stone cold
i have bought xfx 9500 gt(1gb DDR2 )and it was runing perfectly on xp, but then i have installed my second os win 7 professional but the the driver is not catching it
. it is on the device manager but with an yellow question mark
.my resolution has gone all the way down to 800*600
.refresh rate to 1 gz
.the full screen has blasted with dots and i cannot see any thing clearly
although i have installed latest driver i.e_331.82
system specifications
*peintum 4 2.20 gz
*2 gb ram
*500 gb hardisk
*mother board 945 chipset family(american megatrends
Have you installed the Nvidia driver/software package for it from Nvidia? What bit type is your OS....32 or 64? The minimum PSU (power supply) requirement is a 350 watt...do you meet that?
http://www.nvidia.com/download/driverResults.aspx/73779/en-us
yes i have installed the driver packages which comes with the cd ,and i have win7 professional 32 bit, i thing so i have the psu requirement because it is working perfectly with my second OS (i.e. xp)
The driver on the cd will be out of date. Try installing the latest version:
http://www.nvidia.com/Download/index.aspx?lang=en-us
i have downloaded the latest driver from the link you have suggested,but its not working
Do you mean the driver won't install or the driver installs but doesn't work?
Try this link here:
http://www.nvidia.com/download/driverResults.aspx/76104/en-uk
Uninstall your previous drivers using this app:
these are the screen shots of my desktop
An image from 'XFX 9500 gt display problem win 7'. The images show a Windows desktop with a scenic wallpaper and the Screen Resolution settings window set to 800x600.
the driver is installing but in device manager it is with a yellow question mark ,here the image is much clear thn original.
The link you have provided is fore the 64 bit and mine is 32!
Apologies... Here is the 32bit link:
http://www.geforce.com/drivers/results/76014
same !!! installed but not working same screen ,same device manager yellow question mark
Hmm.. sounds odd. Try running this windows 7 upgrade advisor just to make sure all is good for running this os:
i have installed it , and every thing is fine except the video memory
it says that your video card driver doesn't support aero,try to to update it, but i have alredy installed the latest version
Try this guide on turning on Aero:
http://www.mydigitallife.info/how-to-turn-on-and-enable-aero-in-windows-7-enable-aero-peek/
I seem to remember something about WDDM drivers and the like needed for Aero but it's years since I last used Aero itself. Let me wake up properly, drink some coffee and hopefully the memories will return.. :) Seriously I'll do some research and post back but it could be down to something like that.
