Windows initialization problem
Hi ,
when i start up my computer , a black screen apears saying this:
'' Path:\windows\system32\winload.exe
partition: 2
hard disk:3ebb8831
[/noexecute=optin "
What should i do?:confused:
First of all what OS of Windows are you running? Second if it is W7 make sure in your BIOS that the CD/DVD drive is set as your first boot option. if it is then boot your system from the DVD and do the repair option
Remember when asking questions please post your System Specs
Motherboard, CPU type, Memory and OS you are using as minimum. Power supply and video card make and model are also helpful
