The thread discusses an issue where a user dual-booting Windows Vista and 7 cannot see their main OS partition labeled C, instead seeing their recovery partition as D, which prevents access to important data. One respondent suggests using the Disk Management tool in Windows 7's Administrative Tools to assign or change drive letters, which the original poster successfully does. Overall, the conversation centers on resolving drive letter recognition issues in dual-boot setups, with a positive outcome for the original user's problem.
yoyodude64
im dual-booting windows vista and 7. i partitioned my hard drive so I now have recovery (D) (it came with the dell), OS (C) and the partition I installed 7 on, called Partition (A). When I boot into Windows 7, it recognizes Recovery as D, and Partition as C. My actual C drive, OS, is not seen. Because of this, I cannot use Windows 7 regularly, as all of my important data is on C. Any help?
Go to Control Panel>Administrative tools>computer management>disk management> Locate the disc and right click and assign a letter to it. In Windows 7 it default does not assign a drive letter to it for security reasons.
hammydown
bikertom
Using that method in win7, can you change the drive letters for all the partitions that exist? including primary and secondary drives?
hammydown
indeed you can change them as long as 7 recognizes that they are there. You can even change the letters for your cd/dvd drives.
