awaisagha
hi guys!!!
i have a dell studio laptop 1737...
its specs are
2.18 dual core intel.4gb ram,320gb hdd with sucker dvd rw drive...
i have a problem,since the 1st day i bought it,it burns everything,but when i try to make bootable disk,it says the drive is in PIO mode n not in DMA or DAO mode and needs some settings to be done to bring it in DAO mode.
i went for its solution...
1.i contacted dell help line service,they gave a patch,i applied but still the drive says it is in PIO mode.
2.when i go in device manager,n see the drive in ATA section,it says its DMA is enabled.
somewhere on web search i read,that it might be some problem with cables connecting to dvd drive...making it conflic,not set as proper Master or Slave...
but my Qs is,it has come as from factory laptop,no changes...then how it is possible this problem come....
anyone who knows after this whole story....what is possible solution....
It sounds like you are facing an issue with your Dell Studio laptop's DVD drive being in PIO mode instead of the preferred DMA or DAO mode. Here are some steps you can take to troubleshoot and resolve this problem: 1. Check Hardware Connections: - As you mentioned, the issue might be related to the cables connecting the DVD drive. Ensure the cables are properly connected and not loose or damaged. - Try reseating the cables to make sure they are securely connected. 2. Check Device Manager: - Open Device Manager by right-clicking on the Start button and selecting "Device Manager." - Expand the "IDE ATA/ATAPI controllers" section to see if the DVD drive is listed. - Right-click on the DVD drive and select "Properties" to check...
It sounds like you are facing an issue with your Dell Studio laptop's DVD drive being in PIO mode instead of the preferred DMA or DAO mode. Here are some steps you can take to troubleshoot and resolve this problem: 1. Check Hardware Connections: - As you mentioned, the issue might be related to the cables connecting the DVD drive. Ensure the cables are properly connected and not loose or damaged. - Try reseating the cables to make sure they are securely connected. 2. Check Device Manager: - Open Device Manager by right-clicking on the Start button and selecting "Device Manager." - Expand the "IDE ATA/ATAPI controllers" section to see if the DVD drive is listed. - Right-click on the DVD drive and select "Properties" to check the current transfer mode. 3. Reset to DMA: - If the drive is indeed in PIO mode, you can try resetting it to DMA mode: - Right-click on the DVD drive in Device Manager and select "Uninstall device." - Restart your laptop. Windows should reinstall the driver and set it to DMA mode. 4. Update or Reinstall Drivers: - Ensure that you have the latest drivers for your DVD drive. You can download the drivers from the Dell support website. - If reinstalling the drivers doesn't work, you can try updating the firmware of the DVD drive. 5. Check BIOS Settings: - Enter the BIOS settings of your laptop and check if there are any options related to the DVD drive transfer mode. - Make sure the settings are optimized for performance and not set to a legacy mode that might force PIO mode. 6. System Restore: - If the issue started recently, you can try performing a system restore to a point where the DVD drive was functioning correctly. 7. Hardware Inspection: - Since you suspect a possible cable issue, you may want to consider having a technician inspect the internal hardware of your laptop to ensure everything is connected properly. If after trying these steps the issue persists, it might be a hardware problem with the DVD drive itself, in which case you might need to consider replacing the drive. Since your laptop is a factory setup, it's unusual for such issues to arise without any modifications, but hardware can sometimes develop faults over time. If you encounter any difficulties or need further assistance, feel free to ask for more help!
