Snipping Tool’s delay timer is the built-in Windows answer to screenshots that vanish the moment you click away: context menus, File Explorer drop-downs, app tooltips, hover cards, and right-click commands. Microsoft’s current Snipping Tool guidance for Windows 11 and Windows 10 confirms that a timed snip lets you start a countdown, open the temporary interface you need, and then capture it once the screen enters selection mode.
The practical catch is easy to miss: the delay does not always take the picture for you. With Rectangular or Freeform mode, the countdown ends by placing Windows into snipping mode; you still drag around the open menu or tooltip. That is why the timer succeeds where an immediate Windows + Shift + S capture fails—the menu remains visible when the selection overlay appears.
For most documentation screenshots, a five-second delay is enough. Use a longer setting when you need to navigate through nested menus, trigger a tooltip by hovering, or arrange a dialog box before the capture begins.
Windows 11 desktop showing Snipping Tool countdown over File Explorer’s Documents folder and a context menu. Start a delayed snip​
The Snipping Tool app is open on its main interface with controls for starting a new capture or recording.
Open Snipping Tool from Start. If you capture screenshots frequently, pin it to the taskbar; the delayed-capture controls are in the full app, not in the standard Windows + Shift + S capture overlay.
In the app’s toolbar, select Delay or the clock-shaped delay control, then choose the countdown available on your installation. The exact choices can differ across app versions. Microsoft’s support page still describes its Alt + D shortcut as a delay control with a one-to-five-second range, while current Windows 11 installations commonly show preset choices such as three, five, and 10 seconds. The safe rule is simple: choose the displayed interval that gives you enough time to reopen the item you want to preserve.
Next, choose a snipping mode before pressing New:
  • Rectangular mode is the best default for a menu, tooltip, or a small portion of an app window because it lets you exclude unrelated screen content.
  • Window mode captures an entire app window. It is useful when the open menu needs to be shown in the context of the program that owns it, but it may include more than you intended.
  • Full-screen mode is appropriate when the location of the menu or overlay matters, such as a Start menu, desktop context menu, or multi-window layout.
  • Freeform mode is rarely necessary for UI documentation, but it can isolate an irregular on-screen element.
Select New only after setting both the delay and mode. The timer begins immediately. Switch back to the target application, open the menu, and keep the pointer where it needs to be if you are capturing a hover-triggered tooltip.
When the countdown ends, the display dims or turns gray. With Rectangular or Freeform mode, drag over the target while it is still visible. With Window mode, select the highlighted window. A Full-screen snip captures the display without requiring you to draw a box.
Capture menus without closing them​
The timer changes the order of operations. Normally, opening Snipping Tool or clicking a capture button moves focus away from the application, causing a context menu or drop-down list to disappear. A delayed snip gives you a short period to restore focus to the target app after capture has been armed.
For a right-click context menu in File Explorer, for example, select a five-second delay and Rectangular mode, click New, then return to File Explorer. Right-click the folder, file, or empty area whose menu you need. When the screen dims, drag tightly around the menu. The result shows the command list exactly as it appeared before the capture overlay arrived.
A tooltip works the same way, but timing is more sensitive. Arm the snip, move back to the app, and hover over the button or text that generates the tooltip. Avoid clicking the item unless a click is necessary to reveal it. Once the overlay appears, keep the pointer steady and drag around the tooltip.
Nested menus need more preparation. First identify the route—such as View > Show > File name extensions in File Explorer—then choose a longer delay. Open the first menu and move across the submenu before the timer expires. If the menu collapses when the gray overlay appears, try again with a shorter route, a longer delay, or a full-screen capture that requires no final drag.
A useful limitation: Snipping Tool can record what Windows is displaying, but it cannot capture every protected surface. Screens that deliberately block screenshots, including some sign-in, DRM-protected, secure-desktop, and security-product windows, may appear black, blank, or unavailable. A missing capture in those situations is not a timer failure.
The keyboard shortcut is fast, but it is not a delayed shortcut​
Windows + Shift + S opens the image-snipping overlay immediately. Microsoft documents it as a shortcut for selecting a screen region and copying the resulting image to the clipboard. It is excellent for a static window already on screen, but it is the wrong starting point for a drop-down or tooltip that will close as soon as you invoke it.
Use the main Snipping Tool window to set a delay first. Microsoft also documents these in-app keyboard commands:
  • Alt + D moves to the delay control.
  • Alt + M opens the snipping-mode control.
  • Alt + N starts a new snip using the most recently selected mode.
  • Ctrl + S saves the captured image.
  • Ctrl + C copies the finished snip to the clipboard.
The fastest reliable keyboard-led workflow is therefore: open Snipping Tool, select the delay with Alt + D, choose the mode with Alt + M if necessary, and start the capture with Alt + N. Then use the countdown to reopen the disappearing UI element.
This distinction matters for users who expect Windows + Shift + S to inherit a timer selected earlier in the full app. Treat that shortcut as an immediate capture command unless your installed version visibly offers a delay control in its overlay. Windows and Snipping Tool update separately, so interface details can vary even among PCs on the same Windows release.
Save the image rather than trusting the clipboard​
After the capture, Snipping Tool opens the image for review. You can crop excess background, draw annotations, or use the copy command to paste it into a ticket, chat, Word document, or image editor. For a screenshot that must be retained, press Ctrl + S and choose a filename and location.
Microsoft says current Snipping Tool versions can automatically save screenshots to the Screenshots folder, with the behavior and default location configurable in the app’s Settings. That is convenient, but it should not replace an explicit save when the image is evidence for an incident record, a configuration guide, or a support case. Automatic saving can be changed, disabled, redirected, or obscured by notification and app settings.
Use PNG for most Windows interface captures. It preserves text and sharp UI edges without JPEG compression artifacts. JPEG is reasonable only when file size matters more than text clarity. Give the file a name that captures the application, screen, and date—such as FileExplorer-ContextMenu-2026-09-11.png—rather than leaving a long sequence of indistinguishable “Screenshot” files.
Before sharing, inspect the full image at normal size. Delayed screenshots often collect more than intended: notification banners, browser tabs, account names, file paths, email addresses, and other material outside the menu itself. Crop the image or redact sensitive information before it leaves the device.
Windows 10 still has the feature, but the environment has changed​
Microsoft’s support material continues to describe delayed screenshots for both Windows 11 and Windows 10, including the legacy approach of opening a menu and using Ctrl + PrtSc to activate a screen capture. The modern timer workflow remains simpler because it gives you time to construct the target state before entering capture mode.
Windows 10 reached end of support on October 14, 2025. The Snipping Tool instructions may still work on existing Windows 10 PCs, but an organization relying on those machines should not mistake an available screenshot utility for a supported operating system. For managed endpoints, the relevant question is whether the app’s version and capture behavior are consistent enough for support documentation and service-desk procedures.
For everyday use, the outcome is straightforward: arm the delay in the full Snipping Tool app, reopen the UI element that normally disappears, select it when the screen dims, and save a deliberate copy. That sequence captures the transient Windows interface users actually need to show—rather than a blank desktop after the menu has already closed.
