mikedizzle
Hello , I'm having issue with wireless at my new townhome. I had Verizon Fios Installed and I'm attempting to connect with my desktop. I have a dell Dimension E521 with Vista and I bought a Trend Net USB adapter, and Dynex PCI card. The adapter showed me the wireless networks the first time I used it but its not even recognizing it now when I put it in. I Installed the card and again it would show me all the wireless networks including my own but it wouldn't connect to any of them. My girlfriends laptop connects just fine so I know its not on Verizons end. It asked me for my security code one time and I typed in the password and it wouldn't connect. I don't have it firewalled and I can't find anything that could be blocking it. Anybody have any ideas?? Thanks
Mike
Hi Mike, It seems like you're facing connectivity issues with your Dell desktop running Windows Vista and trying to connect to a wireless network using both a Trendnet USB adapter and a Dynex PCI card. Since your girlfriend's laptop can connect without any issues, the problem might be specific to your desktop setup. Here are some troubleshooting steps you can try to resolve the wireless connectivity problem: 1. Check for Driver Updates: - Ensure that the drivers for both the Trendnet USB adapter and the Dynex PCI card are up to date. You can visit the respective manufacturer's websites to download the latest drivers compatible with Windows Vista. 2. Restart Networking Services: - Sometimes restarting the networking services...
Hi Mike, It seems like you're facing connectivity issues with your Dell desktop running Windows Vista and trying to connect to a wireless network using both a Trendnet USB adapter and a Dynex PCI card. Since your girlfriend's laptop can connect without any issues, the problem might be specific to your desktop setup. Here are some troubleshooting steps you can try to resolve the wireless connectivity problem: 1. Check for Driver Updates: - Ensure that the drivers for both the Trendnet USB adapter and the Dynex PCI card are up to date. You can visit the respective manufacturer's websites to download the latest drivers compatible with Windows Vista. 2. Restart Networking Services: - Sometimes restarting the networking services can help. You can do this by opening the Command Prompt as an administrator and running these commands:
 netsh winsock reset netsh int ip reset ipconfig /release ipconfig /renew
3. Check Network Settings: - Verify that the network settings on your desktop are correct. Make sure that the wireless network adapter is enabled and set to connect to the correct network. 4. Reconfigure Wireless Network Profile: - Delete the existing wireless network profile on your desktop and create a new one. This can help in removing any corrupt settings. To do this, go to "Network and Sharing Center" > "Manage wireless networks". 5. Temporarily Disable Security Features: - Temporarily disable any firewall or antivirus software that might be blocking the connection. Also, make sure you are entering the correct security key for your wireless network. 6. Try Different USB Port/PCI Slot: - If the adapters are not being recognized, try connecting them to different USB ports (in the case of the Trendnet USB adapter) or PCI slots (Dynex PCI card) on your desktop. 7. Physical Interference: - Ensure that there are no physical obstructions or interference near your desktop that could be affecting the wireless signal reception. 8. System Restore: - If the issue started recently, consider performing a System Restore to a point where the wireless connection was working fine. 9. Contact Manufacturer Support: - If none of the above solutions work, reaching out to the technical support of Trendnet and Dynex for further assistance might be helpful. By following these steps, you should be able to troubleshoot and resolve the wireless connectivity issue on your Dell desktop running Windows Vista. Let me know if you need further assistance!
