Windows 7 win 7 crashed please help
yaronpe
my win 7 is crashed randomly. i can not figure out the problem. the dump file is uttached.please help :(
  • dump.txt
Hi yaronpe and Welcome to The Forum.
Please see: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html Following Method 2:
Download and run the SF Diagnostics Tool.Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.​
Download and run CPU-Z. Take screenshots**/snips of the Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
**If screenshots, please crop.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
The .dmp files are located at C:\Windows\Minidump. Until a .dmp file is generated, the Minidump folder may not exist.
Go to your C:\Windows\Minidump folder. Copy the .dmp files to a new folder on your desktop. Zip up that folder and attach to a post.
