Microsoft’s latest Insider flight continues the slow‑roll of Copilot‑era polish and cross‑device continuity: Build 26200.5761 (KB5064093) landed in the Insider channels with a staged “Resume from your phone” flow that starts with Spotify, refreshed lock‑screen battery visuals, snappier input and sharing shortcuts, Copilot+ touch tweaks, and a slate of targeted reliability fixes — while a handful of region‑ and driver‑specific bugs remind testers this is still a Dev/Beta experiment. eered Build 26200.5761 as part of the ongoing 25H2 enablement and Dev/Beta channel flights; the company is using Controlled Feature Rollouts (CFR) to gate larger experiments, meaning features will appear gradually and may never ship in the exact form Insiders see today. This staged model reduces risk but increases variance between machines and users.
The hot items in this flight cluster into(the new “Resume” taskbar alert for Android apps), Copilot+ and NPU‑accelerated refinements (Click to Do gesture, Automatic Super Resolution—Auto SR—toasts), and a set of quality‑of‑life and accessibility improvements (Snipping Tool window recording, en/em dash shortcuts, Windows Share pinning). Underneath those are stability fixes aimed at Settings, Windows Hello, gaming overlays, and an important .NET/Visual Studio fix for Arm64 developers.
A curved monitor displays Spotify on a blue desktop, with a smartphone on a stand and a keyboard.Cross‑device Resume: picking up Android app activity on PC​
What Microstfeature is a cross‑device “Resume” alert that can surface on a Windows 11 taskbar when a supported Android app is active on a paired phone. The initial partner in the experiment is Spotify: play a track or podcast on your Android device and, if the feature has been toggled on for your device, a Resume prompt can appear on the PC. Clicking the prompt launches the desktop Spotify app — and if Spotify isn’t installed, Windows will offer a one‑click Microsoft Store installation and sign‑in so playback continues immediately.​
Requirements and setup​
  • A Windows 11 PC running Build 26200.5761 (Dev/Beta as applicable) with the “Get the latest updatealed for Controlled Feature Rollout exposure.
  • Link to Windows / Phone Link pairing between the Android phone and the PC with background permissions allowed.
  • The same Spotify account signed in on both devices one‑click Store install + sign‑in if needed).
Step‑by‑step (short):
  • Settings > Bluetooth & devices > Mobile llow this PC to access your mobile devices” and link your phone.
  • On Android, install and configure Link to Windows and ivity.
  • Start playback in Spotify on the phone; watch for a taskbar Resume alert and click to continue on PC.
Why it matters​
This is Microsoft’close the continuity gap with Apple’s Handoff by offering Android → Windows resume pointne Link stack, not a separate cloud service. Starting with media (Spotify) is a pragmatic choice: playback pynchronize, and successful low‑risk demos build confidence before tackling richer scenarios (drafts, messaging, document state). If Microsoft exposes a Resume API and developers adopt it, the feature could scale beyond media to significantly reduce friction when moving between devices.
Practical limitations and early caveats​
  • The rollout is gradual and telemetry‑gated; not every Insider will see Resume immediately.
  • Initial app support is narrow — Spotify is the first example — so everyday usefulness depends on developer uptake.
  • Resume relies on account parity (sndows stability; disruptions in either layer will break the flow.
Productivity and UX polish: small changes with outsized impact​
icons and quick glance polish​
The lock screen gains refreshed battery iconography and clearer percentage visuals srge state at a glance without unlocking. This is a modest but meaningful polish for people who frequently check battery status on laptops and tabletl: window‑mode screen recording
Snipping Tool’s recorder now supports Window Mode, letting you pick a single application window as the fixed capture region. The recording area snaps to the selected window’s bounds at start and remains fixed for predictability (it does not follow the window if moved mid‑capture). The feature is rolling via an inbox app update and is particularly usorials where you want a single app captured cleanly.
How to use it (short):
  • Open Snipping Tool > Record > New > Recording area dropdown > Window Mode.
  • Select target window, prepare your scene, then start recording — the capture region is locked.
Typing refinements: en and em dash hotkeys​
Writers get a tiny but welcome improvement: Win + Minus inserts an en dash (–) and Win + Shift + Minus inserts an em dash (—). Note the Magnifier caveat: Win + Minus agnifier zoom when that accessibility tool is active.
