toolpusher
- Joined
- Nov 9, 2009
Hi
My win 7 quad core PC suddenly started shutting down without warning yesterday. I thought this might be temperature related so downloaded a small utility to monitor fan speeds and CPU temps. I was amazed to see that when idling my intel CPU was up about 50C and when I gave the PC anything to do it steadily increased until the PC shutdown. On investigation I found the fault to be the dreaded dust totally blocking the fins of the heat sink, after a good clean and blow out the CPU temps are now all steady around 40C even when the PC is working hard.
The app I used was less the 2mb in size and surely something similar could have been built into win 7. Not sure how long I have been stressing the CPU needlessly but I am sure I will have taken a few years of its life span. Even a simple alarm in Win 7 telling you your CPU is running hot would do. Maybe its built into Win7 & but not normally activated anyone know?
regards
TP
regards
TP
