3doz
This computer now after shutting down tries to boot but cant find the drive with the boot info
it somehow changes the bios info
what causes this problem
I have one BSD but it was to quick to read it all
something about not equal
Suggest to replace all of your RAM and use none of the existing at all. Purchase a complete matching set, install, and make sure bios is set to automatic settings.
TorrentG
Banned
Delete ss.sys, AegisP.sys and rt73.sys at C:\Windows\System32\drivers then reboot. Enjoy.
Ya gotta be careful about installing old junk like that. It will bsod every time.
There probably are no new drivers so purchase a replacement for the Belkin. You could check though for July 2009 or newer.
rt73 rt73.sys Thu Nov 24 06:51:35 2005
ss ss.sys Fri Jun 17 13:48:45 2005
AegisP AegisP.sys Tue May 17 16:22:56 2005
3doz
Its still in the system
using regedit it find many links but I cant change the permission to delete them
it slows down the internet and give the BSD
3doz
Belkin is still in the system and using regedit I cant remove them or change the permission to do so
please assist
Elmer
Are the files TorrentG told you to delete still physically in the C:\Windows\System32\drivers folder? Is that your issue?
3doz
no there deleted , the files I am refering to are in the registry
TorrentG
Banned
I'm doubting that, but of course, could be wrong and you have another issue too.
You can post new crash dumps if you want.
Registry entries are not causing crashes at all.
3doz
I am getting a lot of pages closing and opening on different pages
the increadimail locks up on replying
all strange stuff
I have a latest memory scan program and bootet that from the usb and run it all night no problems
the lates blue showed something about manager
TorrentG
Banned
Replace the RAM. It is defective. You don't even have any FAT volumes on the machine - and there is a bsod involving it - 100% defective memory caused this:
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [C:\Downloads\111710-16984-01.dmp]
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x8343f000 PsLoadedModuleList = 0x8357e570
Debug session time: Tue Nov 16 18:34:45.587 2010 (UTC - 5:00)
System Uptime: 0 days 1:06:59.666
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
0: kd> !analyze -v
CACHE_MANAGER (34)
    See the comment for FAT_FILE_SYSTEM (0x23)
Arguments:
Arg1: 00050830
Arg2: 80f59970
Arg3: 80f59550
Arg4: 8349db00
Debugging Details:
EXCEPTION_RECORD:  80f59970 -- (.exr 0xffffffff80f59970)
ExceptionAddress: 8349db00 (nt!ObFastReferenceObject+0x0000000b)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000000
   Parameter[1]: 40000026
Attempt to read from address 40000026
CONTEXT:  80f59550 -- (.cxr 0xffffffff80f59550)
eax=88fff140 ebx=40000026 ecx=89a139f4 edx=85d8d71a esi=88fff140 edi=40000026
eip=8349db00 esp=80f59a38 ebp=80f59a44 iopl=0         nv up ei ng nz na po nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010282
nt!ObFastReferenceObject+0xb:
8349db00 8b0f            mov     ecx,dword ptr [edi]  ds:0023:40000026=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  00000000
EXCEPTION_PARAMETER2:  40000026
READ_ADDRESS: GetPointerFromAddress: unable to read from 8359e700
Unable to read MiSystemVaType memory at 8357e0c0
 40000026
FOLLOWUP_IP:
nt!ObFastReferenceObject+b
FAULTING_IP:
BUGCHECK_STR:  0x34
LAST_CONTROL_TRANSFER:  from 834d75c8 to 8349db00
STACK_TEXT:
80f59a44 834d75c8 40000026 c029bb00 84e05c28 nt!ObFastReferenceObject+0xb
80f59ae4 834a9b05 85d8d718 80f59b7c 00000010 nt!MiMakeSystemCacheRangeValid+0x267
80f59b8c 834e09c2 a6e9b000 00025000 00000000 nt!MmCheckCachedPageStates+0x6f6
80f59bc4 836a1763 85dd4f80 00000001 80f59c48 nt!CcFetchDataForRead+0xb6
80f59c00 834cfa1c 85dd4f80 1a25b000 00000000 nt!CcMapAndCopyFromCache+0x71
80f59ca8 834d2fdc 85dd4f80 a5457a1d 85abe650 nt!CcPerformReadAhead+0x241
80f59d00 8349a083 85abe650 00000000 85b0a020 nt!CcWorkerThread+0x18d
80f59d50 83626d84 00000000 a5457a8d 00000000 nt!ExpWorkerThread+0x10d
80f59d90 834c8159 83499f76 00000000 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ObFastReferenceObject+b
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c3f9b
STACK_COMMAND:  .cxr 0xffffffff80f59550 ; kb
FAILURE_BUCKET_ID:  0x34_nt!ObFastReferenceObject+b
Followup: MachineOwner
0: kd> lmtn
start    end        module name
80bb2000 80bba000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
83408000 8343f000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
8343f000 8383f000   nt       ntkrnlmp.exe Fri Jun 18 23:55:07 2010 (4C1C3F9B)
8c021000 8c099000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
8c099000 8c0aa000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
8c0aa000 8c0b2000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
8c0b2000 8c0f4000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8c0f4000 8c19f000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8c19f000 8c210000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
8c210000 8c21e000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8c21e000 8c266000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8c266000 8c26f000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
8c26f000 8c277000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8c277000 8c2a1000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8c2a1000 8c2ac000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8c2ac000 8c2bd000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
8c2bd000 8c2cd000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8c2cd000 8c318000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8c318000 8c31f000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
