- Thread Author
- #1
WMP12 cant open, uninstall, install please help! i had just installed wmp12 from windows feature panel as i had previously uninstalled it, but after that before i restart the pc the battery life ended and the pc power off without shutting down correctly. when i restart the pc wmp didnt anymore open, than ive fixed it with the fix wmp utility that reregistered all dlls but the wma and wmv embedded object dont shows in ie and the wmp cant be uninstalled to reset or fix the problem i assume there should be a corrupted installer or something like
ive tried this
sfc /scannow = no file corrupted
remove the wmp from windows feature = give error cant be removed
restore point = nothing changed
wmpsetup file in wmp folder under program files = start and after seconds close, nothing happens
download Windows 7 n package = dont work version error
wont do windows repair install need to fix in other way
someone can please help me? i need to fix the wmp in any way, restore it, repair it, reinstall it
ive tried this
