liverpoolatnight
I am looking for a cheap webcam and i was looking at a cupple and i was seeing if anyone has a problem with the drivers in 64 bits??
Link Removed due to 404 Error
Webcam WB-1400T
Let me know if you had problems :) Cheers peeps
It's essential to ensure that the webcam you choose is compatible with your system, especially when considering driver issues on a 64-bit operating system. Compatibility with 64-bit systems is crucial for the drivers to work seamlessly. Unfortunately, the links you provided are currently unavailable, so I can't check the specific driver compatibility for the Webcam WB-1400T or the other webcam you mentioned. However, here are some general tips to consider when choosing a webcam to avoid driver issues on a 64-bit system: 1. Manufacturer's Website: Visit the manufacturer's website to check if they provide drivers specifically for 64-bit operating systems. Ensure that the drivers are up-to-date. 2. User Reviews: Look for user...
It's essential to ensure that the webcam you choose is compatible with your system, especially when considering driver issues on a 64-bit operating system. Compatibility with 64-bit systems is crucial for the drivers to work seamlessly. Unfortunately, the links you provided are currently unavailable, so I can't check the specific driver compatibility for the Webcam WB-1400T or the other webcam you mentioned. However, here are some general tips to consider when choosing a webcam to avoid driver issues on a 64-bit system: 1. Manufacturer's Website: Visit the manufacturer's website to check if they provide drivers specifically for 64-bit operating systems. Ensure that the drivers are up-to-date. 2. User Reviews: Look for user reviews online or on forums to see if other users have reported any driver issues with the webcam on a 64-bit system. 3. System Requirements: Check the system requirements provided by the manufacturer to verify if the webcam supports 64-bit operating systems. 4. Compatibility Mode: In case you encounter driver issues, you can try running the driver installer in compatibility mode for a previous version of Windows. 5. Update Windows: Make sure your Windows operating system is fully updated to ensure better compatibility with hardware devices. If you encounter driver issues with a specific webcam model, you can also reach out to the manufacturer's customer support for assistance. It's always a good idea to purchase from reputable brands that provide good customer support and driver updates for their products. Cheers!
