Windows 7 Win7 BSOD drivers possible problem "help"
Jonis19
Hi guys, i am from brazil and my english is weak, sorry.
I have one problem with BSOD, The motherboard is new.
Logs of cpu-z and W7F
  • W7F_13-01-2013.zip
C: and D: drive have little free space. Please maintain 15% free space on each drive (you can get down to 10%, but will find some performance problems then)
Alcohol 120% (and Daemon Tools software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions). I strongly suspect that this hold true for Win8 systems also.
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
Both memory dumps blame Kaspersky. Please:
- download a fresh copy of Microsoft Security Essentials
- un-install your Kaspersky
- install and immediately update the Microsoft Security Essentials; also ensure that the Windows Firewall is activated
- perform a full system scan with Microsoft Security Essentials (in case something got by the malfunctioning Kaspersky)
- monitor for further BSOD's
After the BSOD's stop, feel free to uninstall Microsoft Security Essentials and reinstall the Kaspersky
intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17)
Intel IDE storage driver
http://www.carrona.org/drivers/driver.php?id=intelide.sys
sptd.sys Sat Mar 3 11:42:03 2012 (4F5249DB)
SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Win7)
http://www.carrona.org/drivers/driver.php?id=sptd.sys
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Sun Jan 13 13:09:55.046 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\011313-19858-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x86 compatible
Built by: [B]7601[/B].17944.x86fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 1:04:41.997[/B]
*** WARNING: Unable to verify timestamp for kltdi.sys
*** ERROR: Module load completed but symbols could not be loaded for kltdi.sys
Probably caused by :[B]kltdi.sys ( kltdi+6500 )[/B]
BugCheck [B]D1, {68, 2, 0, 92152500}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 00000068, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 92152500, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]0xD1_kltdi+6500[/B]
CPUID:        "Intel(R) Pentium(R) Dual  CPU  E2160  @ 1.80GHz"
MaxSpeed:     1800
CurrentSpeed: [B]1795[/B]
  BIOS Version                  080015
  BIOS Release Date             02/05/2010
  Manufacturer
  Product Name                  G41T-M7
**************************Sun Jan 13 11:08:48.291 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\011313-20794-01.dmp]
System Uptime:[B]0 days 3:38:48.242[/B]
*** WARNING: Unable to verify timestamp for klif.sys
*** ERROR: Module load completed but symbols could not be loaded for klif.sys
Probably caused by :[B]klif.sys ( klif+6ce7b )[/B]
BugCheck [B]50, {fd04ef00, 1, 8d09ce7b, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fd04ef00, memory referenced.
Arg2: 00000001, value 0 = read operation, 1 = write operation.
Arg3: 8d09ce7b, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 00000002, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]postgres.exe[/B]
FAILURE_BUCKET_ID: [B]0x50_klif+6ce7b[/B]
MaxSpeed:     1800
  BIOS Version                  080015
  Manufacturer
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:11:03 2009 (4A5BBF07)
[COLOR=RED][B]intelide.sys                Mon Jul 13 19:11:19 2009 (4A5BBF17)[/B][/COLOR]
SAFDSKNT.SYS                Mon Dec  7 19:33:59 2009 (4B1D9EF7)
amdxata.sys                 Fri Mar 19 12:19:01 2010 (4BA3A3F5)
ew_jubusenum.sys            Sat Oct  9 02:48:33 2010 (4CB01041)
igdkmd32.sys                Thu Oct 13 15:01:20 2011 (4E973580)
aoosall2.SYS                Wed Dec 28 04:10:21 2011 (4EFADCFD)
[COLOR=RED][B]sptd.sys                    Sat Mar  3 11:42:03 2012 (4F5249DB)[/B][/COLOR]
klim6.sys                   Tue Mar 27 10:34:20 2012 (4F71CFEC)
kl1.sys                     Fri Apr 13 05:54:02 2012 (4F87F7BA)
kltdi.sys                   Sat May 12 09:13:31 2012 (4FAE61FB)
kneps.sys                   Thu May 24 03:32:45 2012 (4FBDE41D)
klmouflt.sys                Fri May 25 11:30:30 2012 (4FBFA596)
klkbdflt.sys                Fri May 25 11:38:42 2012 (4FBFA782)
klflt.sys                   Tue May 29 07:12:42 2012 (4FC4AF2A)
klif.sys                    Tue May 29 07:54:07 2012 (4FC4B8DF)
gbpkm.sys                   Thu Aug 23 18:06:52 2012 (5036A97C)
Rt86win7.sys                Thu Oct 25 05:13:49 2012 (508902CD)
aum0t98k.SYS                Wed Dec 28 04:10:21 2011 (4EFADCFD)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=SAFDSKNT.SYS
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=ew_jubusenum.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd32.sys
aoosall2.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=klim6.sys
http://www.carrona.org/drivers/driver.php?id=kl1.sys
http://www.carrona.org/drivers/driver.php?id=kltdi.sys
http://www.carrona.org/drivers/driver.php?id=kneps.sys
http://www.carrona.org/drivers/driver.php?id=klmouflt.sys
http://www.carrona.org/drivers/driver.php?id=klkbdflt.sys
http://www.carrona.org/drivers/driver.php?id=klflt.sys
http://www.carrona.org/drivers/driver.php?id=klif.sys
gbpkm.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=Rt86win7.sys
aum0t98k.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
