Windows 7 WTF windows 7.. alot of problems need help desperatly
newhen
Alright I have a ton of driver problems right now that I can't seem to solve. THIS IS ALL AFTER UPGRADING TO RC
1. My hp touchpad sound driver that is suppose to turn red when i mute it does not any more after upgrading to rc.
2. My Razer Mamba, wont work I got it to work for a minute and now it just says cant install driver for unknown device.
3. There are a bunch of other unknown devices in device manager
PLEASE HELP I AM BEGGING.:(
It sounds like you're experiencing some frustrating driver issues after upgrading to Windows RC. Here are some steps you can take to address each of the problems you mentioned:
1. HP Touchpad Sound Driver Issue:​
  • Missing Red Indicator when Muting:
    • This issue might be related to the driver itself. Try reinstalling the sound driver for your HP Touchpad. Here's how you can do it:
      1. Go to Device Manager (Right-click on Start, select Device Manager).
      2. Locate the sound driver for your HP Touchpad under the "Sound, video and game controllers" section.
      3. Right-click on the driver and select "Uninstall device."
      4. Reboot your PC and Windows should automatically reinstall the driver.
        2. Razer Mamba Driver...​
        2. Razer Mamba Driver Issue:​
    []Unknown Device Error:
    • When Windows displays "unknown device" errors, it usually means that the driver is missing or incompatible. Here's what you can do:
      1. Download the latest driver for your Razer Mamba from the official Razer website.
      2. Right-click on the unknown device in Device Manager (if it's listed) and choose "Update driver."
      3. Select the option to browse your computer for the driver software and navigate to the location where you downloaded the Razer Mamba driver.
      4. Follow the on-screen instructions to complete the installation.
        3. Unknown Devices in Device Manager:​
    ]Identifying and Installing Drivers:
    • To address unknown devices in Device Manager:
      1. Right-click on each unknown device and select "Properties."
      2. Go to the "Details" tab and select "Hardware IDs" from the drop-down menu.
      3. Note down the hardware ID displayed.
      4. Use the hardware ID to search for the driver either on the manufacturer's website or through Windows Update. If you're unable to resolve the issues with these steps, feel free to provide more details or let me know if you need further assistance.
