Windows 11 26H1 Bromine Platform: Arm First, Not a General Update
Microsoft’s unexpected 26H1 release is not the next Windows upgrade for your current PC — it’s a device‑specific, hardware‑optimized platform image built to enable next‑generation Arm silicon, and it will ship only on qualifying new machines (most notably Qualcomm’s Snapdragon X2 series) rather than being pushed to existing Intel or AMD systems via Windows Update.
A laptop screen shows a neon schematic of an ARM CPU with stacked NPUs.Background / Overview​
Microsoft’s visible version string jump to Windows 11, version 26H1 (Build 28xxx) in the Canary channel surprised many users and administrators because it broke the familiar H2 annual cadence. The company clarified that 26H1 is a platform release intended for select new devices, not a consumer feature update for the installed base. That distinction is critical: 26H1 is a factory‑flashed image meant to ship with new hardware rather than an in‑place upgrade for the vast majority of PCs.
Put simply, Windows development is running on two parallel tracks in 2026: the ongoing “Germanium” platform line that powers mainstream releases such as 24H2 and 25H2 (and will continue into 26H2 for existing PCs), and a new internal platform baseline — often reported under the Bromine codename — that underpins 26H1 and is engineered specifically for next‑generation Arm systems. Microsoft and partner briefings emphasize that 26H1 “supports device innovations expected in 2026” and will be available only on new devices that ship with select silicon.
This is not a cosmetic rename or a marketing rebrand. It’s a deliberate engineering choice to give OEMs and silicon partners a Windows image that exposes new kernel, scheduler, power, and NPU plumbing tuned to heterogeneous Arm SoCs from day one.
What “platform release” actually means​
The Windows platform core, explained​
When Microsoft refers to a different Windows “core” it is talking about the foundational platform components: the kernel, driver model, process scheduler, hardware abstraction layers, power and thermal governors, and security subsystems. Historically, Windows internal platform branches have had names like Cobalt, Nickel, and Germanium; 26H1’s internal base is widely reported to be a separate branch (Bromine in some reports) developed to match the expectations of new Arm silicon.
A platform release replaces or significantly evolves that foundation. By contrast, the enablement‑package model Microsoft has used recently (e.g., enabling features in 23H2 or 25H2) flips on capabilities already present in the same platform base. 26H1 is not an enablement package — it’s a new plumbing layer that expects different hardware characteristics.
Why a separate platform was necessary​
Modern Arm SoCs are increasingly heterogeneous: multiple core types, integrated NPUs (Neural Processing Units), specialized media blocks, and advanced power management features. Those architectural changes often require low‑level OS support to:
  • Decide which tasks run on performance vs efficiency cores (thread scheduling).
  • Route AI and inference workloads efficiently to on‑chip NPUs.
  • Expose new ACPI or firmware hooks for granular power and thermal control.
  • Provide device certification and driver stacks that are guaranteed out of the box.
Because those plumbing changes are foundational, they can’t be retrofitted onto an existing platform without significant risk to stability and compatibility. Microsoft chose to ship a platform image that is pre‑integrated and validated with the silicon/OEM stack rather than attempting a mass in‑place upgrade.
What’s new in 26H1 — the hands‑on findings​
Although 26H1 is engineered for new hardware and most of its improvements live "under the hood," installations and VM experiments reveal a small set of visible changes and quality‑of‑life improvements that are worth noting. These surface changes are meaningful because they hint at the broader engineering priorities in the Bromine platform even if the biggest benefits will be seen only on supported Arm hardware.
Build and platform identity​
On devices and images examined in early trials, the OS build for the 26H1 branch reports a 28xxx series build (examples in early Canary flights included Build 28020.x). That build identity separates the 26H1 Bromine branch from the Germanium‑based 24H2/25H2 lines and signals a distinct servicing and validation lane.
Natural‑language (semantic) Settings search becomes broadly available​
One of the most tangible changes is a more agentic, semantic search experience in Settings. In 26H1 the Settings search box allows natural‑language queries (for example, “my mouse pointer is too small”) to surface actionable controls directly in the search dropdown — not merely links to a Settings page. This is the kind of UI refinement that reduces friction for non‑power users and aligns with broader Microsoft investments in locally executed agentic behaviors.
