The thread centers on fixing choppy video playback in Media Player Classic when using the CCCP codec pack, specifically noticeable during reverse playback and after seeking on the timeline. The key answer was to change MPC’s output renderer from “EVR Custom Pres” to “EVR (Vista/.Net3)” via Main menu → View → Options → Playback → Output (with an included screenshot). Overall sentiment is positive and solution-oriented, with the poster effectively sharing a straightforward setting change that resolves the issue.
Thread Author
I've been having problems with video playback using the CCCP codec pack which contains Media player classic.
The problem has been that when I use the seekbar in MPC the videoplayback has been choppy for a few seconds. This only seemed to appear while playing backwards. Seeing that MPC is the best mediaplayer out there (my opinion) I knew that I had to get it working properly once more since my old XP system.
What solved the problem for me was just chaing the output renderer to EVR (Vista/.Net3) instead of EVR Custom Pres.
For all you wondering how to do this, it can be found under:
-> Main menu -> View -> Options -> Playback -> Output
I've also added a screenshot for your conveniance
Link Removed due to 404 Error