Windows Share pinning​
The Share dialog is exning favorite share targets**, so commonly used destinations appear at the top of the panel. For peopy to the same app or service, that reduces friction and click time.
Copilot+ devices, Automatic Super Resolution (Auto SR), and Click to Do​
Copilot+ hardware gating and gestures​
Several Copilot‑adjacent refinements are gated to Copilot+ devices (machines with capable NPUs, includardware). Notably, Click to Do gains a two‑finger press invocation on touchscreen Copilot+ PCs, making it easier to select content and launch contextual actions without keyboard or touchpad shortcuts. Agent results in Settings now deep‑link to the exact pages .
Auto SR: simpler controls and toast configuration​
On Snapdragon Copilot+ laptops, Automatic Super Resolution (Auto SR) gets simplified settings and toast‑driven configuration so gamers and creators can tune upscaling behavior quickly without digging through submenus. This reflects Microsoft’s recognition that upscaling needs per‑title tweaking and visible, immediate controls.
Why the Copilot+ approach is a double‑edged sword​
  • Benefits: hardware‑accelerated NPU features can deliver low‑latency on‑device AI and image d privacy‑preserving. Copilot+ optimizations can turn compelling demos into genuinely useful daily helpers.
  • Risks: gating features to specific silicon fragments the user base and complicates messaging. Non‑Copilot owners may see only partial behavior or experience inconsistent performance across devices, which can frustrate cross‑team developers and IT admins.
Fixes, devel64 notes​
Key reliability fixes​
This flight includes several targeted fixes that matter to end users and developers: faster load times for Settings’ Installed apps list, Windows Hello face recognition reliability improvements (reducing cases where recognition succeeded but sign‑in still fell backame stability when overlays and Game Bar are used in multi‑monitor setups with mixed refresh rates.
Visual Studio WPF crash on Arm64 — the KB5064402 .NET fix​
For developers working on Arm64 hardware, a crash in Visual Studio involving WPF after a .NET ued by an accompanying .NET patch identified as KB5064402. Install that .NET update after the OS flight if you build or debug WPF applications on Arm64 to avoid the crash. This is a good example of coordination between OS servicing and runtime patches to keep developer productivity intact.
Recommended developer checklist:
  • Update to Build 26200.5761 on a non‑critical test machine.
  • Immediately install available .NET updates (look for KB5064402) befonarios on Arm64.
  • Collect performance traces for any Game Bar/overlay regressions and send them via Feedback Hub if you rely on overlays for streaming or telemetry.
Known issues, workarounds, and what to watch​
Recall behavior in the European Economic Area​
Insiders in the European Economic Area may experience Recall not working correctly due to regional requirements. Microsoft’s short‑term recovery step is to reset Recall: Settings > Privacy & secuo > Reset Recall. This is a region‑specific quirk; if you travel or test with EEA configurations, veying the build.
File Explorer Shared section and Temporary files scanning​
Some testers report that the **Se Explorer Home appears even when empty, and the Temporary files scanner under Settings > System > Storage may hang scanning progress for some devices. Pude restarting File Explorer, clearing Recent files/folders from File Explorer Options, and rebooting if Temporary files scanning stalls. These are mostly nuisance bugs but can be disruptive to power users.
Xbox controller Bluetooth bugcheck — manual Device Manager workaround​
A particularly severe edge case: some Insiders see bugchecks (blue screens) when using Xbox controllers over Bluetooth. Microsoft documented a manual workaround involving Device Manager driver removalect the documented mitigation and should be used only on test devices:
  • Settings > Bluetooth & devices > Devices: remove the Xbox controller pairing and toggle Bluetooth off/on, then re‑pair.
  • If crashes persist, open Device Manager and choose View > Devices by driver. Expand Bluetooth and Human Interface Devices and uninstall any grayed or suspect Xbox or Bluetooth LE Xinput entries (right‑click > Uninstall device). If prompted, check “Delete the driver software for this device. r reboot, then re‑pair the controller and let Windows re‑provision the driver. Test in the Xbox Accessories app or Game Controllers control panel.