A new privacy toggle — “Search the contents of online files” under Privacy & security > Search — gives users granular control over whether Windows Search can index and surface contents of cloud‑hosted files (like those in OneDrive Personal). This addresses practical privacy concerns as on‑device agents and local indexing grow in importance.
FAT32 formatting limit raised to 2 TB​
A long‑standing practical annoyance has been the 32 GB cap in Windows’ command‑line FAT32 formatting tools. In 26H1, the built‑in format command and diskpart accepted FAT32 formatting for much larger volumes — tested up to 100 GB and reported to now support partitions up to 2 TB — removing the need for third‑party utilities when formatting large SD cards or flash drives. That’s a modest but welcome quality‑of‑life fix for photographers, drone users, and others who rely on large removable media.
Legacy UI polish and Setup safeguards​
Microsoft used the 26H1 image to tidy up some legacy UI and setup flows:
  • Storage settings in Settings > System > Storage > Disks & volumes received spacing and padding fixes; “Create volume” now uses rounded corners and an animated chevron consistent with Windows 11 design language.
  • The Windows Setup clean‑install dialogs now include extra confirmation dialogs for destructive actions such as “Delete partition” or “Format partition,” a sensible safeguard missed in some earlier builds.
Deprecations and protective checks​
26H1 also contains a few deliberate removals and stricter checks:
  • .NET Framework 3.5 no longer appears as an optional Feature on Demand in the “Turn Windows features on or off” dialog. Microsoft appears to be nudging users toward modern .NET runtime versions; however, standalone installers remain available for legacy applications that absolutely require .NET 3.5. This is a notable push toward modernization that may affect older line‑of‑business apps.
  • The System Preparation Tool (Sysprep) now refuses to run in Safe Mode, returning the explicit error “You can’t sysprep while running in Safe mode.” This prevents improper imaging sequences and enforces intended usage patterns.
What 26H1 is not​
It’s important to be explicit about what 26H1 does not represent:
  • 26H1 is not the successor feature update that will be delivered to your existing PC via Windows Update — the mainstream branch will remain on Germanium and receive the expected 26H2 feature update later in 2026.
  • It is not an immediate sign of broad fragmentation: Microsoft has stated this split is a temporary engineering necessity, with both branches expected to converge in a future release cycle (reported around Windows 27H2). However, in the intervening period devices that ship on the 26H1 Bromine platform will follow a separate servicing lane.
  • 26H1 is not a feature playbook for day‑to‑day consumers; the visible UI changes are incremental. The primary value of 26H1 will be realized on hardware that actually implements the new scheduling, power, and NPU integrations.
Why this matters to different audiences​
Consumers and prosumers​
If you’re a mainstream Intel/AMD desktop or laptop user, nothing about your update strategy changes today. Monthly quality updates and the scheduled 26H2 feature update will continue under the existing servicing model; you won’t see 26H1 via Windows Update. For most buyers, the practical takeaway is: don’t chase 26H1 unless you plan to buy a new Arm machine that ships with it.
For early adopters buying the first Snapdragon X2 laptops, 26H1 promises a more optimized out‑of‑box experience — potentially better battery life, native NPU utilization, and OS‑level scheduling tuned to heterogeneous cores. Those benefits will only materialize on hardware that supports the new plumbing.
Enterprises and IT managers​
26H1 raises operational questions for IT teams responsible for fleet stability:
  • Devices shipped with 26H1 will be on a separate servicing lane and may not be eligible for the same in‑place upgrade path to the mainstream 26H2 release later in the year. That’s an important procurement consideration for organizations that standardize on a single image or maintenance baseline.
  • The removal of .NET Framework 3.5 as an FoD means IT must plan for legacy application compatibility. While standalone installers remain, they are an extra step and a potential support headache for older LOB applications.
  • Imaging and automation workflows should account for Sysprep behavior changes (Sysprep can't run in Safe Mode), and OEM drivers that ship on Bromine images may be different from what your current driver management system expects.
OEMs and silicon partners​
For OEMs and silicon vendors the Bromine/26H1 path is a tool: it lets partners deliver a validated OS image that exposes the latest power, scheduling, and NPU capabilities without waiting for the mainstream release cycle. This reduces integration friction and helps vendors ship devices with “Copilot+” or on‑device AI capabilities enabled from day one. The tradeoff is the temporary servicing lane divergence and the added complexity of supporting two active platform baselines within the Windows ecosystem.
