This WindowsForum thread discusses a recurring Blue Screen of Death (BSOD) problem experienced by the user shortly after building their PC. Initial troubleshooting focused on hardware checks, driver updates, and BIOS updates, with suggestions from the forum indicating the issue may be related to hardware components such as the power supply, overheating, or driver conflicts—particularly involving motherboard utilities and antivirus software. The overall sentiment suggests the problem might originate from hardware or software conflicts, with advice centering on updating drivers, uninstalling problematic software, and ensuring BIOS compatibility to resolve the bluescreens.
Juan Brizzi
Member
A BSoD randomly appears.
The problem began a month after I got the PC, after many attempts of troubleshooting the error (replaced SATA cables, resintalled Windows, Update SSD Firmware, alternate SATA ports, cheked everything is well conected, tested RAM with MEMTEST86) I disabled Intel's Link Power Management because i checked the SSD SMART Data and noticed 22 unexpected power losses, and indeed the BSoD stopped for a couple of weeks but it has come back. I've checked again the SMART Data and noticed that the number of power losses has not increased.
It also has a generic 500WPSU, a HDRADEON 6450 and a WD250GB from my previous PC (which passes Wester digital diagnostic though it shows bad sector when tested with different software, i use it only for storage, it has 100MB reserved partition because i forgot to disconnect it the first time I installed Windows7)
I wonder if my crappy PSU is supplying unstable voltage and that’s the source of the problem...I dont have a tester so couldnt check that out.
I attached all the information I could gather.
Thanks for your help.
BugCheck 124, {0, fffffa800436a028, bf800000, 200401}
Probably caused by : GenuineIntel
Followup: MachineOwner
looking at the voltage I can't work out if that's normal operation or something different. The graph is a tad vague to be honest and I don't believe it shows...
BugCheck 124, {0, fffffa80065b2028, bf800000, 200401}
all your Bugchecks were the same as the above and it means a hardware error occurred. Specifically a 'Machine check exception'.
Normal causes for MCE errors include overheating and/or incorrect hardware installation. Specific manually-induced causes include:
  • overclocking (which normally increases heat-output)
  • poorly-fitted heatsink/computer fans (the same problem can happen with excessive dust in the CPU fan)
  • an overloaded internal or external power-supply (fixable by upgrading)
There can be other causes such as Bios inconsistencies, memory issues and bad or old software/data but usually it's hardware related. Looking at your Bios version I notice its a little out of date:
BiosVersion = F1
BiosReleaseDate = 08/26/2013
I checked on updates but it depends on which version or revision your motherboard is (either 1.1 or 2.00) The actual version/revision number is written on the motherboard itself. Here's a link for version 1.1 but make sure it's correct for your motherboard:
http://www.gigabyte.com/products/product-page.aspx?pid=4729#bios
Check the CPU is ok by running Intel's diagnostic test:
AppleCharger.sys Mon Oct 28 01:59:21 2013: GIGABYTE On/Off Charge driver. May cause BSOD on Win7/8 systems - uninstall to test.
dtsoftbus01.sys Fri Feb 21 09:49:36 2014: Daemon Tools driver. Possible BSOD issues in Win7 uninstall to test.
ENG64.SYS Mon Aug 11 11:25:04 2014: Norton AV. Well known amongst debugging circles for causing issues. Please remove and install MSE for at least the interim.
Use this Norton removal tool otherwise all it's tentacles aren't removed.. 😉
https://support.norton.com/sp/en/uk/home/current/solutions/kb20080710133834EN_EndUserProfile_en_us
Use MSE for the interim as it's very stable:
Run the Intel auto driver updater please:
Rt64win7.sys Thu Oct 25 10:20:09 2012: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet please update:
RTKVHD64.sys Tue Oct 29 10:18:58 2013: Realtek High Definition Audio Function Driver please update:
Post any new dump files.
Juan Brizzi
Member
Thread Author #4
Hi again
I uninstalled the ON/OFF CHARGE and Daemon Tools.
Run the Intel Diagnostic test: OK
Intel Auto Driver updater: everything is up to date
I recorded the system with the Gigabyte Information Viewer and this is what shows before the BSOD appears. The PC was only recording without any working load.
I attached the new bug files as well
Let me know what you think about it please
Juan Brizzi
Member
Thread Author #5
ok, this time it didnt crashed but i stopped it anyway because it got worse, is it normal? what should i do?
looking at the voltage I can't work out if that's normal operation or something different. The graph is a tad vague to be honest and I don't believe it shows anything substantial.
Had another look through the driver stack and found this which I'd earlier missed:
etdrv.sys Fri Mar 20 02:59:06 2009: May be part of Gigabyte Tools Easy Tune 6 (incompatible with Win7)
Please don't forget the changes outlined below:
BiosVersion = F1
ENG64.SYS Mon Aug 11 11:25:04 2014: Link Removed AV. Well known amongst debugging circles for causing issues. Please remove and install MSE for at least the interim.
Use this Link Removed removal tool otherwise all it's tentacles aren't removed.. 😉
BugCheck 124, {0, fffffa800664d028, bf800000, 200401}
I notice the machine crashed whilst a Gigabyte app was running:
gdrv.sys Fri Mar 13 03:22:29 2009: Gigabyte Easy Saver - mobo power utility driver please uninstall to test.
If that fails to stop the bsod then try Norton as I've outlined above. I'm pretty sure this isn't a hardware error but try the above and we'll see..
