The thread discusses issues with crackling sounds when playing audio and gaming simultaneously on Windows 7, often linked to onboard Realtek sound drivers. Several users share solutions, including updating drivers and adjusting power settings to high performance, though these fixes don't work for everyone. Overall, the sentiment indicates troubleshooting and mixed success in resolving audio crackling problems related to onboard sound hardware.
- Joined
- Nov 10, 2008
- Messages
- 1,634
I had a very similar problem when I had build 6801. What i did to fix it was i went to the Realtek website and downloaded the most up-to-date sound driver for my device. From then on i had no problems with crackling or the sound not working at all.
- Joined
- Nov 10, 2008
- Messages
- 1,634
Very well put. I spent a whole day just looking through and testing the computer to determine the issue. I finallly figured it out 17 hours later when I read a post online that someone had a similar problem in VISTA and that fixed it. So I gave it a whack and it worked.
Ok, I solve my problem:
Go to Control panel - Power options - and instead Balanced check High performance.
And no crackling sound anymore ... that works for me.
This did not work for me.
I, too, am having a problem listening to multiple sound sources in win7. A single source often works fine, but then fails when another sound source activates.
Same exact problem. Has persisted from onboard sound to Creative X-Fi, with absolutely no difference, with or without beta drivers.
Similar threads
- Solved
- Replies
- 18
- Views
- 6K
