
r11=fffff88009c38958 r12=0000000000000000 r13=0000000000000000
fffff800`02ab4a5f f00fba6b1000 lock bts dword ptr [rbx+10h],0 ds:00000000`00000010=????????
LAST_CONTROL_TRANSFER: from fffff80002ac9929 to fffff80002a8f600
STACK_TEXT:
fffff880`09c37ef8 fffff800`02ac9929 : 00000000`0000001e ffffffff`c0000005 fffff800`02ab4a5f 00000000`00000000 : nt!KeBugCheckEx
fffff880`09c37f00 fffff800`02a8ec42 : fffff880`09c386c8 fffef280`00000000 fffff880`09c38770 00000000`0000000b : nt!KiDispatchException+0x1b9
fffff880`09c38590 fffff800`02a8d54a : 00000000`00000006 00000000`00000000 fffff800`02bc4205 fffff800`02a9b202 : nt!KiExceptionDispatch+0xc2
fffff880`09c38770 fffff800`02ab4a5f : 00000ecf`000000c8 00000000`6d646156 00000000`00000000 fffff960`00094db4 : nt!KiGeneralProtectionFault+0x10a
fffff880`09c38900 fffff800`02ab4f8f : fffff800`02cc9400 00000000`00000018 fffffa80`003ff480 fffffa80`00410880 : nt!MiReplenishPageSlist+0x100
fffff880`09c38960 fffff800`02aaa97a : fffff680`000290a8 00000000`00000002 00000000`00000000 ffffffff`ffffffff : nt!MiRemoveAnyPage+0x24f
fffff880`09c38a80 fffff800`02a8d6ee : 00000000`00000001 00000000`0000001a 00000000`00000001 fffffa80`071f68f0 : nt!MmAccessFault+0x169a
fffff880`09c38be0 00000000`6bd737ed : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`0030e990 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x6bd737ed
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
052510-16863-01.dmp
Loading Dump File [F:\DD\AA\Minidump\052510-16863-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a0f000 PsLoadedModuleList = 0xfffff800`02c4ce50
Debug session time: Wed May 26 01:10:41.410 2010 (GMT+3)
System Uptime: 0 days 6:15:37.361
BugCheck 1E, {ffffffffc0000005, fffff80002aa4a5f, 0, ffffffffffffffff}
1: kd> !analyze -v
Arguments:
Arg2: fffff80002aa4a5f, The address that the exception occurred at
Debugging Details:
FAULTING_IP:
fffff800`02aa4a5f f00fba6b1000 lock bts dword ptr [rbx+10h],0
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cb70e0
ffffffffffffffff
BUGCHECK_STR: 0x1E
CURRENT_IRQL: 2
EXCEPTION_RECORD: fffff8800828d6c8 -- (.exr 0xfffff8800828d6c8)
ExceptionAddress: fffff80002aa4a5f (nt!MiReplenishPageSlist+0x0000000000000100)
NumberParameters: 2
TRAP_FRAME: fffff8800828d770 -- (.trap 0xfffff8800828d770)
rip=fffff80002aa4a5f rsp=fffff8800828d900 rbp=fffffa80042006e0
r8=fffff80002cb9400 r9=fffffa8004200000 r10=fffffa8004200700
r11=fffff8800828d958 r12=0000000000000000 r13=0000000000000000
fffff800`02aa4a5f f00fba6b1000 lock bts dword ptr [rbx+10h],0 ds:00000000`00000010=????????
LAST_CONTROL_TRANSFER: from fffff80002ab9929 to fffff80002a7f600
STACK_TEXT:
fffff880`0828cef8 fffff800`02ab9929 : 00000000`0000001e ffffffff`c0000005 fffff800`02aa4a5f 00000000`00000000 : nt!KeBugCheckEx
fffff880`0828cf00 fffff800`02a7ec42 : fffff880`0828d6c8 fffef280`00000000 fffff880`0828d770 00000000`00000008 : nt!KiDispatchException+0x1b9
fffff880`0828d590 fffff800`02a7d54a : fffffa80`0400a1f0 fffff880`0828d7f0 00000000`00000009 00000000`00000006 : nt!KiExceptionDispatch+0xc2
fffff880`0828d770 fffff800`02aa4a5f : 00000980`00000000 fffffa80`04201480 fffff880`0828dbe0 00000000`0019de20 : nt!KiGeneralProtectionFault+0x10a
fffff880`0828d900 fffff800`02aa4f8f : fffff800`02cb9400 00000000`0000002c fffffa80`01380840 fffffa80`03c91440 : nt!MiReplenishPageSlist+0x100
fffff880`0828d960 fffff800`02a9a97a : fffff680`0003f780 00000000`00000002 00000000`00000000 ffffffff`ffffffff : nt!MiRemoveAnyPage+0x24f
fffff880`0828da80 fffff800`02a7d6ee : 00000000`00000001 00000000`00000030 fffff880`0828db01 fffffa80`04d18e60 : nt!MmAccessFault+0x169a
fffff880`0828dbe0 00000000`68d037dd : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`0040e7f0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x68d037dd
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