8c31f000 8c32d000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8c32d000 8c343000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
8c343000 8c34c000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8c34c000 8c36f000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
8c36f000 8c378000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
8c378000 8c3ac000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8c3ac000 8c3bd000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8c3bd000 8c3fe000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
8c430000 8c55f000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8c55f000 8c58a000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
8c58a000 8c59d000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8c59d000 8c5fa000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
8c5fa000 8c608000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8c608000 8c611000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8c611000 8c6c8000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
8c6c8000 8c706000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
8c706000 8c72b000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
8c72b000 8c785000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
8c785000 8c79f000   serial   serial.sys   Mon Jul 13 19:45:33 2009 (4A5BC71D)
8c79f000 8c7b2000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8c7b2000 8c7c2000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
8c7c2000 8c7cc000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8c7cc000 8c7d8000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8c800000 8c81f000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8c827000 8c970000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
8c970000 8c9a1000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
8c9a1000 8c9a9380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8c9aa000 8c9e9000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
8c9e9000 8c9f1000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
8c9f1000 8ca1e000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
8ca1e000 8ca2e000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8ca2e000 8ca36000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
8ca36000 8ca68000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
8ca68000 8ca79000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
8ca79000 8ca9e000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
8cad0000 8caef000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
8caef000 8cb12000   MpFilter MpFilter.sys Sat Mar 20 00:03:26 2010 (4BA4490E)
8cb12000 8cb19000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
8cb19000 8cb20000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8cb20000 8cb28000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8cb28000 8cb49000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8cb49000 8cb56000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
8cb56000 8cb5e000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8cb5e000 8cb66000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8cb66000 8cb72000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8cb72000 8cb7d000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
8cb7d000 8cb8b000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
8cb8b000 8cba2000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8cba2000 8cbad000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8cbad000 8cbdf000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
8cbdf000 8cbe6000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
8cbe6000 8cbf4000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
8cbf4000 8cbfe000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
93400000 93413000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
93413000 9341a000   TurboB   TurboB.sys   Mon Nov 02 15:45:39 2009 (4AEF44F3)
9342e000 93492000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
93492000 934aa000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
934aa000 934b8000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
934b8000 934d9000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
934d9000 934eb000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
934eb000 9350a000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
9350a000 9354f000   Rt86win7 Rt86win7.sys Wed Jun 23 05:10:23 2010 (4C21CF7F)
9354f000 9357b000   1394ohci 1394ohci.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
9357b000 93593000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
93593000 935a0000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
935a0000 935d1000   msiscsi  msiscsi.sys  Mon Jul 13 19:46:21 2009 (4A5BC74D)
935d1000 93618000   storport storport.sys Mon Jul 13 19:45:58 2009 (4A5BC736)
93618000 9362a000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
9362a000 93642000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
93642000 9364d000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
9364d000 9366f000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
9366f000 93687000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
93687000 9369e000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
9369e000 936b5000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
936b5000 936bf000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
936bf000 936cc000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
936cc000 93700000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
