A default printer that changes itself is Windows trying to be helpful with the enthusiasm of a golden retriever carrying a muddy shoe. The usual culprit is Let Windows manage my default printer: when enabled, Windows can choose the most recently used printer, including after a network or location change. If you need invoices, labels, or schoolwork to land on one predictable device every time, turn that automation off and set the printer manually.
This guide covers the supported Settings route first, then the Print Spooler reset to use when Windows refuses to remember the choice.
A desktop monitor shows Windows printer settings beside a wireless printer printing a document. Start with the setting that causes most surprise changes​
Windows 11 and Windows 10 can automatically assign the default printer based on recent use. That may be convenient on a laptop moving between home and office, but it is the opposite of convenient when the “default” suddenly becomes a PDF writer, an old network printer, or the label printer across the building.
Windows 11​
  • Open Start > Settings.
  • Select Bluetooth & devices > Printers & scanners.
  • Find Let Windows manage my default printer under Printer preferences.
  • Turn it Off.
  • Select the printer you actually want to use.
  • Choose Set as default.
Settings shows the Printers & scanners page with the Add device button and the installed printer list for managing or removing printers.
Windows should now mark that device as Default.
Windows 10​
  • Select Devices > Printers & scanners.
  • Clear Let Windows manage my default printer.
  • Select the preferred printer, then choose Manage.
  • Select Set as default.
If the Set as default button is missing, revisit the previous step. Microsoft’s own guidance confirms that Windows hides the manual default option while automatic printer management is enabled.
Quick check: Restart the PC, open an application such as Notepad, press Ctrl+P, and confirm that the intended printer is already selected. Do this before printing a 40-page document to the neighbor’s long-retired inkjet.
Confirm you chose the right printer, not its doppelgänger​
A single physical printer can appear in Windows more than once. You may see duplicates created by an old USB connection, a manufacturer utility, an earlier network address, a WSD port, or a virtual-printing feature.
In Printers & scanners, inspect the device name carefully before setting it as default. Pay particular attention to entries such as:
  • A printer name followed by Copy 1 or a similar suffix
  • Old office or home network printers
  • Microsoft Print to PDF, Microsoft XPS Document Writer, or fax devices
  • Manufacturer-created “smart” or cloud-print entries
  • A printer marked Offline or Error
The default printer can be selected successfully yet still be useless if it points to an obsolete port or unreachable network device. If its status is offline, make sure the PC and printer are connected to the same network, especially where homes or offices use extenders, guest Wi-Fi, or multiple wireless networks.
Clear stuck jobs before resetting anything​
A stuck print job does not normally change the default printer by itself, but it can make the printer look unresponsive and lead users to choose another device in frustration. Clear the queue first.
  • Go to Settings > Printers & scanners.
  • Select the printer that is causing trouble.
  • Choose Open print queue.
  • Cancel every pending item.
If jobs vanish, return, or cannot be cancelled, the Print Spooler is the next stop.
Reset the Print Spooler when settings will not stick​
The Print Spooler is the Windows service that manages queued print jobs. Microsoft recommends restarting it when printing stops, jobs freeze, or a printer becomes unresponsive. Restarting the service is safe, but any active print jobs may need to be sent again afterward.
Fast method: restart the service​
  • Press Windows + R.
  • Type services.msc, then press Enter.
  • Find Print Spooler.
  • Right-click it and select Restart.
After the service restarts, return to Printers & scanners, verify that automatic default-printer management remains off, and set your preferred printer as the default again.
Thorough method: clear the spooler queue​
Use this only if the queue is stuck or the service restart did not resolve the problem.
  • Open Services by searching for it from Start.
  • Double-click Print Spooler.
  • Select Stop, then select OK.
  • In File Explorer, open:
    C:\Windows\System32\spool\PRINTERS
  • Delete the files inside that folder. Do not delete the folder itself.
  • Return to Services and double-click Print Spooler again.
  • Select Start.
  • Set Startup type to Automatic, then select OK.
This removes stalled jobs that may be clogging the printing pipeline. It does not remove installed printers, but it does discard pending documents, so save your work and be ready to print again.
When the printer still keeps changing​
If Windows continues to swap the default printer after you disable automatic management, work through these checks in order:
  • Remove duplicate printers.
    In Printers & scanners, remove stale copies and printers you no longer use. Leave the active device installed.
  • Reconnect the printer.
    For a network printer, confirm its connection and restart the printer itself. For USB models, reconnect the cable directly to the PC where possible.
  • Update or reinstall the printer driver.
    Microsoft identifies conflicting or outdated drivers as a common cause of spooler trouble. In Device Manager, look under Printers or Print queues for old or duplicate entries. Use the current driver from the printer manufacturer when Windows’ built-in driver is not sufficient.
  • Test from a simple application.
    Print a short page from Notepad before blaming Word, Excel, a browser, or a line-of-business app. If the default holds in Notepad but not in one application, that program may be remembering its own printer selection.
  • Use the Windows printer troubleshooter.
    On Windows 11, Microsoft directs users to the automated printer troubleshooter in the Get Help app. It can diagnose common printing and connection issues without sending you into the registry with a flashlight.
Should you edit the registry?​
Usually, no. The registry contains values associated with legacy default-printer behavior, and you will find plenty of old forum advice pointing to them. But the supported and safest fix for ordinary Windows 10 and Windows 11 systems is the Settings toggle: disable Windows-managed defaults, then explicitly choose the printer.
Registry changes are better reserved for managed environments where an IT administrator has identified a specific policy or configuration conflict. Editing the wrong value can create a more interesting problem than a wandering printer—which is not the sort of excitement most people seek from office hardware.
The practical fix, in one minute​
For most PCs, the durable solution is simply:
  • Turn off Let Windows manage my default printer.
  • Select the desired device and choose Set as default.
  • Clear any stuck queue.
  • Restart the Print Spooler only if printing or saved settings remain unreliable.
  • Remove duplicate printer entries and update the driver if the issue returns.
One final Windows 10 note: Microsoft ended free Windows 10 security updates and technical support on October 14, 2025. The steps above still apply to installed Windows 10 PCs, but a move to Windows 11 is worth considering for a supported long-term setup—especially where printers are business-critical rather than merely occasional paper confetti machines.
