The thread discusses a computer experiencing multiple crashes, with the original poster seeking help. A responder analyzes the bugcheck error as related to unreadable RAM data, possibly caused by outdated drivers, BIOS, or hardware issues like faulty RAM. The advice includes updating drivers and BIOS, and temporarily removing Norton antivirus to troubleshoot further.
ToucanSam
Hi Everyone,
I have a computer that crashed twice in October and was fine until this moth when it crashed another two times. I've uploaded the dumps along with the CPU and RAM info.
Anything you could tell me would be much appreciated.
Thank you.
BugCheck 1E, {ffffffffc0000005, fffff80002ee9bad, 0, 30}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2d312 )
Followup: MachineOwner
this bugcheck was generated due to data held in the RAM which was unreadable. Why it was unreadable could be down to a...
this bugcheck was generated due to data held in the RAM which was unreadable. Why it was unreadable could be down to a number of reasons and there are a few causes for this Bugcheck ranging from out of date drivers and bios to hardware issues (usually RAM).
One of your Dump files blamed Norton AV directly and the app itself is a little infamous for causing the odd issue.
I would suggest that you update your drivers and Bios using the Dell support page:
(Although every care is taken to ensure this is your exact download page please make sure)
If you find the issue continues after then post the dump file and depending on what it says it might be worth removing Norton just to see but anyhow try updating first.