93700000 9370e000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
9370e000 93752000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
93752000 93763000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
93763000 93794000   RMCAST   RMCAST.sys   Mon Jul 13 19:53:39 2009 (4A5BC903)
93794000 937a4000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
937a4000 937ea000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
937ea000 937fa000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
94000000 94009000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
94009000 9400a380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
9400f000 94a8cde0   nvlddmkm nvlddmkm.sys Thu Aug 05 19:32:49 2010 (4C5B4A21)
94a8d000 94a8e040   nvBridge nvBridge.kmd Thu Aug 05 19:33:05 2010 (4C5B4A31)
94a8f000 94b46000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
94b46000 94b7f000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
94b7f000 94b8a000   usbuhci  usbuhci.sys  Mon Jul 13 19:51:10 2009 (4A5BC86E)
94b8a000 94bd5000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
94bd5000 94be4000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
94be4000 94bee000   serenum  serenum.sys  Mon Jul 13 19:45:27 2009 (4A5BC717)
94bee000 94bfb000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
98000000 98308180   RTKVHDA  RTKVHDA.sys  Fri Sep 03 04:00:20 2010 (4C80AB14)
98309000 98338000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
98338000 98351000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
98351000 9835b000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
9835b000 98368000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
98368000 98373000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
98373000 9837c000   dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
9837c000 9838d000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
9838d000 98398000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
98398000 983ab000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
983ab000 983b1480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
983b2000 983b3700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
983b4000 983bf000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
983bf000 983ca000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
983ca000 983e5000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
983e5000 983ff000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
98800000 9881e000   cdd      cdd.dll      unavailable (00000000)
98960000 98bab000   win32k   win32k.sys   unavailable (00000000)
98bc0000 98bc9000   TSDDD    TSDDD.dll    unavailable (00000000)
9e40b000 9e490000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
9e490000 9e4a9000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
9e4a9000 9e4bb000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
9e4bb000 9e4de000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
9e4de000 9e519000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
9e519000 9e534000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
9e54c000 9e5e3000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
9e5e3000 9e5ed000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
9e5ed000 9e60e000   srvnet   srvnet.sys   Thu Aug 26 23:30:39 2010 (4C77315F)
9e60e000 9e61b000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
9e61b000 9e647000   000      000.fcl      Fri Sep 26 09:11:12 2008 (48DCDF70)
9e647000 9e696000   srv2     srv2.sys     Thu Aug 26 23:30:45 2010 (4C773165)
9e696000 9e6e7000   srv      srv.sys      Thu Aug 26 23:31:26 2010 (4C77318E)
9e6e7000 9e6fe000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
9e6fe000 9e70c000   usbscan  usbscan.sys  Mon Jul 13 20:14:44 2009 (4A5BCDF4)
9e70c000 9e717000   usbprint usbprint.sys Mon Jul 13 20:17:06 2009 (4A5BCE82)
9e717000 9e72e000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
9e72e000 9e744000   cdfs     cdfs.sys     Mon Jul 13 19:11:14 2009 (4A5BBF12)
9e7ae000 9e7b7000   asyncmac asyncmac.sys Mon Jul 13 19:54:46 2009 (4A5BC946)
Unloaded modules:
9e744000 9e7ae000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
    Checksum:  00000000
    ImageSize:  0006A000
9e534000 9e54c000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8ca9e000 8caab000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8caab000 8cab6000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
8cab6000 8cabf000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
8cabf000 8cad0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
3doz
whats the best way to sort out 4 sticks for the problem one
the mem program run from ausb on boot does not show it
TorrentG
Banned
Memtest86+.
You should test the modules one at a time, in the slot closest to the CPU. Remove all others while testing.
3doz
thanks will do
know any place that sells ram at the best price in oz it rather high
3doz
One ram tested faulty
now windows is constlye closing down and reopening
I also get a fault werfault,exe has a memory problen
this is nuts just started after I run with just 4 meg ram
TorrentG
Banned
3doz
will do many thanks for the advice will get back if all becoems well
3doz
can you assist with this I dont think its ram
windows explorer keeps shutting down and within a second opens up again
there is no dunps due to this
action center shows no problems
TorrentG
Banned
Nothing to assist with, as I do not have physical access to the machine. Replace the RAM. You have had a professional (me) tell you that RAM is defective. What more do ya want, heh? ;)