Technical risks, compatibility concerns, and fragmentation​
Microsoft’s approach is defensible from an engineering standpoint — Arm silicon is evolving rapidly and deep kernel changes are sometimes best validated on a limited set of systems. But there are practical tradeoffs worth weighing.
  • Servicing lane divergence: Devices shipped with 26H1 will follow a different servicing trajectory. For organizations that require predictable, long‑term servicing contracts or standardized images across device models, this is an operational complication. Microsoft has promised a later convergence, but the interim period requires explicit plans.
  • Application and driver compatibility: The Bromine platform’s scheduler, power model, and driver expectations may expose latent bugs in older drivers or apps that assumed Germanium behavior. ISVs and driver teams will need to test on Bromine images and report regressions to silicon/OEM partners.
  • Legacy dependencies: The push away from .NET 3.5 in the FoD list signals an ongoing modernization push. While this is positive overall, organizations with legacy stacks should validate their applications against supported runtimes and prepare for potential extra steps to maintain compatibility.
  • Speculative support for other silicon: Some coverage and community posts suggest potential support for other upcoming Arm entrants (for example, NVIDIA N1X‑class chips) but these claims are not fully confirmed. Treat vendor‑specific compatibility claims cautiously until OEMs and Microsoft publish explicit support statements. Flagged as unverified until multiple partner confirmations appear.
Developer and ISV implications​
For software vendors, the two most important actions are testing and optimization:
  • Test your applications on the Bromine/26H1 image where possible, especially if you target Arm64 builds or rely on native performance characteristics.
  • Profile AI workloads and media pipelines to see if NPU offload or new hardware codecs are available and beneficial.
Practical steps for ISVs and driver teams:
  • Obtain OEM test units or Bromine images from partner channels for realistic validation.
  • Validate both Germanium and Bromine behavior for scheduling-sensitive workloads (multithreaded apps, background services).
  • Update packaging strategies for legacy dependencies (e.g., ensure .NET 3.5 installers are available if required).
  • Coordinate with OEMs on driver signing and distribution, since factory‑flashed driver packages on Bromine devices may differ from what Windows Update delivers for mainstream devices.
These steps reduce the risk of regressions and ensure a smoother customer experience on the new hardware first wave.
Migration, servicing, and the path forward​
Microsoft’s messaging is clear: 26H1 is a targeted, OEM‑shipped platform image that will not be offered as an in‑place upgrade to the broader installed base. Mainstream consumers will continue to receive their regular Windows 11 servicing and the 26H2 feature update later in 2026. Microsoft expects both platform branches to converge in a future release (commonly discussed around 27H2), which would restore a single servicing lane across architectures.
For those managing mixed fleets, practical guidance is:
  • Treat 26H1 devices as platform‑specialized appliances with vendor‑defined update schedules until Microsoft publishes a migration path.
  • Avoid scheduling critical deployments on first‑wave Bromine devices if you require identical behavior across your fleet.
  • For procurement teams, insist on clear servicing and driver support commitments from OEMs on 26H1 devices.
This conservative posture preserves operational predictability during the temporary multi‑lane servicing window.
Final assessment — strengths, limitations, and what to watch next​
Windows 11 26H1 is a pragmatic engineering response to fast‑moving Arm silicon: it allows Microsoft and partners to ship validated platform images that fully exploit heterogeneous cores, on‑device NPUs, and new power/thermal controls. The decision avoids the risk of shipping mainstream updates that might break on new silicon and gives OEMs a path to offer optimized out‑of‑box experiences. Those are real strengths, especially as on‑device AI and power efficiency become differentiators in the laptop market.
However, the approach introduces short‑term complexity:
  • A separate servicing lane for 26H1 devices means additional complexity for IT, OEMs and ISVs.
  • The visible benefits for consumers are modest until devices with Snapdragon X2 (or other validated silicon) ship and software fully leverages NPUs and scheduler improvements.
  • Any claim about support from alternative silicon vendors (for example, NVIDIA N1X) should be treated as provisional until confirmed by partners and Microsoft.
What to watch next:
  • OEM announcements for Snapdragon X2 devices and their published support lifecycles.
  • Microsoft's official servicing and migration guidance for devices that ship with 26H1, including the timeline for convergence.
  • ISV reports on real‑world performance, battery life, and NPU integration once first‑wave devices reach customers.
