A PDF that looks perfect on screen but emerges from the printer as a stack of pristine white paper is usually not a “PDF problem” in the broad sense. It is a useful clue. The failure can sit in one of three places: the specific document, Microsoft Edge’s rendering or print handoff, or the Windows printer queue and driver. The fastest fix is not random reinstalling—it is a short set of tests that narrows down the guilty party.
Microsoft’s Edge troubleshooting guidance recommends exactly this kind of isolation: test another document, then another application, before blaming either the browser or the printer.
A desktop computer displays printer settings beside a wireless printer in a tidy home office. First: identify where the blank page begins​
Before changing anything, look at Print Preview in Microsoft Edge.
  • Preview is blank too: Edge may be failing to render that PDF, or the PDF itself may contain unsupported, damaged, hidden, or otherwise troublesome content.
  • Preview looks correct, but the physical page is blank: The printer driver, print queue, printer settings, or printer hardware is more likely to blame.
  • Only one PDF prints blank: Treat the document as the primary suspect.
  • Every PDF prints blank, but Word documents print normally: Focus on Edge and its print path.
  • PDFs and Word documents both print blank or fail: Focus on the Windows printer, its driver, and its queue.
This simple split matters. A printer driver can treat output from different applications differently, so “Word works” does not completely clear the driver—but it gives you a much better starting point.
Test the PDF and Edge before touching the driver​
Open a different PDF in Microsoft Edge—preferably one from a reliable source or a file you know printed successfully in the past.
  1. Press Ctrl+P.
  2. Confirm you have selected the correct printer.
  3. Check the preview.
  4. Print one page only.
If the second PDF prints normally, the original file is likely the issue. Download a fresh copy if it came from a website or email attachment, then try again. A damaged font, odd transparency setting, or malformed graphic can affect a single PDF while leaving every other document untouched.
If the test PDF also prints blank, restart Edge completely:
  1. Close every Microsoft Edge window.
  2. Reopen Edge.
  3. Open the PDF again.
  4. Press Ctrl+P and retry.
Microsoft specifically recommends retrying or restarting Edge when its print preview fails or when its built-in PDF viewer cannot supply a preview.
Try the Windows system print dialog​
Microsoft Edge has its own print interface, but Windows also provides the older system print dialog, which exposes more printer-specific settings.
  1. Open the PDF in Edge.
  2. Press Ctrl+Shift+P to open Print using system dialog.
  3. Select the printer.
  4. Select Preferences if available.
  5. Check settings such as:
  • Paper size
  • Paper source or tray
  • Print quality
  • Color versus grayscale
  • Any vendor-specific “economy,” “draft,” or toner-saving settings
  1. Print a single page.
That system dialog can be especially useful where a printer’s own preferences include options not shown in Edge’s streamlined window. Microsoft documents Ctrl+Shift+P as the shortcut for the system print dialog and notes that printer preferences can expose paper source, media, and print-quality controls.
If Edge’s preview is correct but printing from the system dialog succeeds where ordinary Edge printing fails, the browser’s standard print path may have been the snag. Not glamorous, perhaps, but neither is explaining to finance why their 48-page report is now a 48-page snowfall.
Check whether the issue extends beyond Edge​
Next, print from another Windows application. Word is ideal if installed, but any app that can print ordinary text will do.
In Word:
  1. Create a blank document.
  2. Type a few lines of text.
  3. Print using the same printer.
Microsoft’s diagnostic advice uses this comparison because it shows whether the trouble is isolated to Edge or affects Windows printing more generally.
What the result means​
ResultMost likely next step
Other apps print correctly; Edge PDFs are blankRestart Edge, test another PDF, and use the system print dialog
Only one PDF failsReplace or re-download the file; ask its sender for a new copy
Other apps also failClear the print queue, then update or reinstall the driver
No apps print, and the printer is offline or unresponsiveCheck power, cable/Wi-Fi connection, paper, ink/toner, and printer status first
Clear stuck jobs from the Windows print queue​
A corrupt or stalled job can poison the queue for every job behind it. Windows does not always announce this with appropriate drama; sometimes it simply lets the queue sit there like a bad meeting that refuses to end.
Windows 11​
  1. Open Settings.
  2. Go to Bluetooth & devices > Printers & scanners.
  3. Select your printer.
  4. Choose Open print queue.
  5. Right-click each pending job and select Cancel.
Windows 10​
  1. Open Settings.
  2. Go to Devices > Printers & scanners.
  4. Choose Open queue.
  5. Cancel all pending jobs.
If jobs will not disappear or printing continues to hang, restart the Print Spooler service:
  1. Press Windows+R.
  2. Type services.msc, then press Enter.
  3. Find Print Spooler.
  4. Right-click it and select Restart.
Microsoft identifies the spooler as the service responsible for managing Windows print jobs; when it fails, jobs may remain stuck and printers can become unresponsive.
For persistent queue corruption, Microsoft’s broader Windows printer guidance also documents stopping the spooler, removing the queued files from %WINDIR%\system32\spool\PRINTERS, and starting the service again. Only do this after stopping Print Spooler—do not delete files from an active queue folder.
Update—or reinstall—the printer driver​
If PDF previews look normal and multiple applications produce blank output, the printer driver becomes the leading suspect. Drivers translate Windows and application output into commands the particular printer understands. When that translation goes sideways, a page can feed through perfectly while receiving little or no printable content.
Start with the least disruptive route:
  1. Visit the printer manufacturer’s support page.
  2. Find the driver matching the exact printer model and your Windows version.
  3. Install the current driver.
  4. Restart the PC and printer.
  5. Print a Windows test page, then retry the PDF.
Microsoft recommends obtaining the latest driver from the printer manufacturer, and notes that Windows can also help reinstall a printer through Settings > Bluetooth & devices > Printers & scanners.
If updating does not help, remove and re-add the printer:
  1. Go to Settings > Bluetooth & devices > Printers & scanners in Windows 11.
  2. Select the affected printer and choose Remove.
  3. Restart the PC.
  4. Return to Printers & scanners.
  5. Select Add device and let Windows search for the printer.
  6. If Windows cannot find it, choose Add manually and follow the prompts.
On Windows 10, the comparable location is Settings > Devices > Printers & scanners.
After reinstallation, print a test page before returning to the PDF. If the test page itself is blank, the issue is not Edge and not the PDF; inspect printer consumables, firmware, physical printhead or toner issues, and the manufacturer’s diagnostics.
A practical order of operations​
For most home and office PCs, this sequence avoids wasted effort:
  1. Check Edge preview.
  2. Try a different PDF.
  3. Print a simple document from another app.
  4. Use Edge’s system print dialog with Ctrl+Shift+P.
  5. Cancel the print queue and restart Print Spooler.
  6. Update or reinstall the printer driver.
  7. Print a Windows test page.
Windows 11 users can also run the automated printer troubleshooter in the Get Help app before the more manual driver work. Microsoft recommends it as an initial diagnostic step for common printer problems.
One final housekeeping note: Windows 10 remains capable of using printers, but Microsoft ended free Windows 10 security updates and support on October 14, 2025. If this is a business-critical PC, keep that broader support status in mind while evaluating driver and device reliability.
