Ridillz333
[h=3]Hello,[/h][h=3]I recently put together a new PC and have been having random BSOD problems from the word go. They happen at random times sometimes one every minute for an hour(as many as 50 a day), and sometimes days w/o issue. Its really starting to drive me up the wall. I tried to exhaust all other methods before posting like this, to avoid dumping the problem on someone else, but my patients has run out and the new semester is starting so I need a stable system.
Any help would be appreciated
Cheers.
RAMMon v1.0 Build: 1002 built with SysInfo v1.0 Build: 1006
PassMark (R) Software - www.passmark.com[/h]Memory Summary For COREY-PC
Number of Memory Devices: 2 Total Physical Memory: 4072 MB (4096 MB) Total Available Physical Memory: 2889 MB Memory Load: 29%
ItemSlot #1Slot #2Slot #3Slot #4
[TD="class: value, width: 240"]Ram Type [/TD]
[TD="class: altvalue"]Not Populated [/TD]
[TD="class: altvalue"]DDR3 [/TD]
[TD="class: value, width: 240"] Standard Name [/TD]
[TD="class: altvalue"] [/TD]
[TD="class: altvalue"]DDR3-1333 [/TD]
[TD="class: value, width: 240"] Module Name [/TD]
[TD="class: altvalue"]PC3-10600 [/TD]
[TD="class: value, width: 240"]Memory Capacity (MB) [/TD]
[TD="class: altvalue"]2048 [/TD]
[TD="class: value, width: 240"]Bus Clockspeed (Mhz) [/TD]
[TD="class: altvalue"]666.67 [/TD]
[TD="class: value, width: 240"]Jedec Manufacture Name [/TD]
[TD="class: altvalue"]Corsair [/TD]
[TD="class: value, width: 240"]Search Amazon.com [/TD]
[TD="class: altvalue"]Search! [/TD]
[TD="class: value, width: 240"]SPD Revision [/TD]
[TD="class: altvalue"]1.0 [/TD]
[TD="class: value, width: 240"]Registered [/TD]
[TD="class: altvalue"]No [/TD]
[TD="class: value, width: 240"]ECC [/TD]
[TD="class: value, width: 240"]DIMM Slot # [/TD]
[TD="class: altvalue"]2 [/TD]
[TD="class: altvalue"]4 [/TD]
[TD="class: value, width: 240"]Manufactured [/TD]
[TD="class: altvalue"]Year 2000 [/TD]
[TD="class: value, width: 240"]Module Part # [/TD]
[TD="class: altvalue"]CMZ4GX3M2A1600C8 [/TD]
[TD="class: value, width: 240"]Module Revision [/TD]
[TD="class: altvalue"]0x0 [/TD]
[TD="class: value, width: 240"]Module Serial # [/TD]
[TD="class: value, width: 240"]Module Manufacturing Location [/TD]
[TD="class: altvalue"]1 [/TD]
[TD="class: value, width: 240"]# of Row Addressing Bits [/TD]
[TD="class: altvalue"]14 [/TD]
[TD="class: value, width: 240"]# of Column Addressing Bits [/TD]
[TD="class: altvalue"]10 [/TD]
[TD="class: value, width: 240"]# of Banks [/TD]
[TD="class: altvalue"]8 [/TD]
[TD="class: value, width: 240"]# of Ranks [/TD]
[TD="class: value, width: 240"]Device Width in Bits [/TD]
[TD="class: value, width: 240"]Bus Width in Bits [/TD]
[TD="class: altvalue"]64 [/TD]
[TD="class: value, width: 240"]Module Voltage [/TD]
[TD="class: altvalue"]1.5V [/TD]
[TD="class: value, width: 240"]CAS Latencies Supported [/TD]
[TD="class: altvalue"]6 8 9 [/TD]
[TD="class: value, width: 240"]Timings @ Max Frequency [/TD]
[TD="class: altvalue"]9-9-9-24 [/TD]
[TD="class: value, width: 240"] Minimum Clock Cycle Time, tCK (ns) [/TD]
[TD="class: altvalue"]1.500 [/TD]
[TD="class: value, width: 240"] Minimum CAS Latency Time, tAA (ns) [/TD]
[TD="class: altvalue"]13.500 [/TD]
[TD="class: value, width: 240"] Minimum RAS to CAS Delay, tRCD (ns) [/TD]
[TD="class: value, width: 240"] Minimum Row Precharge Time, tRP (ns) [/TD]
[TD="class: value, width: 240"] Minimum Active to Precharge Time, tRAS (ns) [/TD]
[TD="class: altvalue"]36.000 [/TD]
[TD="class: value, width: 240"] Minimum Row Active to Row Active Delay, tRRD (ns) [/TD]
[TD="class: altvalue"]7.500 [/TD]
[TD="class: value, width: 240"] Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns) [/TD]
[TD="class: altvalue"]50.625 [/TD]
[TD="class: value, width: 240"] Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns) [/TD]
[TD="class: altvalue"]110.000 [/TD]
[TD="class: value, width: 240"] [/TD]
[TD="class: value, width: 240"]DDR3 Specific SPD Attributes [/TD]
