lasswens
I built a pc last friday, and i have only one issue. I have Windows 8.1 64-bit, and when im trying to type something my keyboard starts to open programs. I think they are windows key shortcuts. But anyway my windows key isnt stuck because it works no problem with other computer. Please help with this,how can I fix it!
Sorry, wrong link:..
Try this video:
Which programs are opening and have you run a virus scan?
for example L signs me out, R opens the run window, ENTER opens reader.
and, i have run virus scan and it say nothing
Normally those commands won't run unless you depress the Windows key at the same time. Check this web page from Microsoft which tells you how to disable it:
You could always try using the keyboard in a different USB socket as this can make a difference in some things. What kind of keyboard is it? Does it need drivers ect? What about the new system, is the bios updated and any new firmware updated for drives ect?
I have Steelseries Apex keyboard, and i have just couple minutes ago updated my bios, and now im checking firmware
Hey thanks man! Im currently running firmware update, and I think the problem is gone when its done! Anyway I leave a message when its done!
EDIT: Hey Kemical! Problem is gone and thank you very much for helping me! You are awesome bro! Thanks a lot! See ya in next problem :D