This workaround underscores why Insiders should avoid deploying Dev/Beta flights on mission‑critical machines that rely on Bluetooth game controllers. Microsoft has indicated it is investigating and will patch in a future flight.
Strategic analysis: strengths, risks, and how Microsoft should proceed​
Notable strengths​
  • Focused, praarting Resume with Spotify is clever — it’s a highly visible, low‑risk use case that demonstrates the flow without depending on cross‑platform document syncing. If developers adopt the Resume API, Windows could finally offer a practical Android → PC “handoff” story that many users have wanted.
  • Qualitcale: Small UX improvements (dash hotkeys, share pinning, lock screen battery icons) are the kind of incremental wins that improve daily productivity more than one big flashy feature.
  • rentiation: Copilot+ features and Auto SR show how Microsoft plans to use NPU power to deliver on‑device AI capabilities that are fast and private, giving OEMs something to sell beyond raw CPU/GPU specs.
Tangible risks and tran and gating: Tying the best experience to Copilot+ hardware and gating features behind CFR increases the chance of inconsistent experiences across the user base. This fragmentation can confuse consumers and complicate enterprise pilots.​
  • Regional policy friction: Features like Recall have already shown EEA‑specific behavior differences; regulatory and privacy regimes could force Microsoft to ship different feature sets by regiar expectations.
  • Driver and peripheral regressions: The Xbox controller Bluetooth bugcheck is a reminder that peripheral interactions remain a common stability vector; until driver ecosystems settle around new flers should avoid preview rings for primary machines.
Recommendations for Microsoft​
  • Publish a clear developer path and API reference for Resume so app vendors can implement and test the handoff model quickly. Early SDy hooks will accelerate adoption.
  • Provide transparent gating signals in Settings so Insiders know why they do or do not see a feature (toggle status + estimated rollout window). This reduces confusion and Incident Reports.
  • Prioritize peripheral stability fixes (Bluetooth gamers) before widening the rollout to mainstream channels; a single blue‑screen class issue erodes trust quickly.
Practical advice for Insiders, IT admins, and developers​
For Insiders who want to try Resume and Copilot+ features​
  • Turn on Setti Get the latest updates as soon as they’re available to increase your odds of being included in the Controlled Feature Rollouts.
  • Link your phone via Settings > Bluetooth & devices > Mobile devices and ensure Link to Windows runs with background permissions on Android. box apps (Snipping Tool, Share UI) updated after the OS flight; some capabilities are delivered via app updates rather than the OS package.
For IT admins and lab managers​
  • Image test machines or snapshot VMs before applying ds.
  • Pilot the flight in a small ring focused on specific scenarios (developer workstations, gaming rigs, Copilot+ hardware) to collect targeted telemetry.
  • Hold production fleets on stown issues (Xbox controller bugchecks, Recall EEA behavior) are resolved.
For developers​
  • If you build WPF or other .NET apps on Arm64 hardware, install the KB5064402 .NET patch after oid Visual Studio crashes.
  • Evaluate Resume adoption: assess whether your mobile app can expose a lightweight session token and playback/draft state to the Phone Link/Resume API to provide frictionless continuation.
Build 26200.5761 (KB5064093) is a focused, pragmatic flicrosoft’s current strategy: small, synchronised wins delivered via staged rollouts and hardware‑targeted differentiation. The cross‑device Rth Spotify is the clearest consumer‑facing signal that Windows is chasing continuity across Android devices, while Copilot+ and Auto SR show a push toward on‑deviperformance wins for NPU‑equipped machines. The update’s value to testers will hinge on developer adoption of Resume, lot+ features expand to non‑NPU hardware, and Microsoft’s ability to close peripheral and regional bugs before broader shipping.
For Insiders, the build is ritical machines: enable the “get the latest updates” toggle, link your phone, and update your inbox apps to see the new behaviorss, the guidance is conservative: pilot, patch runtimes (KB5064402 for .NET on Arm64), and wait for fixes to the Bluetooth/Xbox driver class issue before moving this fs. In short, this update nudges Windows toward more fluent device transitions and quieter productivity improvements, but it also illustrates the perennial tradeoff of preview software — meaningin flagged‑on experiments and a few stubborn compatibility gremlins.
Source:** Red Hot Cyber Windows 11 Insider Preview: New features and improvements ahead