[TD="class: value, width: 240"] Write Recovery Time, tWR (ns) [/TD]
[TD="class: altvalue"]15.000 [/TD]
[TD="class: value, width: 240"] Internal Write to Read Command Delay, tWTR (ns) [/TD]
[TD="class: value, width: 240"] Internal Read to Precharge Command Delay, tRTP (ns) [/TD]
[TD="class: value, width: 240"] Minimum Four Activate Window Delay, tFAW (ns) [/TD]
[TD="class: altvalue"]37.500 [/TD]
[TD="class: value, width: 240"] RZQ / 6 Supported [/TD]
[TD="class: altvalue"]Yes [/TD]
[TD="class: value, width: 240"] RZQ / 7 Supported [/TD]
[TD="class: value, width: 240"] DLL-Off Mode Supported [/TD]
[TD="class: value, width: 240"] Maximum Operating Temperature (C) [/TD]
[TD="class: altvalue"]95 [/TD]
[TD="class: value, width: 240"] Refresh Rate at Extended Operating Temperature Range [/TD]
[TD="class: altvalue"]1X [/TD]
[TD="class: value, width: 240"] Auto-self Refresh Supported [/TD]
[TD="class: value, width: 240"] On-die Thermal Sensor Readout Supported [/TD]
[TD="class: value, width: 240"] Partial Array Self Refresh Supported [/TD]
[TD="class: value, width: 240"] Thermal Sensor Present [/TD]
[TD="class: value, width: 240"] Non-standard SDRAM Type [/TD]
[TD="class: altvalue"]Standard Monolithic [/TD]
[TD="class: value, width: 240"] Module Type [/TD]
[TD="class: altvalue"]UDIMM [/TD]
[TD="class: value, width: 240"] Module Height (mm) [/TD]
[TD="class: altvalue"]31 [/TD]
[TD="class: value, width: 240"] Module Thickness (front), (mm) [/TD]
[TD="class: value, width: 240"] Module Thickness (back), (mm) [/TD]
[TD="class: value, width: 240"] Module Width (mm) [/TD]
[TD="class: altvalue"]133.5 [/TD]
[TD="class: value, width: 240"] Reference Raw Card Used [/TD]
[TD="class: altvalue"]Raw Card B Rev. 0 [/TD]
[TD="class: value, width: 240"] DRAM Manufacture ID [/TD]
[TD="class: altvalue"]0 [/TD]
[TD="class: value, width: 240"] # of DRAM Rows [/TD]
[TD="class: value, width: 240"] # of Registers [/TD]
[TD="class: value, width: 240"] Register Manufacturer [/TD]
[TD="class: value, width: 240"] Register Type [/TD]
[TD="class: value, width: 240"] Register Revision [/TD]
[TD="class: value, width: 240"]XMP Attributes [/TD]
[TD="class: value, width: 240"] XMP Revision [/TD]
[TD="class: altvalue"]1.2 [/TD]
[TD="class: value, width: 240"] Enthusiast / Certified Profile [/TD]
[TD="class: value, width: 240"] Module voltage [/TD]
[TD="class: altvalue"]1.50V [/TD]
[TD="class: value, width: 240"] Clock speed (Mhz) [/TD]
[TD="class: altvalue"]800.00 [/TD]
[TD="class: value, width: 240"] Minimum clock cycle time, tCK (ns) [/TD]
[TD="class: altvalue"]1.250 [/TD]
[TD="class: value, width: 240"] Supported CAS latencies [/TD]
[TD="class: altvalue"]6 8 [/TD]
[TD="class: value, width: 240"] Minimum CAS latency time, tAA (ns) [/TD]
[TD="class: altvalue"]10.000 [/TD]
[TD="class: value, width: 240"] Minimum RAS to CAS delay time, tRCD (ns) [/TD]
[TD="class: value, width: 240"] Minimum row precharge time, tRP (ns) [/TD]
[TD="class: value, width: 240"] Minimum active to precharge time, tRAS (ns) [/TD]
[TD="class: altvalue"]30.000 [/TD]
[TD="class: value, width: 240"] Supported timing at highest clock speed [/TD]
[TD="class: altvalue"]8-8-8-24 [/TD]
[TD="class: value, width: 240"] Minimum Active to Auto-Refresh Delay, tRC (ns) [/TD]
[TD="class: value, width: 240"] Minimum Recovery Delay, tRFC (ns) [/TD]
[TD="class: value, width: 240"] Minimum Write Recovery time, tWR (ns) [/TD]
[TD="class: value, width: 240"] Minimum Write to Read CMD Delay, tWTR (ns) [/TD]
[TD="class: value, width: 240"] Minimum Read to Pre-charge CMD Delay, tRTP (ns) [/TD]
[TD="class: value, width: 240"] Maximum Average Periodic Refresh Interval, tREFI (us) [/TD]
[TD="class: altvalue"]7.750 [/TD]
[TD="class: value, width: 240"] Write to Read CMD Turn-around Time Optimizations [/TD]
[TD="class: altvalue"]No adjustment [/TD]
[TD="class: value, width: 240"] Read to Write CMD Turn-around Time Optimizations [/TD]
[TD="class: value, width: 240"] Back 2 Back CMD Turn-around Time Optimizations [/TD]