Windows 11 26H1 is a narrow, device‑targeted platform release — not the next general feature update for your PC. It represents Microsoft’s pragmatic choice to build a distinct platform baseline for new Arm silicon so OEMs can ship devices with validated kernel, scheduler, power, and NPU integrations from day one. For most users and enterprises, nothing changes in the immediate term: existing PCs will remain on the Germanium branch and receive the usual updates, including a mainstream 26H2 feature update later in 2026. Early adopters who buy Snapdragon X2 devices stand to gain the most, but organizations should plan carefully around servicing lanes, legacy dependencies, and application compatibility until the platform branches reconverge.
In short: 26H1 is a platform for tomorrow’s silicon, not a patch you need to chase today — and the real test will arrive when the first Bromine‑based devices ship and software begins to exploit the new hardware plumbing.
Source: Windows Latest Hands on with Windows 11 26H1 and why this update is not meant for your PC
Microsoft has quietly shipped a new, purpose-built Windows image — Windows 11, version 26H1 — but unlike prior H1/H2 releases this one is not a general feature update for the existing Windows population; it’s a factory‑installed, hardware‑gated platform image intended to enable next‑generation silicon and will appear only on select new devices.
A laptop glows with a blue holographic BROMINE schematic and Snapdragon X2 branding.Background / Overview​
Microsoft’s visible version string moved to 26H1 in Insider Canary builds (Build 28000), and the company’s public guidance makes an important distinction: 26H1 is a platform‑only, device‑targeted release designed to “support device innovations expected in 2026,” not the broad feature pack that consumers and enterprises typically expect from a numbered Windows release.
That change reflects a deliberate shift in Microsoft’s release strategy. Instead of a single, monolithic H2 feature update pushed to the entire installed base, Microsoft has introduced a parallel servicing lane — a Bromine‑class internal platform baseline — that will be factory‑flashed on qualifying machines built around specific next‑generation SoCs (notably Qualcomm’s Snapdragon X2 family in the initial wave).
The public rollout for 26H1 began in early February 2026, with OEMs shipping devices preinstalled with the image rather than the update being offered to existing Windows 11 devices via Windows Update. Microsoft’s Message Center and support notice made the delivery model explicit: “select new devices only and is not offered as an in‑place update.”
What Windows 11 26H1 Actually Is​
A device-first platform image, not a universal feature update​
  • 26H1 is distributed as an OEM image preinstalled by device manufacturers; end users will not see it as a download in Windows Update if they already own a Windows 11 PC.
  • Internally it’s associated with a new platform baseline codenamed Bromine and carries build numbers in the 28xxx range (Insider Canary Build 28000 surfaced the new version string).
The narrow hardware focus​
  • The initial wave of devices targeted by 26H1 are Arm‑based laptops using next‑generation silicon, specifically Qualcomm’s Snapdragon X2 family; future device families with comparable architecture and NPU/AI capabilities may also be targeted.
  • 26H1 contains low‑level plumbing — kernel tweaks, scheduler updates, power‑management changes, updated driver models and runtime/ NPU plumbing — optimized for the hardware these OEMs expect to ship in early 2026.
Release timing and labeling clarity​
  • Microsoft published Canary‑channel notes and followed with a terse Message Center notice on February 10, 2026 announcing availability on select new devices; that created some early confusion but the ensuing documentation clarified the narrow scope.
Key Differences vs. a Traditional Feature Update​
Delivery and installation model​
  • Devices ship from the factory with 26H1 preinstalled — OEM image only.
  • Existing Windows 11 systems (24H2, 25H2, etc.) will not receive 26H1 as an in‑place upgrade via Windows Update.
  • Devices that ship with 26H1 are placed on a separate servicing lane and are not expected to automatically move to the mainstream 26H2 feature update later in 2026.
Servicing and updates​
  • Although 26H1 devices will receive monthly security and quality updates like other Windows versions, the feature‑update path diverges — Microsoft is treating this as a platform baseline for an emerging class of hardware rather than a universal feature release.
Platform capabilities vs. consumer features​
  • For most users the change won’t bring headline UI features; instead 26H1 focuses on performance, power efficiency, and low‑level support for NPUs and AI runtimes that next‑gen SoCs expose. The visible user‑facing change is minimal, but the platform plumbing under the hood is significant.
