The thread discusses whether it's safe to plug in or remove a SATA hard drive cable while the computer is running. The original poster asks for confirmation to avoid hardware damage, and responses indicate that SATA devices are generally hot-swappable, but compatibility depends on the motherboard, and frequent manual swapping can be risky. Overall, the consensus suggests checking the specific ASUS motherboard's manual and exercising caution, especially when handling boot drives.
pstein
I am not sure:
Can I plug-in (and -out) a SATA cable (to hard disc) from (ASUS) motherboard slot when computer is running?
Or will this cause a damage to hardware?
Peter
All SATA devices are required to be hot-swappable by design. However, the OS must support it (and all current operating systems do) but not all SATA "hosts" (controllers) support it - though most do. So as Andrew suggests, you would need to check your motherboard manual to be sure. I would be surprised if an ASUS board did not.
That said, frequent hot-swapping is not recommended, except in "docking" bays where the drive slides in a guide that perfectly aligns the "fixed" connections. Yanking and re-inserting cables by hand risks improper alignment, and those connections are not very robust. And of course, you would not want to hot-swap a boot drive - except in a properly configured RAID setup.
Digerati
Microsoft MVP