[TD="class: value, width: 240"] System CMD Rate Mode [/TD]
[TD="class: altvalue"]2T [/TD]
Hi and welcome
Virtually all of these were caused by memory corruption. Please run these two tests.
1. Run memtest.
In order to check your ram we going need to do a test, Please download an burn one of the following iso's on an disk.
Memtest86
When you burned the iso on an disk, please turn off your computer and put the cd in your computer. After a while you will see a black screen saying "Press any key to...". Press any key.
Now let the test run for 5-6 passes. Every time the program returns an error the memory is corrupted / bad or defect or the motherboard is bad / defect. If this occurs then please test every single ram stick individually. When you find a good one wich returns no errors then please test it in every...
zigzag3143
Honorable Member
Microsoft MVP
Hi and welcome
1. Run memtest.
Memtest86
Now let the test run for 5-6 passes. Every time the program returns an error the memory is corrupted / bad or defect or the motherboard is bad / defect. If this occurs then please test every single ram stick individually. When you find a good one wich returns no errors then please test it in every single slot your computer has.
If you get no errors on all slots at all, then continue to step 2 of this post.
Step 2, Run the windows driver verifier.
Please read the following instructions carefully and execute them like i said.
First make an backup of your important data on your computer, and check if you have an second computer to contact us if the driver verifier goes wrong.
Then make an system restore point, You can do this by:
Open the Start menu
Open the Programs menu
Open the Accessories menu
Open the System Tools menu
Finally, start System Restore
Pick the option for setting a System Restore Point and click on the Next button
Fill in a name for the restore point so you can find it and click on the Create button
Click on the Close button when done
After you done all that please continue with the following steps. Please read them carefully
Click on your Start button (Windows Orb) and type "verifier" and hit enter
Select the option: "Create Custom Settings ..." and click Next.
Select the option: "Select Individual settings from full list" and click Next.
Select all options except for the option "Low Resource Simulation" and click Next
Select the option: "Select driver names from a list" and click on Next
Then select all drivers EXCEPT for the drivers provided by Microsoft and click next
Then click on finish.
After doing all this reboot your system and wait for it to go to bluescreen, after the BSOD continue to use your computer normally. If you know what causes the BSOD then repeat doing this. if your system doesnt crash then let it run for atleast 48 hours.
It is normal that your system crashes here, This is because windows is stressing out all Drivers on your system to be able to test them.
Please post back to us what the problem is, memory or drivers. So we can assist you futher. It would be helpfull to know what drivers it are. Most of the time windows reports this.
Ridillz333
I'm running into problems running memtest. usually on the second pass I get "unexpected interupt halting cpu0" and the test stops.
zigzag3143
Honorable Member
Microsoft MVP
Usually indicate of a memory issue. Can you pull all the ram but one stick? If so run memtest on that in stick in that mobo slot.
Ridillz333
Ran 9 passes on the other stick with no errors. as stated above the otherstick only makes it to the second pass before the halting error.
Ridillz333
Same deal, only makes it past the first pass.
Edit: I got another BSOD today "KERNEL_STACK_INPAGE_ERROR" and now I can't connect to the internet with the computer. It says I have a connection but no programs can utilise the connection.
zigzag3143
Honorable Member
Microsoft MVP
Can you upload that DMP file to us?
Ridillz333
Here are some recent dumps. bought new memory and installed it but still having issues
