MrThijs
Hey there,
I'm having problems with a HP EliteBook 8570w, I'm having BSODS with the BCCode 00000007e and I'm out of clues now. I did a total reset to factory settings, updated all the outdated drivers and still it occurs. It doesn't happen during the startup of windows (!) it happens randomly!
Details of the code:
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000007e (0xffffffffc0000005, 0xfffff880014fba78, 0xfffff88003b717e8, 0xfffff88003b71040). A dump was saved in: C:\windows\MEMORY.DMP. Report Id: 011214-11996-01.
Event ID: 1001
I've attached the dump file, i couldn't find anymore of the errorcode. It's happening for quite a while now and I'm totally clueless.
P.S I'm sorry my any grammar faulths, English is not my native tongue.
BugCheck 1000007E, {ffffffffc0000005, fffff880014fba78, fffff88003b717e8, fffff88003b71040}
Probably caused by : iaStorA.sys ( iaStorA+60a78 )
Followup: MachineOwner
the dmp file is pointing to the Rapid Storage Technology driver and it may need updating. I''ll check the...
apologies but I'm out of time and must go out. I''ll be back later although i did look at your dmp file briefly but couldnt access the HP driver section. I would suggest checking your bios if you have access to the site. Your current bios is:
BiosVersion = 68IAV Ver. F.43
BiosReleaseDate = 10/08/2013
Good luck and I'll be back in a few hours.
MrThijs
I checked my bios version and it's the latest available for Windows 7 Home Premium 64bit ( the one I have on my laptop at the moment )
the dmp file is pointing to the Rapid Storage Technology driver and it may need updating. I''ll check the driver stack and see how things are.
AlcGener.sys Thu Dec 16 12:35:22 2010: Alcor Micro Smart Card Reader Driver: Please update:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome/?sp4ts.oid=5257504&spf_p.tpst=swdMain&spf_p.prp_swdMain=wsrp-navigationalState%3DswEnvOID%253D4058%257CswLang%253D%257Caction%253DlistDriver&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#Driver - Storage
ArcSoftVCapture.sys Fri Feb 03 01:41:02 2012: Magic-i Driver from ArcSoft, update if possible::
btwampfl.sys Fri Jun 29 14:59:59 2012; Broadcom Bluetooth driver, please update:
http://h20565.www2.hp.com/portal/si...eTok=com.vignette.cachetoken#Driver - Network
HpqKbFiltr.sys Tue Feb 16 18:22:39 2010: HP Quick Launch Buttons HpqKbFiltr Keyboard Filter driver, update if possible? I looked on the machines webpage but couldn't work out what related to this driver. Perhaps you'll have better luck?
iaStorA.sys Mon Oct 28 21:15:26 2013: Intel RST (Rapid Storage Technology) driver. I know this sounds counter to what we normally advise but can you install the driver posted on the machines webpage. It is older than the one above but as it's mentioned specifically in the dmp files it may help if you install the earlier version.
http://h20565.www2.hp.com/portal/si...eTok=com.vignette.cachetoken#Driver - Storage
iusb3hcs.sys Tue Mar 27 09:11:21 2012: Intel USB3 driver, please update:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome/?sp4ts.oid=5257504&spf_p.tpst=swdMain&spf_p.prp_swdMain=wsrp-navigationalState%3DswEnvOID%253D4058%257CswLang%253D%257Caction%253DlistDriver&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#Driver - Chipset
Netwsw00.sys Wed May 29 14:10:47 2013: Intel® Wireless WiFi Link Adapter. Later version on machines web page:
Smb_driver_Intel.sys Sat May 19 00:50:03 2012: Synaptics SMBus Driver, please update:
http://h20565.www2.hp.com/portal/si...en#Driver - Keyboard, Mouse and Input Devices
SPUVCbv_x64.sys Mon Mar 26 13:11:56 2012: Sunplus Technology Digital Camera Driver, please update:
SzCCID.sys Wed Sep 05 10:12:28 2012: Generic USB CCID Driver (Alcor Micro Smart Card Reader driver):
If the bsods continue after updating please run memtest86:
http://www.memtest.org/
Please post any new dmp files.
MrThijs
I've updated them all like you said, now i just need to see if the bsod occurs again, or an other error occurs. Let's hope for the best.
MrThijs
Still no succes, after like 45 minutes of using my computer the BSOD occured again, same errorcode. I've attached the dump file. I can't believe it's still happening after everything I've done so far...
Hmm.. Are you sure thats the latest dmp file as the drivers are still the same dates as above.
MrThijs
Yes 100% sure i checked the "name" of it (its arranged by date) and i uploaded it like 5 mins after the bsod
Ok .. Hmm... tell me when you updated did you go for the very latest date that was showing on the update because most of those drivers should know be reading 2013 not 2012 as above. I'm sure you probably did but just had to ask...
Hmm...strange as I just checked the dmp file again and it's definitely showing the old driver set. Try using the tool found in this thread and post the results:
I really need to see the updated driver dmp file
Oh and did you run memtest86?
