Windows XP XP SP3 extend partition inquiry
ozstar
Well-Known Member
On XP Drive 0 I have C: with XP and have another couple of drives as well.
and Drive 1 is F: Primary and G: Extended each about 37GB.
I have Drive 2 D: 80GB Extended partition...
I want to join both F and G together as 1 partition mainly the G: one.
Though Disk Mgmt Storage how can I do that.
I was afraid to delete the leading F: partition as it is primary.
Thanks
All are NTFS
oz
Just delete both f and g back to unallocated space then reformate the drive however you like.
1. Back up any important data from the two drives first… there is software around that can repartition a hdd without formatting it first but I've not been overly impressed with any of the ones that work within xp.
2. Take a note of page files, recovery partitions or other hidden partition on that hdd?
3. Confirm that no folders (like my downloads) are being redirected to the F or G drive before you proceed.
p.s. yes, a primary partition within a drive can hold a boot section but doesn’t have to and in fact doesn't in your case, so it is just another storage drive.
Many thanks