Technical Deep Dive: What’s Different Under the Hood​
Kernel, scheduler and power management​
26H1’s engineering work centers on core platform subsystems that interact directly with modern Arm‑class SoCs:
  • Kernel and scheduler updates are tuned for heterogeneous CPU clusters and new power/performance tradeoffs found in X2‑class designs. This reduces latency for on‑device AI workloads and improves responsiveness under mixed workloads.
  • Power and thermal management changes aim to maximize battery life across variable NPU and GPU loads, with finer‑grained throttling and co‑management between CPU, GPU and NPU domains.
NPU and AI runtime plumbing​
  • Microsoft’s 26H1 contains updated runtime and driver support to surface NPUs (neural processing units) to Windows components and third‑party frameworks, enabling OEMs and silicon partners to deliver preinstalled, hardware‑accelerated AI features out of the box.
  • Expect vendor execution providers and hardware‑accelerated inference stacks to be bundled and certified for the platform image to ensure consistent behavior across drivers and firmware.
Driver model and OEM firmware tie‑ins​
  • 26H1 is built to ship with specific OEM firmware and drivers, reducing the time‑to‑work for the new SoC’s device drivers and minimizing the risk of divergence between driver expectations and the stock Windows image. That is why Microsoft opted for an OEM‑delivered image rather than pushing the changes through broad Windows Update.
What This Means for Consumers and Purchasers​
If you’re buying a new PC in 2026​
  • If you purchase an OEM device advertised as having the latest Arm silicon (Snapdragon X2 or similar), it may arrive running Windows 11, version 26H1. Those devices will ship with the optimized Bromine platform baseline and should deliver best‑case performance and on‑device AI experience for their specific hardware.
If you already own a Windows 11 PC​
  • Your machine will remain on the mainstream servicing lane (25H2 or 24H2 as appropriate) and you should not expect 26H1 to be offered via Windows Update. The broad consumer feature update — 26H2 — remains the general feature release slated for later in 2026 and will be the update path relevant to the majority of users.
Buying guidance​
  • If you need the specific platform optimizations (for example, best possible battery life and NPU acceleration for on‑device AI workloads), buy devices that explicitly ship with 26H1 and vendor‑certified drivers. For general users and enterprises that value uniformity and predictable update behavior, the mainstream 26H2 cycle will be the safer, more predictable path later in the year.
Enterprise and IT Implications​
Deployment and lifecycle planning​
  • IT teams should treat 26H1 machines as a separate device class. These devices will have:
  • OEM‑installed images and drivers that must be validated against corporate policies.
  • A different feature‑update path that may not align with your standard Windows servicing cadence.
  • Enterprises that adopt 26H1 devices early should update procurement policies, driver validation procedures, and imaging/MDM workflows to account for the device‑specific servicing lane.
Compatibility and application testing​
  • While many mainstream applications will run unchanged (especially if native ARM64 builds or the Prism emulation layer are present), IT must test line‑of‑business applications and security agents on 26H1 devices before broad rollout to avoid surprises. The platform divergence means one device class may behave subtly differently in driver or runtime edge cases.
Update management​
  • Because 26H1 devices remain on a different servicing track, IT groups should:
  • Catalog which endpoints ship with 26H1.
  • Coordinate with OEMs for driver/firmware updates.
  • Validate monthly quality updates before mass deployment in controlled rings.
Developer and ISV Considerations​
App compatibility and the emulation story​
  • Windows on Arm has matured: native ARM64 builds are increasingly common and the improved emulation (Prism-era improvements) reduces compatibility gaps for many x86/x64 apps, but differences still matter for apps that depend on kernel‑mode drivers or assume x86 hardware characteristics. Developers should prioritize native ARM64 builds for performance and energy efficiency on 26H1 machines.
Driver and runtime updates​
  • ISVs that ship hardware drivers, execution providers, or native AI runtimes should engage with OEM and silicon partners to certify compatibility on the Bromine baseline. 26H1 devices will expect vendor‑specific EPs and drivers at install time.
Testing recommendations​
  • Use device labs or OEM partner validation program images to test on the exact Bromine/26H1 configuration. Emulation in general Windows images is insufficient to simulate certain NPU and low‑level scheduling behaviors.
