The thread discusses troubleshooting issues with a built-in webcam on a Valkyrie CZ-15 gaming laptop. The original poster struggles to locate the webcam in Device Manager and discovers that pressing Fn+F6 temporarily toggles the webcam on and off, resolving the problem. Other users provide additional tips, with some noting that the F6 key may control sound on their laptops, indicating that key functions vary between brands.
holidayhawk
Active Member
I'm having problems with my built in webcam. I'm using an Valkyrie CZ-15 from ibuypower. The webcam worked when I first got the laptop, but after not using it for a while it no longer works. I tried to disable and reenable it from device manager, but I couldn't find it in device manager. Does anyone have a fix?
holidayhawk
Active Member
Thread Author #3
I can't find Imaging Devices here what my device manager looks like.
An image from 'Built in webcam problems'. Screenshot of Windows Device Manager showing hardware categories on a laptop.
Jimbo22
From you device manger shot, you don't have the driver installed. Can we get the exact model number of your Valkyrie CZ-15. There should be some more numbers after the 15...eg Valkyrei CZ-15 xxxx. That way we can find the correct driver for you laptop.
holidayhawk
Active Member
Thread Author #5
This is all I can find, "Valkyrie CZ-15 [3] Gaming Laptop." I believe it whatever the default built in camera would be. Sorry I can't find more, is this enough?
holidayhawk
Active Member
Thread Author #7
I just did, and it worked. I never would have believed it would have been such an easy fix, thank you so much!
Jimbo22
Damn it didn't work for me....it turned off my sound...as the F6 key has a speaker on it....this is a samsung laptop. I don't see a webcam symbol on any of the Fkeys. I will have to investigate this further.
But great tip badrobot!
badrobot
No problem. I don't think it's a standard fn key combination. Different brands have different F key settings. :)
Jimbo22
Apparently, Samsung doesn't have a FN key combo to turn on/off the built in webcam.
