A Windows timer that counts down silently is a poor assistant—and an excellent way to forget your tea. If the Clock app reaches zero without an audible alert, check the audio output, app volume and notification settings before assuming the timer is broken.
This guide covers Windows 10 and Windows 11 and takes about 10 minutes. You’ll need access to the PC’s Settings app and a working speaker or pair of headphones.
A laptop displays a timer that has finished alongside sound, volume mixer, and notification settings. Start with a short test​
Open Start, search for Clock, and select Timer. Create or choose a short timer, start it, and keep the PC awake while it runs.
When the timer finishes, note what happens:
  • You see an alert but hear nothing: Start with the volume and output checks.
  • You hear nothing and see no alert: Check notifications and Do not disturb or Focus assist, too.
  • Other apps also have no sound: The problem may affect Windows audio more broadly.
Repeat the short timer after each set of changes so you can tell which fix worked.
Check volume and the output device​
Select the speaker icon on the taskbar and make sure Windows is not muted. Raise the volume to a comfortable level, then play a video or another familiar sound to check the speakers.
If you use external speakers or headphones, check their power and volume controls as well. A monitor, Bluetooth headset or docking station may be selected as the output even when you expect sound from the laptop speakers.
To check the selected device:
  1. Open Settings > System > Sound.
  2. Under Output, select the speaker or headphones you want to use.
  3. Play another sound to confirm you can hear it.
If you can hear other audio but the timer remains silent, check the app mixer:
  • Windows 11: In Settings > System > Sound, open Volume mixer. Under Apps, look for Clock. If it appears, make sure it isn’t muted and check its output device.
  • Windows 10: Right-click the taskbar speaker icon and select Open Volume mixer. If Clock appears, make sure its volume is raised and it isn’t muted.
Microsoft notes that individual apps can have their own volume settings and may use a different output device from the system default. If Clock doesn’t appear in the mixer, don’t assume that proves a fault; continue with the notification checks.
In short: Working system audio is a good start, but it doesn’t rule out an app-specific volume or output setting.
Turn on Clock notifications​
Windows can show an alert without playing a notification sound, so check both settings.
Windows 11​
  1. Open Settings > System > Notifications.
  2. Make sure Notifications is on.
  3. Under Notifications from apps and other senders, find Clock and turn it on if it is listed.
  4. Select Clock to review its options. Enable notification banners and Play a sound if those options are available.
Windows 10​
  1. Open Settings > System > Notifications & actions.
  2. Make sure notifications from apps and other senders are enabled.
  3. Find Clock or Alarms & Clock in the app list and turn its notifications on if listed.
  4. Select the app and check its banner and sound options.
Names and available controls can vary by Windows and Clock app version. If the app isn’t listed, continue with the remaining checks rather than looking for a setting that may not be available on your PC. Microsoft documents separate controls for notification banners and sounds, which is why seeing a notification doesn’t necessarily mean you’ll hear one.
Review Do not disturb or Focus assist​
These features can suppress notifications during work, games or full-screen activity. Temporarily turn them off and run another short timer; that’s more useful than guessing whether a particular alert should be allowed through.
On Windows 11:
  1. Go to Settings > System > Notifications.
  2. Turn Do not disturb off for the test.
  3. Expand Turn on do not disturb automatically and review any rules that could switch it back on.
Windows 11 Focus sessions can also turn on Do not disturb automatically. Check Settings > System > Focus if the problem seems to occur during a session. You can review priority notification options if you prefer to keep Do not disturb enabled, but test your timer afterward rather than assuming the exception works as intended.
On Windows 10:
  1. Go to Settings > System > Focus assist.
  2. Select Off for the test.
  3. Review Automatic rules, particularly if the problem occurs while gaming, duplicating a display or using an app full screen.
In short: If alerts work with these features off, review their automatic rules before turning them back on.
Keep the PC awake​
Microsoft says Clock alarms and timers can work when the app is closed or the device is locked. But if Clock warns that notifications only appear while the device is awake, the PC must not go to sleep before the timer expires. A dark screen and a sleeping PC are not the same thing.
For a longer timer, plug in your laptop and review sleep settings:
  • Windows 11: Settings > System > Power & battery, then look for Screen and sleep.
  • Windows 10: Settings > System > Power & sleep.
Adjust the sleep setting long enough for your timer, then restore your preferred setting afterward if you changed it for testing.
If the timer is still silent​
Restart the PC and repeat the short test. If other sounds are also missing, Windows 11 users can open Get Help, search for audio troubleshooter, and follow the prompts. Microsoft provides that troubleshooter for broader sound problems.
If other audio works and Clock alone still misbehaves, you can try Repair for the app if Windows offers it:
  • Windows 11: Go to Settings > Apps > Installed apps, find Clock, open its menu and select Advanced options, then Repair.
  • Windows 10: Go to Settings > Apps > Apps & features, select Clock or Alarms & Clock, and look for Advanced options > Repair.
Repair is the less disruptive choice; Reset may remove app data, so use it only after considering any saved Clock settings.
The final check is simple: run a short timer with the intended speakers connected, the PC awake and your normal notification settings restored. You’re done when it finishes and you can hear the alert where you expect it.
Windows 10 remains usable, but Microsoft ended its standard support on October 14, 2025; users should consider their security-update options or a move to a supported Windows version.