Security and Servicing: Monthly Patches, but a Separate Lane​
  • Microsoft will continue to release monthly security and quality updates for 26H1 devices, keeping them aligned with the cadence for patching critical vulnerabilities; however, the feature update path is intentionally separate. This preserves the ability to rapidly patch security issues while keeping feature divergence constrained to the intended device classes.
  • That separation reduces the risk of introducing wide‑scale regressions into the mainstream installed base, but it increases the complexity for security teams that must track multiple platform baselines concurrently. Plan for parallel validation of updates across servicing lanes.
Strengths and Opportunities​
  • Optimized experience on day one. By shipping a platform image tailored to the SoC and firmware, OEMs can deliver best‑case battery life, performance and NPU acceleration without waiting for broad Windows Update rollouts.
  • Cleaner integration with silicon vendors. Bromine‑class engineering allows Microsoft, OEMs, and silicon partners to coordinate deeper kernel and runtime changes that would be risky to push to the entire Windows population.
  • Faster time‑to‑market for new hardware. OEMs can ship new Arm architectures earlier in the product cycle because 26H1 provides a certified, preintegrated baseline for drivers and AI runtimes.
Risks, Fragmentation and Real‑World Downsides​
  • Platform fragmentation. The introduction of a separate servicing lane raises the risk of divergence between devices and complicates enterprise lifecycle management. Organizations could end up juggling multiple platform baselines with different feature and compatibility profiles.
  • Update confusion for consumers. Messaging that an upgrade exists but isn’t offered to existing users invites confusion; without clear sales and OEM communications many buyers may assume their current device is eligible when it is not. Early Message Center wording led to exactly this problem.
  • Driver and ISV certification burden. Hardware vendors and ISVs must certify for the Bromine baseline and maintain distinct driver packages and execution providers for that lane, increasing engineering overhead.
  • Migration path uncertainty. Microsoft has stated 26H1 devices won’t automatically move to 26H2 later in 2026, and while future convergence releases are possible, the timeline and migration mechanics are not fully defined — a practical concern for enterprises planning standardization.
Practical Recommendations​
For consumers and prospective buyers​
  • If your workflows benefit from on‑device AI acceleration and longer battery life on Arm silicon, buy devices that explicitly ship with 26H1 and have vendor‑certified drivers. Otherwise, default to mainstream devices and wait for 26H2 if you want a consistent upgrade path.
For IT teams and procurement​
  • Inventory existing and prospective devices for platform baseline (26H1 vs mainstream).
  • Update procurement language to require OEM confirmation of the shipped Windows image and driver support window.
  • Prepare independent validation rings for Bromine/26H1 devices to test line‑of‑business apps, security agents and firmware updates.
For developers and ISVs​
  • Prioritize native ARM64 builds and certify drivers and execution providers with OEM partners. Use Bromine/26H1 test images to validate performance and NPU behavior early.
How Microsoft Could Reduce Friction​
  • Clearer messaging in the OEM and Microsoft storefronts explaining that 26H1 is device‑specific and not a Windows Update for existing PCs would reduce consumer confusion. Early Message Center comms should be augmented with plain‑language buyer guidance.
  • Better tooling and APIs for IT to identify and manage devices across servicing lanes (automated labeling in MDM, clearer lifecycle metadata from OEMs) would help enterprises manage the fragmentation.
  • A documented migration path and timeline showing how and when Bromine/26H1 devices will be reconciled with mainstream feature releases would ease procurement decisions.
Bottom Line​
Windows 11 version 26H1 represents a major strategic pivot: rather than being the next universal feature update, it is a hardware‑gated platform baseline intended to let Windows, OEMs and silicon partners ship next‑generation Arm and AI‑centric devices with optimized low‑level support out of the box. For users who buy those specific machines, 26H1 should unlock better battery life, smoother NPU acceleration and a more integrated on‑device AI experience. For the majority of the Windows ecosystem — existing Intel/AMD PC owners and enterprises that value a single servicing lane — the practical impact is administrative: prepare for parallel servicing lanes, test carefully, and expect the more broadly relevant Windows 11 26H2 feature release later in 2026.
In short: 26H1 is important, but it’s important in a device‑first way — a plumbing and platform release that signals Microsoft’s approach to supporting increasingly diverse silicon rather than a mass consumer update everyone needs to install.
Source: WinCentral Windows 11 26H1 First Release Explained: What’s New
